How to issue certs for multiple domains with different webroots with acme.sh?
I reverted the apache conf files to what they were before. I mistakenly changed them just before I posted my last reply.
Now, sudo apachectl -t -D DUMP_VHOSTS gives the below output:
port 443 namevhost compzets.com (/etc/apache2/sites-enabled/compzets.com-le-ssl.conf:2)
         port 443 namevhost code.compzets.com (/etc/apache2/sites-enabled/compzets.com-le-ssl.conf:12)
                 alias code.compzets.com
         port 443 namevhost fbapps.compzets.com (/etc/apache2/sites-enabled/compzets.com-le-ssl.conf:48)
                 alias fbapps.compzets.com
         port 443 namevhost game.compzets.com (/etc/apache2/sites-enabled/compzets.com-le-ssl.conf:84)
                 alias game.compzets.com
         port 443 namevhost plugins.compzets.com (/etc/apache2/sites-enabled/compzets.com-le-ssl.conf:120)
                 alias plugins.compzets.com
         port 443 namevhost shopmate.compzets.com (/etc/apache2/sites-enabled/compzets.com-le-ssl.conf:156)
                 alias shopmate.compzets.com
         port 443 namevhost webapps.compzets.com (/etc/apache2/sites-enabled/compzets.com-le-ssl.conf:192)
                 alias webapps.compzets.com
         port 443 namevhost blog.compzets.com (/etc/apache2/sites-enabled/compzets.com-le-ssl.conf:228)
                 alias blog.compzets.com
         port 443 namevhost www.compzets.com (/etc/apache2/sites-enabled/compzets.com-le-ssl.conf:264)
         default server droplet1.compzets.com (/etc/apache2/sites-enabled/000-default.conf:1)
         port 80 namevhost droplet1.compzets.com (/etc/apache2/sites-enabled/000-default.conf:1)
         port 80 namevhost www.compzets.com (/etc/apache2/sites-enabled/compzets.com.conf:1)
         port 80 namevhost compzets.com (/etc/apache2/sites-enabled/compzets.com.conf:36)
         port 80 namevhost code.compzets.com (/etc/apache2/sites-enabled/compzets.com.conf:45)
         port 80 namevhost shopmate.compzets.com (/etc/apache2/sites-enabled/compzets.com.conf:78)
         port 80 namevhost webapps.compzets.com (/etc/apache2/sites-enabled/compzets.com.conf:111)
         port 80 namevhost plugins.compzets.com (/etc/apache2/sites-enabled/compzets.com.conf:144)
         port 80 namevhost fbapps.compzets.com (/etc/apache2/sites-enabled/compzets.com.conf:177)
         port 80 namevhost game.compzets.com (/etc/apache2/sites-enabled/compzets.com.conf:210)
         port 80 namevhost blog.compzets.com (/etc/apache2/sites-enabled/compzets.com.conf:243)
However, the acme.sh issue cert command still gives the same error as posted above.
My apache conf file looks like below:
<IfModule mod_ssl.c>
<VirtualHost *:443>
     ServerName compzets.com
     Redirect permanent / http://www.compzets.com/
SSLCertificateFile /root/.acme.sh/www.compzets.com/www.compzets.com.cer
SSLCertificateKeyFile /root/.acme.sh/www.compzets.com/www.compzets.com.key
SSLCertificateChainFile /root/.acme.sh/www.compzets.com/fullchain.cer
</VirtualHost>
</IfModule>
<VirtualHost *:443>
        # specifies what hostname must appear in the request's Host: header to
        ServerName code.compzets.com
        ServerAlias code.compzets.com
        ServerAdmin webmaster@compzets.com
        DocumentRoot /var/www/compzets.com/code
        # error, crit, alert, emerg.
        # modules, e.g.
        #LogLevel info ssl:warn
SSLCertificateFile /etc/letsencrypt/live/compzets.com/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/compzets.com/privkey.pem
SSLCertificateChainFile /etc/letsencrypt/live/compzets.com/chain.pem
</VirtualHost>
</IfModule>
<VirtualHost *:443>
        ServerName fbapps.compzets.com
        ServerAlias fbapps.compzets.com
        DocumentRoot /var/www/compzets.com/fbapps
        # modules, e.g.
</VirtualHost>
</IfModule>
<VirtualHost *:443>
        ServerName game.compzets.com
        ServerAlias game.compzets.com
        DocumentRoot /var/www/compzets.com/game
        # modules, e.g.
</VirtualHost>
</IfModule>
<VirtualHost *:443>
        ServerName plugins.compzets.com
        ServerAlias plugins.compzets.com
        DocumentRoot /var/www/compzets.com/plugins
        # modules, e.g.
SSLCertificateFile /root/.acme.sh/plugins.compzets.com/plugins.compzets.com.cer
SSLCertificateKeyFile /root/.acme.sh/plugins.compzets.com/plugins.compzets.com.key
SSLCertificateChainFile /root/.acme.sh/plugins.compzets.com/fullchain.cer
</VirtualHost>
</IfModule>
<VirtualHost *:443>
        ServerName shopmate.compzets.com
        ServerAlias shopmate.compzets.com
        DocumentRoot /var/www/shopmate.com
        # modules, e.g.
</VirtualHost>
</IfModule>
<VirtualHost *:443>
        ServerName webapps.compzets.com
        ServerAlias webapps.compzets.com
        DocumentRoot /var/www/compzets.com/webapps
        # modules, e.g.
SSLCertificateFile /root/.acme.sh/webapps.compzets.com/webapps.compzets.com.cer
SSLCertificateKeyFile /root/.acme.sh/webapps.compzets.com/webapps.compzets.com.key
SSLCertificateChainFile /root/.acme.sh/webapps.compzets.com/fullchain.cer
</VirtualHost>
</IfModule>
<VirtualHost *:443>
        ServerName blog.compzets.com
        ServerAlias blog.compzets.com
        DocumentRoot /var/www/compzets.com/blog
        # modules, e.g.
</VirtualHost>
</IfModule>
<VirtualHost *:443>
	ServerName www.compzets.com
	#ServerAlias www.compzets.com
	# modules, e.g.
</VirtualHost>
</IfModule>
This conf file worked okay when the CA was ZeroSSL so I assume it would work when the CA is letencrypt, isn't it?
Can you show the contents of these two files too?
The port 80 vhosts will be the first ones to see the HTTP challenge coming from the Lets Encrypt server. These two files defined all your port 80 vhosts.
Yes, in theory just swapping LE for ZeroSSL should give same result. But, we can only go by what we see now. We do not know what your conf or system state was in when using ZeroSSL.
Also, I do not see that you created a cert with ZeroSSL in the same manner you are trying now with LE. Why this should matter is still a mystery. This is your public cert history crt.sh | compzets.com
000-default.conf:
<VirtualHost *:80>
	#ServerName www.example.com
	DocumentRoot /var/www/html
	# modules, e.g.
</VirtualHost>
compzets.com.conf:
<VirtualHost *:80>
	# modules, e.g.
RewriteEngine on
RewriteCond %{SERVER_NAME} =www.compzets.com
</VirtualHost>
# WWW Redirect
<VirtualHost *:80>
RewriteEngine on
RewriteCond %{SERVER_NAME} =compzets.com
</VirtualHost>
# Sub-domains
<VirtualHost *:80>
        # modules, e.g.
RewriteEngine on
RewriteCond %{SERVER_NAME} =code.compzets.com
</VirtualHost>
<VirtualHost *:80>
        # modules, e.g.
RewriteEngine on
RewriteCond %{SERVER_NAME} =shopmate.compzets.com
</VirtualHost>
<VirtualHost *:80>
        # modules, e.g.
RewriteEngine on
RewriteCond %{SERVER_NAME} =webapps.compzets.com
</VirtualHost>
<VirtualHost *:80>
        # modules, e.g.
RewriteEngine on
RewriteCond %{SERVER_NAME} =plugins.compzets.com
</VirtualHost>
<VirtualHost *:80>
        # modules, e.g.
RewriteEngine on
RewriteCond %{SERVER_NAME} =fbapps.compzets.com
</VirtualHost>
<VirtualHost *:80>
        # modules, e.g.
RewriteEngine on
RewriteCond %{SERVER_NAME} =game.compzets.com
</VirtualHost>
<VirtualHost *:80>
        # modules, e.g.
RewriteEngine on
RewriteCond %{SERVER_NAME} =blog.compzets.com
</VirtualHost>
I can't find anything technically wrong with the current config.
I would check that the challenge requests are being handled as expected.
Abbreviated for clarity:
From the snippets above, requests to HTTP://compzets.com/ and HTTP://www.compzets.com/ should end up being handled from /var/www/compzets.com
We can test that with:
mkdir -p /var/www/compzets.com/.well-known/acme-challenge
echo test1234 > /var/www/compzets.com/.well-known/acme-challenge/Test-File-1234
Then try both:
http://compzets.com/.well-known/acme-challenge/Test-File-1234
http://www.compzets.com/.well-known/acme-challenge/Test-File-1234
Both work as expected. You can hit the URLs from your machine as well. I have it there now.
Ok, the redirects for compzets.com are clumsy (see below) but it should work. Personally I would work on cleaning those up before attempting acme.sh. But, if you want you could try JUST these two domains. Small steps are easier to debug.
acme.sh --issue -d www.compzets.com -d compzets.com -w /var/www/compzets.com --force --server letsencrypt --debug
Redirects for compzets.com
curl -Li http://compzets.com/.well-known/acme-challenge/Test-File-1234
Date: Thu, 11 Nov 2021 13:51:28 GMT
Server: Apache/2.4.7 (Ubuntu)
Location: https://compzets.com/.well-known/acme-challenge/Test-File-1234
Content-Length: 347
Location: http://www.compzets.com/.well-known/acme-challenge/Test-File-1234
Content-Length: 351
Date: Thu, 11 Nov 2021 13:51:29 GMT
Location: https://www.compzets.com/.well-known/acme-challenge/Test-File-1234
Content-Length: 355
HTTP/1.1 200 OK
Last-Modified: Thu, 11 Nov 2021 12:34:00 GMT
ETag: "9-5d0828e9ba2b0"
Accept-Ranges: bytes
Content-Length: 9
test1234
