How to generate a purely manual SSL cert?
I just discovered this system and am very excited about it. I have generated many certs in the past from various issuers, so I’m fairly familiar with the process. But I cannot find any way to generate a cert from letsencrypt without installing certbot on my linux server. I really do not want to install certbot software. I want to generate the cert and install that myself through my WHM.
How can this be done?
Maybe https://zerossl.com/free-ssl/#crt ?
The certs are only 90 days in duration, so manual issuance is not something that is encouraged.
Hi @HerrimanCoder
there are a lot of other clients you can use.
