I can use --dry-run to test certificate creation/renewal and it works great. I noticed however that at the end of the run I get the message
Dry run: skipping deploy hook command: <the command I use in --renew-hook>
Is there a way to force the execution of the renew hook in a test mode? (= the certificate retrieval is dry ran, but then the hook is executed)
