My web server is (include version): nestjs 7 (express)
The operating system my web server runs on is (include version): Raspbian Buster
Hi All
I have got my certificate setup and as far as I can tell it will be automatically renewed (when I type systemctl status certbot.timer I see a message saying it will run twice a day). After it has renewed I think that I need to restart my server so I need a hook.
There are instructions here about how to run renew with a post hook when running on the command line. There are also instructions about adding files to the config directory to run as a post hook.
It seems that I want to add files to the config directory that will run when the certificate is renewed - these scripts will run for all domains though. Ideally I want to only restart the appropriate webserver for whatever certificate has been renewed.
Depends on which configuration file you're putting the option. Adding it to /etc/letsencrypt/cli.ini would mean it's used for every certificate indeed, but if you're using /etc/letsencrypt/renewal/${certname}.conf, it's only used for that specific certificate.
