How to force Apache 2.4 (httpd) to read fullchain.pem? certbot seems to work but I have an https:// issue X86_64 GNU/Linux (Linux 2 AMI)
Port 80 :upside_down_face:, now I will try:
certbot --redirect --uir
1: onearth.studio
2: www.onearth.studio
blank to select all options shown (Enter 'c' to cancel): 1 2
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificate name you requested
and isn't close to expiry.
(ref: /etc/letsencrypt/renewal/onearth.studio.conf)
What would you like to do?
2: Renew & replace the certificate (may be subject to CA rate limits)
Select the appropriate number [1-2] then [enter] (press 'c' to cancel):
Shall I choose 1 or 2?
For Sure! (It's a "blue pill" "red pill" thing)
:cold_face: :hot_face:
I'll go for... 1
I do trust you!
That's a scary thought!
And now your redirect is working!
Date: Sun, 02 May 2021 17:55:58 GMT
Server: Apache/2.4.46 () OpenSSL/1.0.2k-fips PHP/7.4.15
Deploying Certificate to VirtualHost /etc/httpd/conf/httpd-le-ssl.conf
Added an HTTP->HTTPS rewrite in addition to other RewriteRules; you may wish to check
for overall consistency.
Redirecting vhost in /etc/httpd/conf/httpd.conf to ssl vhost in /etc/httpd/conf/httpd-
le-ssl.conf
Adding Upgrade-Insecure-Requests header to ssl vhost in /etc/httpd/conf/httpd-le-ssl.c
onf
Enhancement Upgrade-Insecure-Requests was already set.
Congratulations! You have successfully enabled https://onearth.studio and
https://www.onearth.studio
   Donating to ISRG / Let's Encrypt:   https://letsencrypt.org/donate
   Donating to EFF:                    https://eff.org/donate-le
This is exactly what we want to see! We're getting there!
@griffin was pointing out you might still be getting a "not found" error? Is this still happening?
What says sudo apachectl -S now?
:sweat_smile: :grinning: :smiley:
THX RIP!
THX GRIFFIN!
THX TO ALL LET'S ENCRYPT COMMUNITY SUPPORT TEAM!
You're quite welcome! :slightly_smiling_face:
Of course you are very welcome. Would you please show the output of:
sudo apachectl -S
To relieve our anxiety :thinking:
sudo apachectl -S
It produced this answer:
AH00526: Syntax error on line 24 of /etc/httpd/conf/httpd-le-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/onearth.studio/fullchain.pem' does not
 exist or is empty
Still can't read fullchain.pem, should I post it?
I'm pondering this.
Testing shows the certificate chain to be correct. But why this error?
sudo apachectl configtest shows "Syntax OK"
but
sudo apachectl -S shows the error.
Looking into a few workflows so as to verify the certificate.
Can we have another look at the output from:
sudo certbot certificates
Thanks for your answer, I ran this command:
Found the following certs:
  Certificate Name: onearth.studio
    Serial Number: 4194300b99ca8a4ebb03f7cf8a68856c8b1
    Key Type: RSA
    Domains: onearth.studio www.onearth.studio
    Expiry Date: 2021-07-24 18:28:10+00:00 (VALID: 82 days)
    Certificate Path: /etc/letsencrypt/live/onearth.studio/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/onearth.studio/privkey.pem
I think @Osiris has experience debugging this kind of thing. Maybe he'll give us a "leg up" and help us verify the certificate existence and validity.
@griffin is still working it too!
One would think the apachectl -S wasn't ran through sudo even when @OnEarth said he/she did so :thinking: Usually this (the situation where the file and its contents do actually exist, but Apache says it doesn't) is the result of a permission problem.
Is there a certbot command that can be used to fix permissions and file structure?
@OnEarth Are you certain that you ran: sudo apachectl -S ??
Not that I know of. But it's very rare for root not to be able to read the files in question.
Does apache have directory access (execute permission) all the way up into live?
Osiris, Rip and Griffin, I did a copy and paste with the
sudo apachectl -S
command I am pretty sure but who knows I might have done a mistake because now the output is different:
VirtualHost configuration:
*:80                   onearth.studio (/etc/httpd/conf/httpd.conf:58)
*:443                  is a NameVirtualHost
         default server ip-172-31-33-253.us-east-2.compute.internal (/etc/httpd/conf.d/ssl.conf:56)
         port 443 namevhost ip-172-31-33-253.us-east-2.compute.internal (/etc/httpd/conf.d/ssl.conf:56)
         port 443 namevhost onearth.studio (/etc/httpd/conf/httpd-le-ssl.conf:2)
                 alias www.onearth.studio
ServerRoot: "/etc/httpd"
Main DocumentRoot: "/etc/httpd/htdocs"
Main ErrorLog: "/etc/httpd/logs/error_log"
Mutex authn-socache: using_defaults
Mutex default: dir="/run/httpd/" mechanism=default
Mutex cache-socache: using_defaults
Mutex authdigest-opaque: using_defaults
Mutex proxy-balancer-shm: using_defaults
Mutex authdigest-client: using_defaults
Mutex lua-ivm-shm: using_defaults
Mutex proxy: using_defaults
PidFile: "/run/httpd/httpd.pid"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="apache" id=48
Group: name="apache" id=48
