How to determine resolver and resolver_timeout?
Hi @wizozi,
I think you should write some context to your question
If you are talking about nginx directives resolver
In resolver
directive you put a dns resolver (ip or domain name), it could be your ISP dns resolver, your own resolver or whatever resolver you want to use, if you are unsure you could any of the public dns resolvers like 1.1.1.1 or 9.9.9.9 or 8.8.8.8 or …
resolver 1.1.1.1;
For more info: https://nginx.org/en/docs/http/ngx_http_core_module.html#resolver
In resolver_timeout
you set how long nginx will wait for an anwser from the previously defined resolver
resolver_timeout 15s;
For more info: https://nginx.org/en/docs/http/ngx_http_core_module.html#resolver_timeout
Cheers,
sahsanu
