Ok, then sticking to your concern...
May we see the current vhost?:
thank you it's working now ...
https://emplois.kagan.ch Connexion | Site d’administration de Django
if you look above I shared the apache configuration file vhosts but the problem is solved thank you....
How did you fix it?
I reread the documents on letsencrypt and used the following application ![]()
candango/automatoes: A Let's Encrypt/ACME client based on Manuale. You can keep being manual but we're automated also. (github.com)
Thank you for the assistance I tried a lot of things and finally got something to work... specifically Osiris, rg305, MikeMcQ ...
Hm, still a little bit puzzled. Why would that ACME client suddenly work while Certbot didn't?
acme client did not work ... manuale worked...
"manuale" is an ACME client. One of many, like Certbot is an ACME client too. As is django-letsencrypt.
Just curious ... did you use the manuaLE method of creating a TXT record in your DNS?
yes that's correct... my logic was that number 1 they made it in specific languages for a reason and #2 that each language would have an appropriate solution since they likely work on similar types of projects...
Ah, Certbot also offers a manual method. Just know you cannot auto-renew with manual methods. Sometimes that is your only option and maybe that is so with your config.
We were working towards a method which would allow auto-renew. But, I'm still not sure how we'd get you there ![]()
well the stress of time is off I am still interested... at least now I can work on building the website and do not have to have the stupid distraction that oh the website is insecure. are you trying to hack me , I cannot visit website without ssl certification we are not allowed, what is this, no you need to type http:// ... don't just type emplois.kagan... etc.. and will be able to present the website without issues...
Yes, I understand. If you wish more comments you should un-check rg305's post as the Solution. Volunteers won't as likely contribute since you have marked this as solved.
un-solved - LOL
ok thank you... I don't know if unchecked is correct because the problem is solved
... but like you said there might be a better solution although honestly I can't say I require it although I would be interested in knowing a better one... maybe it's better to leave it as solved not to stress the volunteers ...
The problem wasn't solved.
You simply implemented a workaround [the problem].
But the initial problem remains.
The pace to the eventual solution is in your hands.
As long as you keep replying, we will keep trying.
my problem was solved though
all I needed was that workaround... that does not seem like a compromised workaround in any way... I wouldn't mind to know a better solution but this is just for further scope and understanding it's not required in any way...
I kind of disagree.
The topic title isn't "How can I get a cert [quickly]?"
It asks:
"How to acme challenge with Website runnning Apache, Django and FreeBSD"
Which I don't think we have solved yet.
correct but the title was based on the fact that I didn't know that there was another option for certification as the one I did ...
but I'm happy now and would love to hear the answer to the original question... it's just for my benefit I am not going to lose sleep on it like I did last night up to late hours, etc.. had to delete so many different personal videos to make space for all the bad attempts where they required rustc , this that... ,etc..
Again, the pace is in your hands.
We can continue as slowly as you would like.
[so long as there is activity in the topic under 30 days, it will not close automatically]
