How to use certbot using localhost name
My domain is: i dont have domain i have a hostname of my machine registry,mylocalk8s.local
sudo certbot --nginx --non-interactive --agree-tos --email contact@mylocalk8s.local --domains registry.mylocalk8s.com --reinstall --redirect
Either it didn't find A record and was giving errors regarding A record and when I put .local it produced below error:
cregistry@cregistry:/etc/nginx/sites-enabled$ sudo certbot --nginx --non-interactive --agree-tos --email contact@local.com --domains registry.mylocalk8s.local --reinstall --redirect
An unexpected error occurred:
The server will not issue certificates for the identifier :: Error creating new order :: Cannot issue for "registry.mylocalk8s.local": Domain name does not end with a valid public suffix (TLD)
nginx version: nginx/1.18.0 (Ubuntu)
ubuntu 20.4 LTS
My hosting provider, if applicable, is: local deployment on VMWare
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
Hello @joshtheflame, welcome to the Let's Encrypt community. :slightly_smiling_face:
Let’s Encrypt offers Domain Validation (DV) certificates. Let's Encrypt does not offer local host without a public facing domain name a Domain Validation (DV) certificates.
Regarding your question about using Certbot for local hostnames: you could set up your own CA with an ACME server and use the Certbot --server option so it will use your own ACME server.
ok thanks alot i think i will try to generate my own SSL using nginx and use that. appreciate your response.
