coffeeok.pp.ua
sudo certbot certonly --manual --preferred-challenges=dns -d coffeeok.pp.ua
and
sudo openssl pkcs12 -export -out coffeok.pp.ua.pfx \
-inkey /etc/letsencrypt/live/coffeeok.pp.ua/privkey.pem
-in /etc/letsencrypt/live/coffeeok.pp.ua/fullchain.pem
Enter Export Password:
Verifying - Enter Export Password:
I left export password empty
IIS 8.5.9600.16384
Windows Server 2012 R2
I used certbot manually on my local machine
no
certbot 3.1.0
So, I have win server as VM on linux machine. IIS can accept connection on non-standart port (because of port forwarding) so that is reason why i used certbot manually. I have next question and I hope you can help me:
If I used certbot with --preferred-challenges=dns key does it mean that I've get wildcart-certificate that I could use for all hosts like my-host.coffeeok.pp.ua . I think yes, but can you approve it?
I have problem with generated .pfx certificate. To generate this certificate I used command
After I tried to import this certificate to IIS I get error
"There was an error while performing this operation.
Details:
The specified network password is not correct."
During the import process I left password field empty because I also set empty export password during pfx certificate generation.
Also the output .pfx file has size 2.7K while .pfx file that I've generated before from ZeroSSL crt files was 5.0K. So I don't know, maybe I missed something.
- Also when I used ZeroSSL first time for correct work I was needed to add intermediate chain certificates. How I can generate it from this .pem files?
Thanks for your answers.
