My domain is: paul.kim
I ran this command: sudo letsencrypt --apache -d paul.kim -d www.paul.kim -d blog.paul.kim -d www.blog.paul.kim
error: only one vhost allowed in .conf. So I fixed the issue by creating another vhost.conf file and only adding a single vhost to each .conf file.
My operating system is (include version): Ubuntu Server 16.04 64 bit
My web server is (include version): Apache 2.4
My hosting provider, if applicable, is: Amazon EC2 instance
How can I clean up duplicate certificates? I ran let’s encrypt command for the domain paul.kim
and now I have 2 certificates: paul.kim
and paul.kim-0001
. I messed up on the first one paul.kim
so the second one is the correct one (paul.kim-0001
) is the correct one.
Now it seems that certificates for both paul.kim
and the duplicate paul.kim-0001
will be renewed. How can I remove paul.kim
? Or is it okay to just leave it there since everything is working fine. I’m just concerned because 2 certificates are issued for a single domain and each time I renew, both certs will be renews. I just really need cert renewal for paul.kim-0001
Looking over other posts and the document, it seems I need to delete the following:
/etc/letsencrypt/archive/paul.kim/
/etc/letsencrypt/live/paul.kim/
/etc/letsencrypt/renewal/paul.kim.conf
And leave the following alone intact:
/etc/letsencrypt/archive/paul.kim-0001/
/etc/letsencrypt/live/paul.kim-0001/
/etc/letsencrypt/renewal/paul.kim-0001.conf
Is this correct?
It would be extremely helpful if there was documentation on how to handle removing duplicate certificates (ending in -0001, etc) Or letting us know its okay to just leave it as is. Everything is working fine, but I just have this extra certificate and am not sure if I should just leave it alone or need to clean it up.
