Ok so I don't see the error now. This is good.
Definitely a difference!
SO GREAT!
THANKS!
Ok @OnEarth ,
Where to go from here?
I'm not seeing any images, looks like your site is based completely on a script that is wrapped in html.
I won't be able to help you fix that, but there are a couple other things you could do to "tighten things up a bit".
Please let us know if your are satisfied at this point or want to continue to tweak some more.
Before the last time I ran sudo apachectl -S, I did not forgot sudo (I think) but after running
certbot --redirect --uir
I did forgot to restart apache, I don't know it it had any impact on the output of:
sudo apachectl -S
Thank you @Osiris
Rip,
I would be very glad to "tighten things up a bit", let me know what I need to do.
It's getting late in France, I'll be back tomorrow.
My site is a React App with Stripe payment method, I will fix the issue with the images.
Thank you again, all of you, for your help and for your patience,
Jan
