I will try to create a 4096 SSL certificate using this command sudo certbot certonly --standalone -d mydomainname --rsa-key-size 4096. But throwing this error An unexpected error occurred: TypeError: Password was not given but private key is encrypted.
And i tried another solution for this problem create a certificate using this command sudo certbot certonly --standalone -d my domain name and after that change 2048 bit into 4096 bit using this command sudo openssl req -x509 -newkey rsa:4096 -keyout privkey.pem -out cert.pem -days 365 -subj "/CN=mydomain name"
After that 256 cert.pem converted into 4096
but this certificate shown CA root certificate is not trusted .To enable trust,install this certificates in the trusted root certification authorities store.
This command is probably correct, but you have inadvertently overwritten the private key managed by certbot with another private key, which you have password protected. Certbot doesn't expect its private key to be password protected, so it fails.
That is not a problem now. Created cert.pem using for API Integration but this certificate verification showed the certificate was not under a trusted path file . This is the major problem.I want solution for this issue
Please show this detail.
I agree (mostly)... But, I think that depending on the version of certbot, it might also need:
--key-type rsa
[in any case: it wouldn't hurt to add that in as well]
Assuming you're referring to this command:
With this command you have created a self-signed certificate (completely unrelated to Let's Encrypt) that's useless to you. If you want a (trusted) Let's Encrypt certificate, you will have to use certbot or another ACME client. Creating self-signed certificates will do nothing for you.
I tried the below command in current version
sudo certbot certonly --standalone -d my domain name --rsa-key-size 4096
but I can't be getting a 4096-bit certificate. If any solution for get (trusted) Let's Encrypt certificate in trusted path using certbot.
R3 intermediate itself is 2048bit so not sure if it matters: (long term security should handle by FS ciphersuite
Unfortunately, my crystal globe is being repaired currently. Can you please elaborate on this statement? Without more information from you we can't help you. Please add logs et cetera and provide as much details.
Also:
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it. In any case, all the answers to this questionnaire are required:
Hosting server - aws
I ran this command - sudo certbot certonly --standalone -d mydomainname --rsa-key-size 4096
ValueError: ('Could not deserialize key data. The data may be in an incorrect format, it may be encrypted with an unsupported algorithm, or it may be an unsupported key type (e.g. EC curves with explicit parameters).', [<OpenSSLError(code=503841036, lib=60, reason=524556, reason_text=unsupported)>])
certbot --version: certbot 2.9.0
i want 4096 bit certificate from trusted ca root path
Try specifying the key-type:
sudo certbot certonly --standalone -d mydomainname --key-type rsa --rsa-key-size 4096
Modern versions of certbot default to the elliptic curve key type.
