Help with Obtaining SSL certification for my domain
My domain is: lunar-o.com
I ran this command: sudo certbot --nginx -d n8n.lunar-o.com
It produced this output: Challenge failed for domain n8n.lunar-o.com
http-01 challenge for n8n.lunar-o.com
Domain: n8n.lunar-o.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for n8n.lunar-o.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for n8n.lunar-o.com - check that a DNS record exists for this domain
My web server is (include version): Google Cloud?
The operating system my web server runs on is (include version): I don't know
My hosting provider, if applicable, is: Google Cloud?
To use HTTP domain validation the CA need to check your domain with a special HTTP (tcp port 80) request which your acme certificate software (certbot) helps reply to.
Your domain n8n.lunar-o.com doesn't point to the public IP of your server, so the CA cannot connect to it in order to check the HTTP response.
