How to add ssl certificate to my web site and how get cA bundle
Hi @Rajendra
there
is your topic. Please don't start new topics with the same problem. Thanks.
My domain is:rajclothcenter.in
The public and private keys (in asymmetric encryption algorithms such as RSA) are linked to each other: one cannot exist without the other.
So if you have a private key, you also have the public key.
But I think a little bit more context is required to answer the question behind the question: why do you need "a public key"?
Sir see this we need to do this process in this video https://youtu.be/sJnup_L2gLM
This is only process to add ssl certificate
OK. You have an existing CSR that you downloaded from your web application, and you want to use it to get a certificate.
This isn't normally how Let's Encrypt is used, because it's a manual process and the certificates are short-lived in duration (90 days). You would have to repeat the process at least that often. If you don't have any other choice, buying a cheap 1-year certificate from another CA might be a better decision.
Nonetheless, it's still possible to do this with Let's Encrypt. There are some sites like https://gethttpsforfree.com which will help you do that.
You can also use one of the existing ACME clients on https://letsencrypt.org/docs/client-options/ to perform the procedure, many of them will allow you to use an existing CSR to create a certificate.
Please don't keep opening new threads with the question in the thread title, if all the questions are related to the same issue. You should continue in your previously opened thread.
Also, @_az has already answered this question in your previous thread, please follow up there:
https://community.letsencrypt.org/t/how-to-get-public-key/136217/6?u=osiris
But it showing your public key isn't formatted correctly now what to do
Please follow up in your previous thread.
Merged .............
Without knowing what you did and where you did that, we cannot answer this.
