How to create pfx to specified location when renew?
My domain is:primteksolusindo.com
The operating system my web server runs on is (include version): Centos 7
Hi @winanjaya
if you need a pfx file, your environment should have a tool to create that file. Most tools allow it to say: "Use that output-file".
Hi, JuergenAuer…
Thanks for your reply, I confuse about what file should I use, regarding to create pfx.
Privkey.pem
Cert.pem
Chain.pem
Fullchain.pem
Any suggestion?
Hi @winanjaya,
There are various examples of doing this in earlier threads on the forum; please see
https://community.letsencrypt.org/search?q=openssl%20pkcs12
With Certbot, you could make a deploy-hook script that does this automatically following a certificate renewal.
