I am not using the default client. I am using a bash client. But have tried others all with the same effect. The error is exactly what is returned from the server. The certificate that is served if I just use:
Is there something else I can check? Asserting that my server is serving the wrong certificate and not indicating how one can learn that does not help solve this problem for all only those willing to publish the domain name.
The TLS-SNI-01 challenge works by putting a self-signed certificate with a part of the challenge as its CN in it and places this temporary cert in the place of the virtualhost for the requested domain. So the client should have the option to āswap outā your own self signed certificate with its own temporary one⦠Why this doesnāt work is something in the client I think⦠Perhaps you can contact the developper for that bash client?
As far as Iām aware none of the bash clients generate / use a self signed cert. They all just use whatever webserver you have running, and make no changes to it during the challenge. Checking through your account and SSL at the moment I canāt see any reason for the error. Can you run the script with debug turned on, and paste the latter part of the debug ? ( excluding all the private key and domain key information which would have been earlier ) .
Please have a look at the spec how the TLS challenge works and contact the developer of your client directly. You might want to put a link to the opened issue here if your client is hosted on something like GitHub.
The TLS challenge isnāt failing it is on the Letās Encrypt side. The cert works fine and behaves as expected for other services it is only failing in the sense that Letās Encrypt doesnāt accept the cert which is odd because the only (all be it very out dated) documentation indicates that a self signed certificate should work.
Do you have current documentation on how the TLS-SNI-01 challenge works? It isnāt part of the āACME Documentationā at all at this point and there are comments in this forum to the effect that there wonāt be till the standard is out of draft making it rather difficult to implement.
I managed to find some documentation on what exactly needs to be added for tls-sni-01. The client does not generate the self signed certificate so it fails to add the necessary validation to the header. The error returned by Letās Encrypt is very confusing and should be updated.
The documentation on the acme protocol as it stands can be found here:
To my knowledge there is no āno sudoā style client that can use tls-sni-01 since they would need to install a certificate on the fly requiring sudo.
Iāve researched this error message extensively & Iāve tried probably everything thatās been recommended
without success. Mind you, Iām no guru when it comes to this stuff.
As far as Iām concerned, my CName is correct & my DNS A record is correct. From my reading
of the problem these two are ācriticalā.
Iāve got the same error message and couldnāt solve it yesterday. But finally Iāve renewed my certificate:)
Error message:
$ docker run -it --rm -p 1086:80 -p 1087:443 --name letsencrypt -v "/etc/letsencrypt:/etc/letsencrypt" -v "/var/lib/letsencrypt:/var/lib/letsencrypt" quay.io/letsencrypt/letsencrypt:latest renew
Processing /etc/letsencrypt/renewal/drem.jp.conf
2016-03-15 02:57:20,087:WARNING:letsencrypt.cli:Attempting to renew cert from /etc/letsencrypt/renewal/drem.jp.conf produced an unexpected error: Failed authorization procedure. drem.jp (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization
:: Correct zName not found for TLS SNI challenge. Found 'drem.jp'. Skipping.
/etc/letsencrypt/live/drem.jp/fullchain.pem (failure)
Domain: drem.jp
Detail: Correct zName not found for TLS SNI challenge. Found
'drem.jp'
I think that this message was a misleading in my case.
I didnāt change DNS and other network settings. Then I executed the following command on the same host.
$ docker run -it --rm --name letsencrypt -v "/etc/letsencrypt:/etc/letsencrypt" -v "/var/lib/letsencrypt:/var/lib/letsencrypt" -v "/tmp/letsencrypt:/tmp/letsencrypt" quay.io/letsencrypt/letsencrypt:latest certonly
-a webroot --webroot-path=/tmp/letsencrypt -d drem.jp
- Congratulations! Your certificate and chain have been saved at
/etc/letsencrypt/live/drem.jp/fullchain.pem. Your cert will expire
on 2016-06-14. To obtain a new version of the certificate in the
future, simply run Let's Encrypt again.
- If you like Let's Encrypt, please consider supporting our work by:
Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
I didnāt know the cause, but Iāve solve it by using webroot. I hope my case will help others.
Itās not really āsolvedā. The webroot uses the http-01 challenge, while your previous error was caused by the tlssni-01 challenge. So in the end it might be solved for you, but the error for the tlssni-01 challenge probably would still cause problems, when used.
This is justa quick note without proper analysis.
We recived:
Detail: Correct zName not found for TLS SNI challenge. Found ''
for all domains in /etc/apache2/sites-available/reverseproxy-ssl.conf except the last oneā¦
By moving a domain to the end of /etc/apache2/sites-available/reverseproxy-ssl.conf we could generate certificates.
After generating a certs for a domain the reverseproxy-ssl.conf file got updated with one minor error:
The first virtual host declaration recieved a ServerAlias pointing out the last virtual host declaration.
After removing theese ServerAlias declaration our sites are working as expected with letsencrypt certs.
The client currently doesnāt properly support apache configurations with multiple VirtualHosts per file. What @hans.hook is describing is probably a side effect of that.
I thought the certonly flag would conflict with the apache flag? Itās not āonlyā a cert if youāre also getting it to alter your Apache config, surely.
I just checked, and according to the documentation, ācertonlyā works with the standalone and webroot plugins. If you want to use the apache plugin, leave out the ācertonlyā
Indeed certonly and apache conflict but instead of informing about this I get āCorrect zName not found for TLS SNI challengeā + two other error messages I forgot in the meantime.
