I have website pointed to the same DocumentRoot, so the main domaine and all subdomaines " * " will root in the same direcotry, with this idea i’m asking how to create same certificat for all domaine inculde main domaine and any subdomain.
Hi @GhoumaTn
this isn't a problem. Choose a client
if you use certbot, then use the webroot plugin with the -w option.
Moved to "Help"
