Please help me in getting Let’s Encrypt SSL Certificate.
Have you checked out the getting started guide? There are dozens and dozens of configurations you could have, and you’ve provided us with no information. Nobody can really help you without more info, but you should really check out the getting started guide first, and then come here if you have some more specific questions.
When you started your post in the Help category, you were given a number of questions to answer. If you had answered, your answers would have helped the community direct you more specifically. Instead, you deleted them. Therefore, the best we can do is direct you to the page above.
