How to point to port 80?
I configured A and AAAA recordings. If I call https://api.meteointelligence.com , everything works fine (with my non valid local certificate). But if i call http://api.meteointelligence.com it points to my ip address and I guess this is the problem. So where do I have to configure that the port 80 should be used?
Or are there any issues with Strato? My Server is hosted by Hetzner but the Domain was bought on strato.
certbot --apache
1: api.meteointelligence.com
http-01 challenge for api.meteointelligence.com
Enabled Apache rewrite module
Failed authorization procedure. api.meteointelligence.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://api.meteointelligence.com/.well-known/acme-challenge/8Too29EnWOrLqlk-zZuFnv-7s80ILMbT00fPnkqXwiQ: Connection refused
   Domain: api.meteointelligence.com
   Type:   connection
   Detail: Fetching
   Connection refused
Server version: Apache/2.4.29 (Ubuntu)
Server built:   2019-09-16T12:58:48
Ubuntu 18.04
Server is hosted by Hetzner, Domain was bought by Strato.
Yes
No
certbot 0.31.0
Hi @meteoDaniel
checking your domain that doesn't work - https://check-your-website.server-daten.de/?q=api.meteointelligence.com
api.meteointelligence.com A 176.9.117.21 Falkenstein/Saxony/Germany (DE) - Hetzner Online GmbH Hostname: kvm.esbmz.de yes 1 0
AAAA ::ffff:176.9.117.210 Falkenstein/Saxony/Germany (DE) - Hetzner Online GmbH yes
www.api.meteointelligence.com Name Error yes 1 0
api.meteointelligence.com A 176.9.117.210 Falkenstein/Saxony/Germany (DE) - Hetzner Online GmbH No Hostname found no
The 176.9.117.210 is your old ip address.
But the old answers, the new not:
http://api.meteointelligence.com/ 176.9.117.21 -2 1.127 V
ConnectFailure - Unable to connect to the remote server
http://api.meteointelligence.com/ 176.9.117.210 GZip used - 3138 / 10918 - 71,26 % 200 Html is minified: 223,78 % 0.063 H
So Letsencrypt can't connect your domain because there is no running webserver or a blocking firewall.
And your ipv6 is wrong. That's
not a public visible ipv6 address.
After using one of the several inspection tools I saw that the IP for the A record was wrong. Now everything works fine. Thanks for your support
