How do I configure LE to send/receive emails using SSL?
My host provider (MochaHost) insists that Let's Encrypt does not work with mail servers, to send/receive emails using SSL encryption. He's telling me to buy a paid certificate.
Is that true?
Is there a step by step guide about configuring Let's Encrypt to use on a mail server?
Thank you so much in advance.
My domain is:microsafe.com.br
My web server is (include version):IIS 8.0
The operating system my web server runs on is (include version):Windows Server 2012
My hosting provider, if applicable, is:mochahost.com
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):SolidCP
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):don't know
Welcome to the Let's Encrypt Community :slightly_smiling_face:
Any SSL/TLS certificate, including one issued by Let's Encrypt, can be used to secure email communications. How to do so depends upon the mail server software being used. As this process is not at all specific to Let's Encrypt certificates, I encourage you to search for the documentation for your mail server software, which might be found in the SolidCP documentation.
Thank you. I use SmarterMail for my mail server.
When I questioned MochaHost about it, they sent me this reply:
"Email service is using the SMTP to send emails , IMAP for reading them.
Both services need to have VALID SSL Certificate installed , unfortunately you don't have such !"
Well...
SMTP (465) - filtered
https://decoder.link/sslchecker/microsafe.com.br/465
SMTP (587) - nonresponsive
https://decoder.link/sslchecker/microsafe.com.br/587
IMAP (993) - no certificate
https://decoder.link/sslchecker/microsafe.com.br/993
POP3 (995) - no certificate
https://decoder.link/sslchecker/microsafe.com.br/995
Given these MX records:
microsafe.com.br. 21600 IN MX 10 mx.spamexperts.com.
microsafe.com.br. 21600 IN MX 20 fallbackmx.spamexperts.eu.
microsafe.com.br. 21600 IN MX 30 lastmx.spamexperts.net.
you might need to check with "spamexperts".
Griffin, i'm genuinely thankful for all the trouble you went through to diagnose my mail server configuration. It's highly appreciated.
I have sent this information to Mocha. Let's see what they say.
MX records are for inbound emails.
Outbound emails might be limited by the SPF record. But aren't required to be listed anywhere.
So he may be able to use this system for outbound emailing.
[In order to be included in the inbound emails, then an MX record (and cost) would have to be added]
What MochaHost says is that they tried to attribute Let's Encrypt to the SmarterMail server using the SolidCP tool for that, and it didn't work. They want me to buy a SSL certificate, saying that would work. I don't understand the difference.
I found a tutorial about integrating Let's Encrypt with SmarterMail, but it uses a different tool than the one Mocha authorizes to use. So I'm stuck on that. If I use the tool on the SmarterMail tutorial, they wave themselves of all the responsibilty for that, in the case of a crash or worse.
Here's the tutorial:
https://portal.smartertools.com//kb/a3466/securing-smartermail-with-lets-encrypt.aspx
There are two popular and well documented Windows ACME clients (that I can think of).
If that guide doesn't solve your problem, I would try using PoshACME.
They should be able to integrate a certificate from Let's Encrypt just as easily as they could one from any other CA. (Let's Encrypt encourages automation more than other CAs do with the 90-day-only certificates, but from a technical perspective it works the same way as any other certificate.)
