How to generate a PrivateKey for a certificate issued with CSR?
Hi All,
I am new to Certificate lifecycle management and Encryption. Can someone give me leads if there is some way to create privatekey for a certificate generated from CSR?
My basic requirement is to renew/revoke a certificate which has been issued from CSR on an ACME server.
So renew/revoke needs a private key corresponding to the certificate issued.
Thanks in advance!
Hi @SahanaJC
you can't.
First, a public / private key pair is created. Then you can create the CSR based on the public key.
So there is no way CSR -> private key.
But if you use that certificate, you must have the private key. So there is no need to recreate / extract it.
Those are quite the opposites? Renewing also doesn't require the previous private key as generally a new keypair is generated anyway.
