Hi
I have letsencrypt in docker and i have subdomain.mywebsite.duckdns.org for all my services
eg. radarr / sonarr / etc … It’s all working fine.
If I open and forward port 8883 on my router then I can access mqtt from outside and it’s all working fine. However, I’d like to add a mqtt.subdomain.conf file so I can connect to my mosquitto mqtt server mqtt.mywebsite.duckdns.org using TLS over port 443 without having to open an additional port (8883).
I have tried the following mqtt.subdomain.conf file
listen 443 ssl;
listen [::]:443 ssl;
server_name mqtt.*;
include /config/nginx/ssl.conf;
client_max_body_size 0;
# location / {
# include /config/nginx/proxy.conf;
# resolver 127.0.0.11 valid=30s;
# set $upstream_app mqtt;
# set $upstream_port 8883;
# set $upstream_proto http;
# proxy_pass http://192.168.1.99:8883;
location /api/websocket {
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header Connection "upgrade";
I think the problem is I need to use stream { } ; but when I add I get the error
nginx: [emerg] "stream" directive is not allowed here in /config/nginx/proxy-confs/mqtt.subdomain.conf:39
How can I change the above to use stream for websockets mqtt client.
I actually don’t mind if i use regular mqtt or websockets, but would like to try do without opening the additional ports.
