How to fix my Lets Encrypt cert so that it's not self signed
I’m using Acme.sh for making certs
server: Linux/Apache 2.4.35
on https://github.com/Neilpang/acme.sh page, I’ve been using section “6. Use Apache mode”
acme.sh --issue --apache -d example.com -d www.example.com -d cp.example.com
to make the certificate, and I’m ending up with a self-signed certificate.
Is there a general rule or setting I need to have in place to make sure that LE is set to sign them instead of my own domain?
Update: I’ve also tried using domain API to automatically issue a cert, with a production key, using the command:
acme.sh --issue --dns dns_gd -d example.com -d www.example.com
What am I doing wrong?
My domain is: prodecksupply.com
acme.sh --issue --dns dns_gd -d prodecksupply.com -d prodecksupply.com
[Mon Mar 4 13:18:09 MST 2019] Domains have changed.
[Mon Mar 4 13:18:09 MST 2019] Multi domain=‘DNS:prodecksupply.com,DNS:prodecksupply.com’
[Mon Mar 4 13:18:09 MST 2019] Getting domain auth token for each domain
[Mon Mar 4 13:18:09 MST 2019] Getting webroot for domain=‘prodecksupply.com
[Mon Mar 4 13:18:09 MST 2019] Getting new-authz for domain=‘prodecksupply.com
[Mon Mar 4 13:18:10 MST 2019] The new-authz request is ok.
[Mon Mar 4 13:18:10 MST 2019] Getting webroot for domain=‘prodecksupply.com
[Mon Mar 4 13:18:10 MST 2019] Getting new-authz for domain=‘prodecksupply.com
[Mon Mar 4 13:18:11 MST 2019] The new-authz request is ok.
[Mon Mar 4 13:18:11 MST 2019] prodecksupply.com is already verified, skip dns-01.
[Mon Mar 4 13:18:11 MST 2019] Verify finished, start to sign.
[Mon Mar 4 13:18:13 MST 2019] Cert success.
[Mon Mar 4 13:18:13 MST 2019] Your cert is in /home/.acme.sh/prodecksupply.com/prodecksupply.com.cer
[Mon Mar 4 13:18:13 MST 2019] Your cert key is in /home/.acme.sh/prodecksupply.com/prodecksupply.com.key
[Mon Mar 4 13:18:13 MST 2019] The intermediate CA cert is in /home/.acme.sh/prodecksupply.com/ca.cer
[Mon Mar 4 13:18:13 MST 2019] And the full chain certs is there: /home/.acme.sh/prodecksupply.com/fullchain.cer
My web server is (include version):Apache Version 2.4.35
The operating system my web server runs on is (include version): Linux 2.6.32-954.3.5.lve1.4.58.el6.x86_64
My hosting provider is: godaddy.com
YES I can login to a root shell on my machine
YES, I’m using a control panel to manage my site
Name and version of the control panel: cPanel Version 70.0 (build 51)
The version of my client is acme.sh v2.8.1
You are using cPanel with acme.sh, which means you’ll need to instruct acme.sh to install the certificate after installation.
Please follow this guide to proceed.
Thank you
Hi @schmitty42
that happens if you have different vHost definitions, so the ACME-client changes the wrong configuration.
CN=prodecksupply.deckandbasement.com
	03.10.2017
	03.10.2018
152 days expired	prodecksupply.deckandbasement.com,
mail.prodecksupply.com, prodecksupply.com,
www.prodecksupply.com,
www.prodecksupply.deckandbasement.com - 5 entries
looks like your website uses the default vHost, not the certificate acme.sh has created.
But: If you have cPanel, isn't there an integrated solution? It may be impossible to install a certificate outside of your cPanel.
They don’t have any sort of simple/built-in/easy-setup utility that I’ve been able to find, but they will allow certificate additions if I create the certs and keys them outside the server. Still looking into this.
Probably your certificate import simply isn't taking effect for some reason. You can confirm that the certificate file generated by acme.sh is not self-signed with a command like
openssl x509 -text -noout -in /home/.acme.sh/prodecksupply.com/prodecksupply.com.cer
You’ve issued the certificate, but have not install it via command line.
The command you show above will not install the certificate to cPanel by default. Check out the guide I posted before and see the bottom section to ask acme.sh to install it…
Thank you
