Hello
My server is Windows server 2012 R2, IIS 8.5
I want to redirect http:// to http://www - this works
Also want to redirect https:// to https://www - this doesn’t work because of SSL error
Here my configs
www binding working fine
http://www.monstermmorpg.com
or
https://www.monstermmorpg.com
http:// to http//www redirect binding and redirect
http://monstermmorpg.com redirects to http://www.monstermmorpg.com
Now the my problematic part comes
I need your help here
Here how i composed https:// redirect to https://www.
https://monstermmorpg.com to https://www.monstermmorpg.com
However this redirect fails due to SSL mismatch error
How did i compose my SSL certificates?
I have used latest release here
Run as administrator in a static folder
Select N
Select 1
Select all monstermmorpg domains 1 by 1 with repetitive new certificate composition
So where is the error?
Thank you very much for your answers
The SSL error of https://monstermmorpg.com like below
Hi @MonsterMMORPG
checking your certificates you have some new certificates ( https://check-your-website.server-daten.de/?q=monstermmorpg.com#ct-logs ):
| CertSpotter-Id |
Issuer |
not before |
not after |
Domain names |
LE-Duplicate |
next LE |
| 985681314 |
CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US |
2019-06-25 11:00:05 |
2019-09-23 11:00:05 |
www.monstermmorpg.com - 1 entries |
duplicate nr. 1 |
| 985682622 |
2019-06-25 10:59:48 |
2019-09-23 10:59:48 |
static.monstermmorpg.com - 1 entries |
duplicate nr. 1 |
| 985679267 |
2019-06-25 10:58:05 |
2019-09-23 10:58:05 |
duplicate nr. 1 |
| 985633193 |
2019-06-25 10:15:26 |
2019-09-23 10:15:26 |
forumturkce.monstermmorpg.com - 1 entries |
duplicate nr. 1 |
| 985540908 |
2019-06-25 08:58:10 |
2019-09-23 08:58:10 |
forum.monstermmorpg.com - 1 entries |
duplicate nr. 1 |
So you have all required certificates, one with non-www, one with www.
So first step: Update your bindings.
Your www binding is correct, your non-www binding uses the wrong certificate.
First step - all bindings must work, recheck the domain if the Grade N is gone.
Second step - update your redirects. But it's the second step. And you have already a redirect https + non-www -> https + www.
Thank you very much for reply
How am I going to bind non-www to correct one can you explain to me?
that is my primary problem that grade N
Your Topic has the screenshot of your binding. Select the correct certificate.
I have bound it to monstermmorpg.com generated by letsencrypt but still not working
there is alsowww.monstermmorpg.com binding but it also gives error
here available bindings
What's the error message?
It does not give any binding error
But the https error persists
Currently it is set to monstermmorpg.com but the error persists
That's simple.
You have a lot of domains on one server.
So you have to check the
Require Server Name Indication
One domain (the "standard domain") without that check. All other domains -> that must be checked.
The server-daten.de server has the same config: One host doesn't use that checkbox, there is the *.server-daten.de wildcard certificate. All other domains must use SNI to work, then an individual certificate is possible.
I have selected that option but still gives SSL error
If you tell me what steps i need to do i can do that
I am willing to compose a wild card SSL certificate
Ok i have found the solution
I have to check Require Server Name Indication for all domains that uses same IP
How do I create a default SSL for clients that has no SNI capabilities with letsencrypt?
These are Windows XP + IE6.
Select one domain as "main domain", then uncheck that box.
It works only both main and the other http is marked as SNI works
If i don’t mark main one and mark only https redirect, still https redirect giving SSL error
Here let me show
main site bound to 2.226 ip
https redirect site bound to 2.226
no other site domain etc is bound to 2.226
but https redirect still giving SSL error
here > https://monstermmorpg.com
That's a curious configuration. Is it required to select a special ip address? Use always *.
And check your configuration online, then you see, which certificate is used. Last own check - https://check-your-website.server-daten.de/?q=monstermmorpg.com - your non-www uses the www version.
Looks like your configuration is too difficult, so there are errors.
Actually it uses its own certificate
However since main domain SNI is not enabled, giving that error. When I click SNI for main site in IIS as well, it starts working
I have tried bound to * version as well still SSL error persists
