I suppose all of you already checked this. The same error raised to me during the renewal process. I redirected the traffic from 443 to 8443 (with iptables). The solution was to remove the entry from iptables and stop the tomcat, then executing the renewal process worked like a charm. The script looks like this.
/etc/init.d/tomcat7 stop
iptables -t nat -D PREROUTING -i eth0 -p tcp -m tcp --dport 443 -j REDIRECT --to-ports 8443
$letsencryptdir/letsencrypt-auto renew --standalone --standalone-supported-challenges tls-sni-01 --renew-by-default --email <my_email> --verbose --text --agree-tos
iptables -t nat -I PREROUTING -i eth0 -p tcp -m tcp --dport 443 -j REDIRECT --to-ports 8443
/etc/init.d/tomcat7 start
I’m getting this exact same error, when trying to renew my standalone cert. The DNS A record is correct…
To fix these errors, please make sure that your domain name was entered correctly and the DNS A record(s) for that domain contain(s) the right IP address.
2016-05-12 14:34:20,851:INFO:letsencrypt.auth_handler:Cleaning up challenges
Failed authorization procedure. referendum.ml (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Correct zName not found for TLS SNI challenge. Found 'www.referendum.ml, referendum.ml', www.referendum.ml (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Correct zName not found for TLS SNI challenge. Found 'www.referendum.ml, referendum.ml'
Domain: referendum.ml
Detail: Correct zName not found for TLS SNI challenge. Found
Domain: www.referendum.ml
Hi
I resolved this issue by disabling IPv6 on my Ubuntu 14.04 machine for Apache 2.4 as my server does not have a real IPv6 address.
To accomplish this, I explicitly set the IP address in /etc/apache2/ports.conf
Listen <IP>:80 Listen <IP>:443
and in all vhosts:
<VirtualHost <IP>:80>
instead of
<VirtualHost *:80>
After these changes, netstat -lnp | egrep ":443|:80" shows tcp in the first column instead of tcp6.
Then, the cerbot renew worked like a charm.
Best regards
Frederick Thomssen
Fathomssen solution is what solved the issue for me using Apache2 with Debian. I didn’t have IPv6 enabled, but still ran into the issue when trying to renew my cert because my IP were not defined properly. One was using the loopback and the other *.
Switched the config to use the actual IP and everything worked perfectly
Thank you!
