How to run an app running in a specific port using https
i have installed certbot to generate certificate on debian:
sudo apt install certbot python3-certbot-apache
sudo certbot --apache -d your_domain -d www.your_domain
it works as expected when I see the apache file i sse this:
nano /etc/apache2/sites-available/000-default-le-ssl.conf
i have this content :
<IfModule mod_ssl.c>
<VirtualHost *:443>
        # specifies what hostname must appear in the request's Host: header to
        #ServerName www.example.com
        DocumentRoot /var/www/html
        # error, crit, alert, emerg.
        # modules, e.g.
        #LogLevel info ssl:warn
ServerName your_domain.fr
ServerAlias your_domain.fr
SSLCertificateFile /etc/letsencrypt/live/your_domain.fr/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/your_domain.fr/privkey.pem
</VirtualHost>
</IfModule>
i have an application running in the port 3000.
when i type your_domain.fr:3000 it works but when i type
https://your_domain.fr:3000 it doesnt work. could you help please ?
Usually applications cannot run HTTP and HTTPS on the same port. Also, configuring HTTPS on Apache doesn't magically make any other application use HTTPS too.
Also, do you really want to have that application accessible on port 3000? What application is it anyway?
Maybe it's a good idea to put that application on port 3000 behind a reverse proxy set up in Apache, so that Apache does all the HTTPS stuff and you can keep your application HTTP on port 3000. See Reverse Proxy Guide - Apache HTTP Server Version 2.4 for more info about setting up a reverse proxy using Apache.
thnaks for your time, it is an application running using docker compose. which is running on the port 3000.
i'm new to apache, do you think if I put that application on port 3000 behind a reverse proxy set up in Apache it will work.?
thanks
Here details on Apache can be found in documentation and forums:
If the Internet can reach your server on port 3000.
If the application is "OK" with being proxied.
If you know enough about your application to move the service port used [if needed].
If you understand apache well enough to setup the reverse proxy.
Then, I think yes; It could work.
That said, you should first read up on SNI.
Because you may not need to connect to your application via port 3000.
It might be possible to use SNI and connect to your application via port 443 [HTTPS].
Note: I know absolutely nothing about your application, so this advice is very very general.
Here is the preferred method (snap) to install Certbot:
And the second choice (pip) to install Certbot:
well, it is a simple application which running on the port 3000 using docker compose. i have bought a domain name(yourdomain.fr), and i have created a certificate using certbot as explained above.
i can see the apache defaut page when i run https://yourdomain.fr on the browser.
but now my problem is to be able to access to my application using https://yourdomain.fr:3000 if you could help please
example.com is the proper domain name to use if you redacted the actual domain name.
As https://example.com/ shows the intended usages
Example Domain
This domain is for use in illustrative examples in documents. You may use this domain in literature without prior coordination or asking for permission.
Also see:
Yes. See the guide I linked in my post above.
Please note that this is not a generic computer help forum, but specifically for HTTPS/TLS/SSL/ACME/Let's Encrypt. While you might get lucky and have volunteers guide you through the process of setting up a reverse proxy, it might also be possible you need to ask for help for that specific Apache task elsewhere.
The alternative is to have your application on port 3000 run HTTPS on a different port (e.g. 3001), but personally I would not advise that, as it would be much more difficult to redirect HTTP on port 3000 to HTTPS on port 3001. Apache currently is already set up to do that for you, but using port 80 -> 443. So a reverse proxy would be the best solution IMO.
