markjc
August 4, 2021, 12:15pm
#1
My domain is: https://upguitarhill.hopto.org
I ran this command: I went to Check SSL Certificate and I get a chain incomplete error for 1 web site I host from a home computer but not another?
BUT another web site on exactly the same server / environment reports a complete chain?
I.e. the Warning Triangle highlighted in image above has the full chain of certificates and all ok?
I am just confused why this is happening.
Apache latest XAMPP version 80+
Windows 10
NA I home host
Yes
Depends. I work directly within XAMPP and update the letsencrypt certificates when needed
or certbot-auto --version
if you're using Certbot):
Latest version of certbot.
Hello Mark
I can confirm that your Apache is only serving your leaf certificate and not the full chain. You need to change your Apache SSLCertificateFile
directive to point to fullchain.pem
instead of cert.pem
. Don't forget to reload Apache afterwards:
httpd -k graceful
https://www.digicert.com/help/
https://whatsmychaincert.com/?upguitarhill.hopto.org
rg305
August 4, 2021, 2:05pm
#3
Which ACME client do you use?
I think this tells it all:
rg305
August 4, 2021, 2:09pm
#5
Aaaah, yes!
It does tell a lot - but not all (like: version)
True. "Latest" does age rather quickly in technology. OS repos lie too.
rg305
August 4, 2021, 2:22pm
#7
"latest" (for this repo. on this date. obtained via this method.)
And that's if everything worked as expected - what if it hasn't?
markjc
August 4, 2021, 2:32pm
#8
Hi all. Griffin!
Thank you for your time.
I had the following in my SSLCertificateFile setup.
I.e. SSLCertificateFile "C:\Certbot\live\injustice.hopto.org \cert.pem"
SSLCertificateKeyFile "C:\Certbot\live\injustice.hopto.org \privkey.pem"
I then added per your advice this extra line:
SSLCertificateChainFile "C:\Certbot\live\injustice.hopto.org \fullchain.pem"
Rebooted the XAMP server and the web site comes up.
Yet when I run the Check SSL Certificate I still get error.
Happy to help with any checking of my environment. Just help me with what you need / I need to do. Still a newbie with all of this & working on windows. Apol. Certbot is recently fixed thanks to your help previously so it would be very latest and Xampp is also very latest. Oh and PS I run 4 web sites from thsi machine. 1 works with full chain and other three show similar error as above. OH and I did try to not use the cert line but then XAMPP server crashes.
markjc
August 4, 2021, 2:56pm
#9
Hi I fixed it.
Thanks to you all!
The issue seems to be that I must use SSLCertificateChainFile "C:\Certbot\live\upguitarhill.hopto.org \chain.pem" and not fullchain.
OH and also I entered the 3 entries above in two places:
xampp\apache\conf\extra\httpd-vhosts.conf
and
xampp\apache\conf\extra\httpd-ssl.conf
Thanks a mill guys!
I didn't say to add an SSLCertificateChainFile
directive because the SSLCertificateChainFile
directive is obsolete in newer Apache versions.
I said to change cert.pem
to fullchain.pem
in your SSLCertificateFile
directive.
https://httpd.apache.org/docs/current/mod/mod_ssl.html#sslcertificatechainfile
It sounds like your Apache configuration might have some other issues.
What are the outputs of:
httpd -S
dir C:\xampp\apache /q /r /s
dir C:\Certbot /q /r /s
certbot certificates
Please put 3 backticks above and below each output, like this:
output
rg305
August 4, 2021, 7:23pm
#12
And to leave no stone unturned...
Which version of Apache
are you running?
markjc
August 5, 2021, 2:53am
#13
Hi guys. Thanks for your help. I really REALLY appreciate it.
OK
I made the change you recommended and it worked perfectly.
I.e. I changed the cert line to SSLCertificateChainFile "C:\Certbot\live\injustice.hopto.org \fullchain.pem"
I also #'d out all instances of #SSLCertificateChainFile "C:\Certbot\live\pmway.hopto.org \chain.pem" that applied to my 4 web sites.
When I checked the web after restarting XAMPP they ran perfectly and geocert reports a full chain of certificates.
I ran httpd -S from the windows cmd with administrator rights:
C:\WINDOWS\system32>httpd -S
'httpd' is not recognized as an internal or external command,
operable program or batch file.
Was very long and I exceeded the body limit. I will send it in another reply. Hopefully it will go through.
I then ran: dir C:\Certbot /q /r /s
C:\WINDOWS\system32>dir C:\Certbot /q /r /s
Volume in drive C has no label.
Volume Serial Number is 58CF-DBB8
Directory of C:\Certbot
2021/08/05 04:27 AM <DIR> DESKTOP-4BTUU3N\Markus .
2021/08/05 04:27 AM <DIR> NT SERVICE\TrustedInsta..
2021/06/10 10:38 AM <DIR> DESKTOP-4BTUU3N\Markus accounts
2021/06/10 10:44 AM <DIR> DESKTOP-4BTUU3N\Markus archive
2021/06/10 10:44 AM <DIR> DESKTOP-4BTUU3N\Markus csr
2021/06/10 10:44 AM <DIR> DESKTOP-4BTUU3N\Markus keys
2021/08/05 04:26 AM <DIR> DESKTOP-4BTUU3N\Markus lib
2021/06/10 10:44 AM <DIR> DESKTOP-4BTUU3N\Markus live
2021/08/05 04:27 AM <DIR> DESKTOP-4BTUU3N\Markus log
2021/06/10 10:44 AM <DIR> DESKTOP-4BTUU3N\Markus renewal
2021/06/10 07:45 AM <DIR> DESKTOP-4BTUU3N\Markus renewal-hooks
0 File(s) 0 bytes
Directory of C:\Certbot\accounts
2021/06/10 10:38 AM <DIR> DESKTOP-4BTUU3N\Markus .
2021/06/10 10:38 AM <DIR> DESKTOP-4BTUU3N\Markus ..
2021/06/10 10:38 AM <DIR> DESKTOP-4BTUU3N\Markus acme-staging-v02.api.letsencrypt.org
2021/06/10 07:45 AM <DIR> DESKTOP-4BTUU3N\Markus acme-v02.api.letsencrypt.org
0 File(s) 0 bytes
Directory of C:\Certbot\accounts\acme-staging-v02.api.letsencrypt.org
2021/06/10 10:38 AM <DIR> DESKTOP-4BTUU3N\Markus directory
0 File(s) 0 bytes
Directory of C:\Certbot\accounts\acme-staging-v02.api.letsencrypt.org\directory
2021/06/10 10:38 AM <DIR> DESKTOP-4BTUU3N\Markus 708f4b1f168cfc39d3e047810167be41
0 File(s) 0 bytes
Directory of C:\Certbot\accounts\acme-staging-v02.api.letsencrypt.org\directory\708f4b1f168cfc39d3e047810167be41
2021/06/10 10:38 AM 75 BUILTIN\Administrators meta.json
2021/06/10 10:38 AM 1 632 DESKTOP-4BTUU3N\Markus private_key.json
2021/06/10 10:38 AM 86 BUILTIN\Administrators regr.json
3 File(s) 1 793 bytes
Directory of C:\Certbot\accounts\acme-v02.api.letsencrypt.org
2021/06/10 07:45 AM <DIR> DESKTOP-4BTUU3N\Markus .
2021/06/10 07:45 AM <DIR> DESKTOP-4BTUU3N\Markus ..
2021/06/10 07:46 AM <DIR> DESKTOP-4BTUU3N\Markus directory
0 File(s) 0 bytes
Directory of C:\Certbot\accounts\acme-v02.api.letsencrypt.org\directory
2021/06/10 07:46 AM <DIR> DESKTOP-4BTUU3N\Markus .
2021/06/10 07:46 AM <DIR> DESKTOP-4BTUU3N\Markus ..
2021/06/10 07:46 AM <DIR> DESKTOP-4BTUU3N\Markus dab507ffed7b5e57cb652eb328e8a716
0 File(s) 0 bytes
Directory of C:\Certbot\accounts\acme-v02.api.letsencrypt.org\directory\dab507ffed7b5e57cb652eb328e8a716
2021/06/10 09:10 AM 75 DESKTOP-4BTUU3N\Markus meta.json
2021/06/10 07:46 AM 1 632 DESKTOP-4BTUU3N\Markus private_key.json
2021/06/10 07:46 AM 79 DESKTOP-4BTUU3N\Markus regr.json
3 File(s) 1 786 bytes
Directory of C:\Certbot\archive
2021/06/10 10:44 AM <DIR> DESKTOP-4BTUU3N\Markus .
2021/06/10 10:44 AM <DIR> DESKTOP-4BTUU3N\Markus ..
2021/06/10 09:11 AM <DIR> DESKTOP-4BTUU3N\Markus anc.hopto.org
2021/06/10 09:11 AM <DIR> DESKTOP-4BTUU3N\Markus injustice.hopto.org
2021/06/10 10:44 AM <DIR> DESKTOP-4BTUU3N\Markus pmway.hopto.org
2021/06/10 09:11 AM <DIR> DESKTOP-4BTUU3N\Markus upguitarhill.hopto.org
0 File(s) 0 bytes
Directory of C:\Certbot\archive\anc.hopto.org
2021/06/10 09:11 AM <DIR> DESKTOP-4BTUU3N\Markus .
2021/06/10 09:11 AM <DIR> DESKTOP-4BTUU3N\Markus ..
2021/06/10 09:11 AM 1 838 DESKTOP-4BTUU3N\Markus cert1.pem
2021/06/10 09:11 AM 3 749 DESKTOP-4BTUU3N\Markus chain1.pem
2021/06/10 09:11 AM 5 587 DESKTOP-4BTUU3N\Markus fullchain1.pem
2021/06/10 09:11 AM 1 704 DESKTOP-4BTUU3N\Markus privkey1.pem
4 File(s) 12 878 bytes
Directory of C:\Certbot\archive\injustice.hopto.org
2021/06/10 09:11 AM 1 854 DESKTOP-4BTUU3N\Markus cert1.pem
2021/06/10 09:11 AM 5 603 DESKTOP-4BTUU3N\Markus fullchain1.pem
2021/06/10 09:11 AM 1 708 DESKTOP-4BTUU3N\Markus privkey1.pem
4 File(s) 12 914 bytes
Directory of C:\Certbot\archive\pmway.hopto.org
2021/06/10 10:44 AM 1 842 BUILTIN\Administrators cert1.pem
2021/06/10 10:44 AM 3 749 BUILTIN\Administrators chain1.pem
2021/06/10 10:44 AM 5 591 BUILTIN\Administrators fullchain1.pem
2021/06/10 10:44 AM 1 708 DESKTOP-4BTUU3N\Markus privkey1.pem
4 File(s) 12 890 bytes
Directory of C:\Certbot\archive\upguitarhill.hopto.org
2021/06/10 09:11 AM 1 862 DESKTOP-4BTUU3N\Markus cert1.pem
2021/06/10 09:11 AM 5 611 DESKTOP-4BTUU3N\Markus fullchain1.pem
4 File(s) 12 926 bytes
Directory of C:\Certbot\csr
2021/06/10 07:46 AM 924 DESKTOP-4BTUU3N\Markus 0000_csr-certbot.pem
2021/06/10 07:59 AM 936 DESKTOP-4BTUU3N\Markus 0001_csr-certbot.pem
2021/06/10 08:00 AM 936 DESKTOP-4BTUU3N\Markus 0002_csr-certbot.pem
2021/06/10 08:01 AM 936 DESKTOP-4BTUU3N\Markus 0003_csr-certbot.pem
2021/06/10 08:01 AM 932 DESKTOP-4BTUU3N\Markus 0004_csr-certbot.pem
2021/06/10 08:02 AM 924 DESKTOP-4BTUU3N\Markus 0005_csr-certbot.pem
2021/06/10 08:56 AM 924 DESKTOP-4BTUU3N\Markus 0006_csr-certbot.pem
2021/06/10 08:56 AM 924 DESKTOP-4BTUU3N\Markus 0007_csr-certbot.pem
2021/06/10 09:09 AM 1 005 DESKTOP-4BTUU3N\Markus 0008_csr-certbot.pem
2021/06/10 09:11 AM 936 DESKTOP-4BTUU3N\Markus 0009_csr-certbot.pem
2021/06/10 09:11 AM 932 DESKTOP-4BTUU3N\Markus 0010_csr-certbot.pem
2021/06/10 09:11 AM 924 DESKTOP-4BTUU3N\Markus 0011_csr-certbot.pem
2021/06/10 10:40 AM 924 DESKTOP-4BTUU3N\Markus 0012_csr-certbot.pem
2021/06/10 10:44 AM 924 DESKTOP-4BTUU3N\Markus 0013_csr-certbot.pem
14 File(s) 13 081 bytes
Directory of C:\Certbot\keys
2021/06/10 07:46 AM 1 704 DESKTOP-4BTUU3N\Markus 0000_key-certbot.pem
2021/06/10 07:59 AM 1 704 DESKTOP-4BTUU3N\Markus 0001_key-certbot.pem
2021/06/10 08:00 AM 1 704 DESKTOP-4BTUU3N\Markus 0002_key-certbot.pem
2021/06/10 08:01 AM 1 704 DESKTOP-4BTUU3N\Markus 0003_key-certbot.pem
2021/06/10 08:01 AM 1 704 DESKTOP-4BTUU3N\Markus 0004_key-certbot.pem
2021/06/10 08:02 AM 1 708 DESKTOP-4BTUU3N\Markus 0005_key-certbot.pem
2021/06/10 08:56 AM 1 708 DESKTOP-4BTUU3N\Markus 0006_key-certbot.pem
2021/06/10 08:56 AM 1 704 DESKTOP-4BTUU3N\Markus 0007_key-certbot.pem
2021/06/10 09:09 AM 1 704 DESKTOP-4BTUU3N\Markus 0008_key-certbot.pem
2021/06/10 09:11 AM 1 704 DESKTOP-4BTUU3N\Markus 0009_key-certbot.pem
2021/06/10 09:11 AM 1 708 DESKTOP-4BTUU3N\Markus 0010_key-certbot.pem
2021/06/10 09:11 AM 1 704 DESKTOP-4BTUU3N\Markus 0011_key-certbot.pem
2021/06/10 10:40 AM 1 704 DESKTOP-4BTUU3N\Markus 0012_key-certbot.pem
2021/06/10 10:44 AM 1 708 DESKTOP-4BTUU3N\Markus 0013_key-certbot.pem
14 File(s) 23 872 bytes
Directory of C:\Certbot\lib
2021/08/05 04:27 AM <DIR> DESKTOP-4BTUU3N\Markus ..
0 File(s) 0 bytes
Directory of C:\Certbot\live
2021/06/10 09:10 AM 754 DESKTOP-4BTUU3N\Markus README
1 File(s) 754 bytes
Directory of C:\Certbot\live\anc.hopto.org
2021/06/10 09:11 AM <SYMLINK> DESKTOP-4BTUU3N\Markus cert.pem [..\..\archive\anc.hopto.org\cert1.pem]
2021/06/10 09:11 AM <SYMLINK> DESKTOP-4BTUU3N\Markus chain.pem [..\..\archive\anc.hopto.org\chain1.pem]
2021/06/10 09:11 AM <SYMLINK> DESKTOP-4BTUU3N\Markus fullchain.pem [..\..\archive\anc.hopto.org\fullchain1.pem]
2021/06/10 09:11 AM <SYMLINK> DESKTOP-4BTUU3N\Markus privkey.pem [..\..\archive\anc.hopto.org\privkey1.pem]
2021/06/10 09:11 AM 706 DESKTOP-4BTUU3N\Markus README
5 File(s) 706 bytes
Directory of C:\Certbot\live\injustice.hopto.org
2021/06/10 09:11 AM <SYMLINK> DESKTOP-4BTUU3N\Markus cert.pem [..\..\archive\injustice.hopto.org\cert1.pem]
2021/06/10 09:11 AM <SYMLINK> DESKTOP-4BTUU3N\Markus chain.pem [..\..\archive\injustice.hopto.org\chain1.pem]
2021/06/10 09:11 AM <SYMLINK> DESKTOP-4BTUU3N\Markus fullchain.pem [..\..\archive\injustice.hopto.org\fullchain1.pem]
2021/06/10 09:11 AM <SYMLINK> DESKTOP-4BTUU3N\Markus privkey.pem [..\..\archive\injustice.hopto.org\privkey1.pem]
5 File(s) 706 bytes
Directory of C:\Certbot\live\pmway.hopto.org
2021/06/10 10:44 AM <SYMLINK> BUILTIN\Administrators cert.pem [..\..\archive\pmway.hopto.org\cert1.pem]
2021/06/10 10:44 AM <SYMLINK> BUILTIN\Administrators chain.pem [..\..\archive\pmway.hopto.org\chain1.pem]
2021/06/10 10:44 AM <SYMLINK> BUILTIN\Administrators fullchain.pem [..\..\archive\pmway.hopto.org\fullchain1.pem]
2021/06/10 10:44 AM <SYMLINK> BUILTIN\Administrators privkey.pem [..\..\archive\pmway.hopto.org\privkey1.pem]
2021/06/10 10:44 AM 706 BUILTIN\Administrators README
5 File(s) 706 bytes
Directory of C:\Certbot\live\upguitarhill.hopto.org
2021/06/10 09:11 AM <SYMLINK> DESKTOP-4BTUU3N\Markus cert.pem [..\..\archive\upguitarhill.hopto.org\cert1.pem]
2021/06/10 09:11 AM <SYMLINK> DESKTOP-4BTUU3N\Markus chain.pem [..\..\archive\upguitarhill.hopto.org\chain1.pem]
2021/06/10 09:11 AM <SYMLINK> DESKTOP-4BTUU3N\Markus fullchain.pem [..\..\archive\upguitarhill.hopto.org\fullchain1.pem]
2021/06/10 09:11 AM <SYMLINK> DESKTOP-4BTUU3N\Markus privkey.pem [..\..\archive\upguitarhill.hopto.org\privkey1.pem]
5 File(s) 706 bytes
Directory of C:\Certbot\log
2021/08/05 04:27 AM 4 090 BUILTIN\Administrators letsencrypt.log
2021/08/05 04:26 AM 4 090 BUILTIN\Administrators letsencrypt.log.1
2021/06/10 11:28 AM 41 987 BUILTIN\Administrators letsencrypt.log.10
2021/06/10 10:55 AM 5 245 BUILTIN\Administrators letsencrypt.log.11
2021/06/10 10:44 AM 26 176 BUILTIN\Administrators letsencrypt.log.12
2021/06/10 10:43 AM 1 542 BUILTIN\Administrators letsencrypt.log.13
2021/06/10 10:42 AM 4 147 BUILTIN\Administrators letsencrypt.log.14
2021/06/10 10:42 AM 1 587 BUILTIN\Administrators letsencrypt.log.15
2021/06/10 10:40 AM 26 230 BUILTIN\Administrators letsencrypt.log.16
2021/06/10 10:38 AM 36 277 BUILTIN\Administrators letsencrypt.log.17
2021/06/10 09:12 AM 5 248 DESKTOP-4BTUU3N\Markus letsencrypt.log.18
2021/06/10 09:11 AM 25 999 DESKTOP-4BTUU3N\Markus letsencrypt.log.19
2021/07/27 03:56 PM 5 245 BUILTIN\Administrators letsencrypt.log.2
2021/06/10 09:11 AM 26 157 DESKTOP-4BTUU3N\Markus letsencrypt.log.20
2021/06/10 09:11 AM 26 237 DESKTOP-4BTUU3N\Markus letsencrypt.log.21
2021/06/10 09:10 AM 61 351 DESKTOP-4BTUU3N\Markus letsencrypt.log.22
2021/06/10 08:58 AM 899 DESKTOP-4BTUU3N\Markus letsencrypt.log.23
2021/06/10 08:57 AM 25 438 DESKTOP-4BTUU3N\Markus letsencrypt.log.24
2021/06/10 08:56 AM 15 885 DESKTOP-4BTUU3N\Markus letsencrypt.log.25
2021/06/10 08:18 AM 668 DESKTOP-4BTUU3N\Markus letsencrypt.log.26
2021/06/10 08:18 AM 1 048 DESKTOP-4BTUU3N\Markus letsencrypt.log.27
2021/06/10 08:02 AM 20 497 DESKTOP-4BTUU3N\Markus letsencrypt.log.28
2021/06/10 08:02 AM 25 507 DESKTOP-4BTUU3N\Markus letsencrypt.log.29
2021/06/10 03:24 PM 5 245 BUILTIN\Administrators letsencrypt.log.3
2021/06/10 08:01 AM 20 635 DESKTOP-4BTUU3N\Markus letsencrypt.log.30
2021/06/10 08:00 AM 9 257 DESKTOP-4BTUU3N\Markus letsencrypt.log.31
2021/06/10 07:59 AM 9 257 DESKTOP-4BTUU3N\Markus letsencrypt.log.32
2021/06/10 07:47 AM 28 680 DESKTOP-4BTUU3N\Markus letsencrypt.log.33
2021/06/10 07:45 AM 0 DESKTOP-4BTUU3N\Markus letsencrypt.log.34
2021/06/10 03:07 PM 5 245 BUILTIN\Administrators letsencrypt.log.4
2021/06/10 03:06 PM 10 885 BUILTIN\Administrators letsencrypt.log.5
2021/06/10 03:06 PM 34 214 BUILTIN\Administrators letsencrypt.log.6
2021/06/10 03:05 PM 34 122 BUILTIN\Administrators letsencrypt.log.7
2021/06/10 03:03 PM 39 501 BUILTIN\Administrators letsencrypt.log.8
2021/06/10 12:35 PM 4 090 BUILTIN\Administrators letsencrypt.log.9
35 File(s) 592 681 bytes
Directory of C:\Certbot\renewal
2021/06/10 09:11 AM 492 DESKTOP-4BTUU3N\Markus anc.hopto.org.conf
2021/06/10 09:11 AM 522 DESKTOP-4BTUU3N\Markus injustice.hopto.org.conf
2021/06/10 10:44 AM 572 DESKTOP-4BTUU3N\Markus pmway.hopto.org.conf
2021/06/10 09:11 AM 537 DESKTOP-4BTUU3N\Markus upguitarhill.hopto.org.conf
4 File(s) 2 123 bytes
Directory of C:\Certbot\renewal-hooks
2021/06/10 07:45 AM <DIR> DESKTOP-4BTUU3N\Markus deploy
2021/06/10 07:45 AM <DIR> DESKTOP-4BTUU3N\Markus post
2021/06/10 07:45 AM <DIR> DESKTOP-4BTUU3N\Markus pre
0 File(s) 0 bytes
Directory of C:\Certbot\renewal-hooks\deploy
0 File(s) 0 bytes
Directory of C:\Certbot\renewal-hooks\post
0 File(s) 0 bytes
Directory of C:\Certbot\renewal-hooks\pre
0 File(s) 0 bytes
Total Files Listed:
110 File(s) 690 522 bytes
80 Dir(s) 93 507 846 144 bytes free
and then I ran: certbot certificates
C:\WINDOWS\system32>certbot certificates
Saving debug log to C:\Certbot\log\letsencrypt.log
Found the following certs:
Certificate Name: anc.hopto.org
Serial Number: 3689b6c0dee1e0912a57e6ae4ebbe1d59ea
Key Type: RSA
Domains: anc.hopto.org
Expiry Date: 2021-09-08 06:12:00+00:00 (VALID: 34 days)
Certificate Path: C:\Certbot\live\anc.hopto.org\fullchain.pem
Private Key Path: C:\Certbot\live\anc.hopto.org\privkey.pem
Certificate Name: injustice.hopto.org
Serial Number: 3ba1ebd1273e7a1aff7c868fcd7890cbcb6
Key Type: RSA
Domains: injustice.hopto.org
Expiry Date: 2021-09-08 06:11:38+00:00 (VALID: 34 days)
Certificate Path: C:\Certbot\live\injustice.hopto.org\fullchain.pem
Private Key Path: C:\Certbot\live\injustice.hopto.org\privkey.pem
Certificate Name: pmway.hopto.org
Serial Number: 421cafc3b323c682e8d3bf07f21046c9863
Key Type: RSA
Domains: pmway.hopto.org
Expiry Date: 2021-09-08 07:44:10+00:00 (VALID: 34 days)
Certificate Path: C:\Certbot\live\pmway.hopto.org\fullchain.pem
Private Key Path: C:\Certbot\live\pmway.hopto.org\privkey.pem
Certificate Name: upguitarhill.hopto.org
Serial Number: 322e27db860d55b5795b532767a55059087
Key Type: RSA
Domains: upguitarhill.hopto.org
Expiry Date: 2021-09-08 06:11:12+00:00 (VALID: 34 days)
Certificate Path: C:\Certbot\live\upguitarhill.hopto.org\fullchain.pem
Private Key Path: C:\Certbot\live\upguitarhill.hopto.org\privkey.pem
AND finally my Apache version is: Product name Apache HTTP Server
Product version 2.4.47
Hope I did the above correctly.
Looking forward to any and all insights from you guys to sort out my stuff here.
An aside: I do find a strange thing happening when I try to use my web site from work. It reports that the web site is not safe NOT PRIVATE.
A “your connection is not private” error means your browser cannot verify whether a website is safe to visit . Your browser issues this warning message to prevent you from visiting the site, because visiting an unsafe or unsecure site may put your personal information at risk.
You know the google error threatening one of all sorts of dire problems. What is wierd is that this only happens at work. I test my web site using the Opera browser VPN and it finds it no problem.
markjc
August 5, 2021, 2:55am
#14
Here is 3a. Top half of it.
I then ran: dir G:\xampp\apache /q /r /s
C:\WINDOWS\system32>dir G:\xampp\apache /q /r /s
Volume in drive G is G Volume
Volume Serial Number is 626A-6F0D
Directory of G:\xampp\apache
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators .
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators ..
2020/02/21 03:33 AM 13 741 BUILTIN\Administrators ABOUT_APACHE.txt
2013/03/30 02:29 PM 305 BUILTIN\Administrators apache_installservice.bat
2013/03/30 02:29 PM 352 BUILTIN\Administrators apache_uninstallservice.bat
2021/06/09 07:53 AM <DIR> BUILTIN\Administrators bin
2021/04/24 12:34 PM 61 BUILTIN\Administrators CHANGES.txt
2021/06/08 03:31 PM <DIR> BUILTIN\Administrators conf
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators error
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators icons
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators include
2016/05/17 09:59 PM 3 869 BUILTIN\Administrators INSTALL.txt
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators lib
2021/04/24 12:34 PM 44 494 BUILTIN\Administrators LICENSE.txt
2021/08/05 04:32 AM <DIR> BUILTIN\Administrators logs
2021/05/11 08:47 AM 543 BUILTIN\Administrators makecert.bat
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators manual
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators modules
2021/04/24 12:34 PM 2 865 BUILTIN\Administrators NOTICE.txt
2021/04/24 01:12 PM 44 907 BUILTIN\Administrators OPENSSL-NEWS.txt
2021/04/24 01:12 PM 4 545 BUILTIN\Administrators OPENSSL-README.txt
2014/01/23 07:33 PM 4 752 BUILTIN\Administrators README.txt
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators scripts
11 File(s) 120 434 bytes
Directory of G:\xampp\apache\bin
2021/06/09 07:53 AM <DIR> BUILTIN\Administrators .
2021/06/09 07:53 AM <DIR> BUILTIN\Administrators ..
2021/02/03 11:25 AM 47 DESKTOP-4BTUU3N\Markus .htpasswd
2021/04/24 01:09 PM 98 304 BUILTIN\Administrators ab.exe
2021/04/24 01:09 PM 110 592 BUILTIN\Administrators abs.exe
2021/06/09 07:52 AM <DIR> DESKTOP-4BTUU3N\Markus Apache password files
2021/04/24 01:09 PM 43 008 BUILTIN\Administrators ApacheMonitor.exe
2021/04/24 01:09 PM 19 456 BUILTIN\Administrators apr_crypto_openssl-1.dll
2021/04/24 01:09 PM 31 232 BUILTIN\Administrators apr_dbd_odbc-1.dll
2021/04/24 01:09 PM 14 848 BUILTIN\Administrators apr_ldap-1.dll
2021/04/13 06:13 AM 206 919 BUILTIN\Administrators curl-ca-bundle.crt
2019/02/06 08:58 AM 4 110 456 BUILTIN\Administrators curl.exe
2021/04/24 01:12 PM 9 192 BUILTIN\Administrators dbmmanage.pl
2021/04/24 01:10 PM 101 376 BUILTIN\Administrators htcacheclean.exe
2021/04/24 01:10 PM 123 904 BUILTIN\Administrators htdbm.exe
2021/04/24 01:10 PM 85 504 BUILTIN\Administrators htdigest.exe
2021/04/24 01:10 PM 119 296 BUILTIN\Administrators htpasswd.exe
2021/04/24 01:12 PM 29 696 BUILTIN\Administrators httpd.exe
2021/04/24 01:10 PM 66 048 BUILTIN\Administrators httxt2dbm.exe
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators iconv
2021/05/05 03:10 AM 28 568 064 BUILTIN\Administrators icudt68.dll
2021/05/05 03:10 AM 2 962 944 BUILTIN\Administrators icuin68.dll
2021/05/05 03:10 AM 60 416 BUILTIN\Administrators icuio68.dll
2021/05/05 03:10 AM 2 187 264 BUILTIN\Administrators icuuc68.dll
2020/07/27 12:14 PM 53 760 BUILTIN\Administrators jansson.dll
2021/04/24 01:08 PM 213 504 BUILTIN\Administrators libapr-1.dll
2021/04/24 01:08 PM 36 864 BUILTIN\Administrators libapriconv-1.dll
2021/04/24 01:08 PM 278 528 BUILTIN\Administrators libaprutil-1.dll
2021/03/27 01:13 PM 3 437 056 BUILTIN\Administrators libcrypto-1_1-x64.dll
2019/02/06 08:58 AM 1 020 536 BUILTIN\Administrators libcurl.dll
2021/04/24 01:08 PM 442 880 BUILTIN\Administrators libhttpd.dll
2021/05/05 03:10 AM 194 560 BUILTIN\Administrators libsasl.dll
2021/05/05 03:10 AM 281 600 BUILTIN\Administrators libssh2.dll
2021/03/27 01:14 PM 686 592 BUILTIN\Administrators libssl-1_1-x64.dll
2020/02/17 02:25 PM 1 391 616 BUILTIN\Administrators libxml2.dll
2021/04/24 01:10 PM 58 368 BUILTIN\Administrators logresolve.exe
2019/04/05 04:28 PM 184 320 BUILTIN\Administrators lua52.dll
2021/06/09 07:53 AM <DIR> DESKTOP-4BTUU3N\Markus NB htaccess for user and pwd in apache bin
2021/04/24 12:17 PM 147 968 BUILTIN\Administrators nghttp2.dll
2021/03/27 01:15 PM 549 376 BUILTIN\Administrators openssl.exe
2020/02/17 02:44 PM 395 264 BUILTIN\Administrators pcre.dll
2012/04/16 07:30 PM 61 440 BUILTIN\Administrators pv.exe
2021/04/24 01:09 PM 78 336 BUILTIN\Administrators rotatelogs.exe
2021/04/24 01:09 PM 18 432 BUILTIN\Administrators wintty.exe
2019/04/05 02:30 PM 86 016 BUILTIN\Administrators zlib1.dll
40 File(s) 48 565 582 bytes
Directory of G:\xampp\apache\bin\Apache password files
2021/06/09 07:52 AM <DIR> DESKTOP-4BTUU3N\Markus .
2021/06/09 07:52 AM <DIR> BUILTIN\Administrators ..
2021/06/09 07:52 AM <DIR> DESKTOP-4BTUU3N\Markus NB htaccess for user and pwd in apache bin
1 File(s) 47 bytes
Directory of G:\xampp\apache\bin\Apache password files\NB htaccess for user and pwd in apache bin
2021/06/09 07:52 AM <DIR> DESKTOP-4BTUU3N\Markus ..
2021/02/03 11:27 AM 96 DESKTOP-4BTUU3N\Markus .htaccess
2021/02/03 11:30 AM 16 DESKTOP-4BTUU3N\Markus nbhtpasswd.txt
2 File(s) 112 bytes
Directory of G:\xampp\apache\bin\iconv
2020/07/27 01:34 PM 14 848 BUILTIN\Administrators adobe-stdenc.so
2020/07/27 01:34 PM 15 360 BUILTIN\Administrators adobe-zdingbats.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators cp037.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators cp038.so
2020/07/27 01:34 PM 14 848 BUILTIN\Administrators cp10006.so
2020/07/27 01:34 PM 14 848 BUILTIN\Administrators cp10007.so
2020/07/27 01:34 PM 15 360 BUILTIN\Administrators cp10029.so
2020/07/27 01:34 PM 13 824 BUILTIN\Administrators cp1006.so
2020/07/27 01:34 PM 15 872 BUILTIN\Administrators cp10079.so
2020/07/27 01:34 PM 15 872 BUILTIN\Administrators cp10081.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators cp1026.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators cp273.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators cp274.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators cp275.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators cp277.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators cp278.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators cp280.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators cp281.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators cp284.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators cp285.so
2020/07/27 01:34 PM 13 312 BUILTIN\Administrators cp290.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators cp297.so
2020/07/27 01:34 PM 13 312 BUILTIN\Administrators cp420.so
2020/07/27 01:34 PM 14 336 BUILTIN\Administrators cp423.so
2020/07/27 01:34 PM 13 312 BUILTIN\Administrators cp424.so
2020/07/27 01:34 PM 15 360 BUILTIN\Administrators cp437.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators cp500.so
2020/07/27 01:34 PM 14 336 BUILTIN\Administrators cp737.so
2020/07/27 01:34 PM 14 336 BUILTIN\Administrators cp775.so
2020/07/27 01:34 PM 13 824 BUILTIN\Administrators cp850.so
2020/07/27 01:34 PM 13 824 BUILTIN\Administrators cp851.so
2020/07/27 01:34 PM 13 824 BUILTIN\Administrators cp852.so
2020/07/27 01:34 PM 13 824 BUILTIN\Administrators cp855.so
2020/07/27 01:34 PM 13 824 BUILTIN\Administrators cp856.so
2020/07/27 01:34 PM 13 312 BUILTIN\Administrators cp857.so
2020/07/27 01:34 PM 14 848 BUILTIN\Administrators cp860.so
2020/07/27 01:34 PM 15 360 BUILTIN\Administrators cp861.so
2020/07/27 01:34 PM 15 872 BUILTIN\Administrators cp862.so
2020/07/27 01:34 PM 15 360 BUILTIN\Administrators cp863.so
2020/07/27 01:34 PM 14 848 BUILTIN\Administrators cp864.so
2020/07/27 01:34 PM 15 360 BUILTIN\Administrators cp865.so
2020/07/27 01:34 PM 14 336 BUILTIN\Administrators cp866.so
2020/07/27 01:34 PM 14 336 BUILTIN\Administrators cp868.so
2020/07/27 01:34 PM 13 824 BUILTIN\Administrators cp869.so
2020/07/27 01:34 PM 13 312 BUILTIN\Administrators cp870.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators cp871.so
2020/07/27 01:34 PM 13 312 BUILTIN\Administrators cp874.so
2020/07/27 01:34 PM 13 312 BUILTIN\Administrators cp875.so
2020/07/27 01:34 PM 13 312 BUILTIN\Administrators cp880.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators cp891.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators cp903.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators cp904.so
2020/07/27 01:34 PM 13 312 BUILTIN\Administrators cp905.so
2020/07/27 01:34 PM 13 312 BUILTIN\Administrators cp918.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators dec-mcs.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators ebcdic-at-de-a.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators ebcdic-at-de.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators ebcdic-ca-fr.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators ebcdic-dk-no-a.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators ebcdic-dk-no.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators ebcdic-es-a.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators ebcdic-es-s.so
2020/07/27 01:34 PM 12 800 BUILTIN\Administrators ebcdic-es.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators ebcdic-fi-se-a.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators ebcdic-fi-se.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators ebcdic-fr.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators ebcdic-it.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators ebcdic-pt.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators ebcdic-uk.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators ebcdic-us.so
2020/07/27 01:34 PM 9 728 BUILTIN\Administrators euc-jp.so
2020/07/27 01:34 PM 9 728 BUILTIN\Administrators euc-kr.so
2020/07/27 01:34 PM 9 728 BUILTIN\Administrators euc-tw.so
2020/07/27 01:34 PM 9 728 BUILTIN\Administrators gb2312.so
2020/07/27 01:35 PM 14 848 BUILTIN\Administrators hp-roman8.so
2020/07/27 01:34 PM 9 728 BUILTIN\Administrators iso-10646-ucs-2.so
2020/07/27 01:34 PM 10 240 BUILTIN\Administrators iso-10646-ucs-4.so
2020/07/27 01:34 PM 10 240 BUILTIN\Administrators iso-2022-cn.so
2020/07/27 01:34 PM 10 240 BUILTIN\Administrators iso-2022-jp-2.so
2020/07/27 01:34 PM 10 240 BUILTIN\Administrators iso-2022-jp.so
2020/07/27 01:34 PM 9 728 BUILTIN\Administrators iso-2022-kr.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-8859-1.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-8859-10.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-8859-13.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-8859-14.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-8859-15.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-8859-2.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-8859-3.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-8859-4.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-8859-5.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-8859-6.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-8859-7.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-8859-8.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-8859-9.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-10.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-102.so
2020/07/27 01:35 PM 13 824 BUILTIN\Administrators iso-ir-103.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-11.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-ir-111.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-121.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-122.so
2020/07/27 01:35 PM 14 848 BUILTIN\Administrators iso-ir-123.so
2020/07/27 01:35 PM 15 360 BUILTIN\Administrators iso-ir-128.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-13.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-ir-139.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-14.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-141.so
2020/07/27 01:35 PM 14 848 BUILTIN\Administrators iso-ir-142.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-146.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-147.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-15.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-ir-150.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-151.so
2020/07/27 01:35 PM 14 336 BUILTIN\Administrators iso-ir-152.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-153.so
2020/07/27 01:35 PM 14 336 BUILTIN\Administrators iso-ir-154.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-ir-155.so
2020/07/27 01:35 PM 13 824 BUILTIN\Administrators iso-ir-158.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-16.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-17.so
2020/07/27 01:35 PM 13 824 BUILTIN\Administrators iso-ir-18.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-19.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-2.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-21.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-25.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-ir-27.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-37.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-4.so
2020/07/27 01:35 PM 13 824 BUILTIN\Administrators iso-ir-47.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-49.so
2020/07/27 01:35 PM 14 848 BUILTIN\Administrators iso-ir-50.so
2020/07/27 01:35 PM 14 848 BUILTIN\Administrators iso-ir-51.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-54.so
2020/07/27 01:35 PM 13 824 BUILTIN\Administrators iso-ir-55.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-57.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-60.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-61.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-69.so
2020/07/27 01:35 PM 14 848 BUILTIN\Administrators iso-ir-70.so
2020/07/27 01:35 PM 13 824 BUILTIN\Administrators iso-ir-8-1.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-8-2.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-84.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-85.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-86.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-ir-88.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators iso-ir-89.so
2020/07/27 01:35 PM 13 824 BUILTIN\Administrators iso-ir-9-1.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-9-2.so
2020/07/27 01:35 PM 14 848 BUILTIN\Administrators iso-ir-90.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-91.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-92.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-93.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-94.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso-ir-95.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-96.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso-ir-98.so
2020/07/27 01:35 PM 15 360 BUILTIN\Administrators iso-ir-99.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators iso646-dk.so
2020/07/27 01:35 PM 12 800 BUILTIN\Administrators iso646-kr.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators jis_x0201.so
2020/07/27 01:35 PM 14 336 BUILTIN\Administrators koi8-r.so
2020/07/27 01:35 PM 14 336 BUILTIN\Administrators koi8-ru.so
2020/07/27 01:35 PM 14 336 BUILTIN\Administrators koi8-u.so
2020/07/27 01:35 PM 15 360 BUILTIN\Administrators mac-ce.so
2020/07/27 01:35 PM 16 384 BUILTIN\Administrators mac-croatian.so
2020/07/27 01:35 PM 14 848 BUILTIN\Administrators mac-cyrillic.so
2020/07/27 01:35 PM 15 872 BUILTIN\Administrators mac-dingbats.so
2020/07/27 01:35 PM 15 360 BUILTIN\Administrators mac-greek.so
2020/07/27 01:35 PM 16 384 BUILTIN\Administrators mac-iceland.so
2020/07/27 01:35 PM 16 384 BUILTIN\Administrators mac-romania.so
2020/07/27 01:35 PM 14 336 BUILTIN\Administrators mac-thai.so
2020/07/27 01:35 PM 16 384 BUILTIN\Administrators mac-turkish.so
2020/07/27 01:35 PM 11 776 BUILTIN\Administrators mac-ukraine.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators osd_ebcdic_df04_1.so
2020/07/27 01:35 PM 13 312 BUILTIN\Administrators osd_ebcdic_df04_15.so
2020/07/27 01:34 PM 9 728 BUILTIN\Administrators ucs2-internal.so
2020/07/27 01:34 PM 9 728 BUILTIN\Administrators ucs4-internal.so
2020/07/27 01:34 PM 12 288 BUILTIN\Administrators unicode-1-1-utf-7.so
2020/07/27 01:35 PM 12 288 BUILTIN\Administrators us-ascii.so
2020/07/27 01:34 PM 10 240 BUILTIN\Administrators utf-16.so
2020/07/27 01:34 PM 10 240 BUILTIN\Administrators utf-8.so
2020/07/27 01:35 PM 14 336 BUILTIN\Administrators windows-1250.so
2020/07/27 01:35 PM 13 824 BUILTIN\Administrators windows-1251.so
2020/07/27 01:35 PM 14 336 BUILTIN\Administrators windows-1252.so
2020/07/27 01:35 PM 14 336 BUILTIN\Administrators windows-1253.so
2020/07/27 01:35 PM 14 336 BUILTIN\Administrators windows-1254.so
2020/07/27 01:35 PM 14 848 BUILTIN\Administrators windows-1255.so
2020/07/27 01:35 PM 14 848 BUILTIN\Administrators windows-1256.so
2020/07/27 01:35 PM 14 336 BUILTIN\Administrators windows-1257.so
2020/07/27 01:35 PM 14 848 BUILTIN\Administrators windows-1258.so
2020/07/27 01:34 PM 10 240 BUILTIN\Administrators _tbl_simple.so
191 File(s) 2 520 576 bytes
Directory of G:\xampp\apache\bin\NB htaccess for user and pwd in apache bin
2021/06/09 07:53 AM <DIR> DESKTOP-4BTUU3N\Markus .
2 File(s) 112 bytes
Directory of G:\xampp\apache\conf
2021/06/08 03:31 PM <DIR> BUILTIN\Administrators .
2021/06/08 03:31 PM <DIR> BUILTIN\Administrators ..
2021/04/24 01:12 PM 1 820 BUILTIN\Administrators charset.conv
2021/06/10 08:37 AM <DIR> BUILTIN\Administrators extra
2021/06/09 08:44 AM 8 956 BUILTIN\Administrators httpd.conf
2021/04/24 01:12 PM 13 449 BUILTIN\Administrators magic
2021/05/11 08:47 AM 60 869 BUILTIN\Administrators mime.types
2021/03/25 04:28 PM 11 259 BUILTIN\Administrators openssl.cnf
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators original
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators ssl.crt
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators ssl.csr
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators ssl.key
5 File(s) 96 353 bytes
Directory of G:\xampp\apache\conf\extra
2021/06/10 08:37 AM <DIR> BUILTIN\Administrators .
2021/06/10 08:37 AM <DIR> BUILTIN\Administrators ..
2021/06/08 04:30 PM <DIR> DESKTOP-4BTUU3N\Markus bak
2021/06/10 08:37 AM <DIR> DESKTOP-4BTUU3N\Markus bakforlivemovedtoG
2013/03/30 02:29 PM 432 BUILTIN\Administrators httpd-ajp.conf
2021/06/08 03:31 PM 3 048 BUILTIN\Administrators httpd-autoindex.conf
2021/06/08 03:31 PM 2 128 BUILTIN\Administrators httpd-dav.conf
2021/06/08 03:31 PM 3 032 BUILTIN\Administrators httpd-default.conf
2021/06/08 03:31 PM 1 220 BUILTIN\Administrators httpd-info.conf
2021/06/08 03:31 PM 5 300 BUILTIN\Administrators httpd-languages.conf
2021/06/08 03:31 PM 1 427 BUILTIN\Administrators httpd-manual.conf
2021/06/08 03:31 PM 4 563 BUILTIN\Administrators httpd-mpm.conf
2021/06/08 03:31 PM 2 382 BUILTIN\Administrators httpd-multilang-errordoc.conf
2013/03/30 02:29 PM 276 BUILTIN\Administrators httpd-proxy.conf
2021/08/05 04:11 AM 11 340 BUILTIN\Administrators httpd-ssl.conf
2021/06/08 03:31 PM 952 BUILTIN\Administrators httpd-userdir.conf
2021/08/05 04:10 AM 9 120 BUILTIN\Administrators httpd-vhosts.conf
2021/06/08 03:31 PM 2 787 BUILTIN\Administrators httpd-xampp.conf
2021/04/24 01:12 PM 3 251 BUILTIN\Administrators proxy-html.conf
15 File(s) 51 258 bytes
Directory of G:\xampp\apache\conf\extra\bak
2021/06/08 04:30 PM <DIR> DESKTOP-4BTUU3N\Markus .
2021/06/08 04:30 PM <DIR> BUILTIN\Administrators ..
2013/03/30 02:29 PM 432 DESKTOP-4BTUU3N\Markus httpd-ajp.conf
2021/06/08 03:31 PM 3 048 DESKTOP-4BTUU3N\Markus httpd-autoindex.conf
2021/06/08 03:31 PM 2 128 DESKTOP-4BTUU3N\Markus httpd-dav.conf
2021/06/08 03:31 PM 3 032 DESKTOP-4BTUU3N\Markus httpd-default.conf
2021/06/08 03:31 PM 1 220 DESKTOP-4BTUU3N\Markus httpd-info.conf
2021/06/08 03:31 PM 5 300 DESKTOP-4BTUU3N\Markus httpd-languages.conf
2021/06/08 03:31 PM 1 427 DESKTOP-4BTUU3N\Markus httpd-manual.conf
2021/06/08 03:31 PM 4 563 DESKTOP-4BTUU3N\Markus httpd-mpm.conf
2021/06/08 03:31 PM 2 382 DESKTOP-4BTUU3N\Markus httpd-multilang-errordoc.conf
2013/03/30 02:29 PM 276 DESKTOP-4BTUU3N\Markus httpd-proxy.conf
2021/06/08 03:31 PM 13 436 DESKTOP-4BTUU3N\Markus httpd-ssl.conf
2021/06/08 03:31 PM 952 DESKTOP-4BTUU3N\Markus httpd-userdir.conf
2021/06/08 03:31 PM 1 591 DESKTOP-4BTUU3N\Markus httpd-vhosts.conf
2021/06/08 03:31 PM 2 787 DESKTOP-4BTUU3N\Markus httpd-xampp.conf
2021/04/24 01:12 PM 3 251 DESKTOP-4BTUU3N\Markus proxy-html.conf
15 File(s) 45 825 bytes
Directory of G:\xampp\apache\conf\extra\bakforlivemovedtoG
2021/06/10 08:37 AM <DIR> DESKTOP-4BTUU3N\Markus .
2021/06/09 11:32 AM 11 022 DESKTOP-4BTUU3N\Markus httpd-ssl.conf
2021/06/09 01:27 PM 7 949 DESKTOP-4BTUU3N\Markus httpd-vhosts.conf
2 File(s) 18 971 bytes
Directory of G:\xampp\apache\conf\original
2004/11/20 11:16 PM 1 818 BUILTIN\Administrators charset.conv
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators extra
2021/04/24 01:12 PM 20 556 BUILTIN\Administrators httpd.conf
2019/07/05 03:26 PM 13 449 BUILTIN\Administrators magic
2017/09/29 07:10 PM 62 702 BUILTIN\Administrators mime.types
4 File(s) 98 525 bytes
Directory of G:\xampp\apache\conf\original\extra
2021/04/24 01:12 PM 2 958 BUILTIN\Administrators httpd-autoindex.conf
2021/04/24 01:12 PM 1 827 BUILTIN\Administrators httpd-dav.conf
2021/04/24 01:12 PM 3 032 BUILTIN\Administrators httpd-default.conf
2021/04/24 01:12 PM 1 155 BUILTIN\Administrators httpd-info.conf
2021/04/24 01:12 PM 5 219 BUILTIN\Administrators httpd-languages.conf
2021/04/24 01:12 PM 1 417 BUILTIN\Administrators httpd-manual.conf
2021/04/24 01:12 PM 4 563 BUILTIN\Administrators httpd-mpm.conf
2021/04/24 01:12 PM 2 250 BUILTIN\Administrators httpd-multilang-errordoc.conf
2021/04/24 01:12 PM 13 495 BUILTIN\Administrators httpd-ssl.conf
2021/04/24 01:12 PM 744 BUILTIN\Administrators httpd-userdir.conf
2021/04/24 01:12 PM 1 492 BUILTIN\Administrators httpd-vhosts.conf
12 File(s) 41 403 bytes
Directory of G:\xampp\apache\conf\ssl.crt
2013/03/30 02:29 PM 623 BUILTIN\Administrators server.crt
1 File(s) 623 bytes
Directory of G:\xampp\apache\conf\ssl.csr
2013/03/30 02:29 PM 578 BUILTIN\Administrators server.csr
1 File(s) 578 bytes
Directory of G:\xampp\apache\conf\ssl.key
2013/03/30 02:29 PM 887 BUILTIN\Administrators server.key
1 File(s) 887 bytes
Directory of G:\xampp\apache\error
2021/02/28 02:43 PM 5 752 BUILTIN\Administrators contact.html.var
2018/07/07 02:06 AM 11 965 BUILTIN\Administrators HTTP_BAD_GATEWAY.html.var
2018/07/07 02:06 AM 8 575 BUILTIN\Administrators HTTP_BAD_REQUEST.html.var
2018/07/07 02:06 AM 14 979 BUILTIN\Administrators HTTP_FORBIDDEN.html.var
2018/07/07 02:06 AM 17 105 BUILTIN\Administrators HTTP_GONE.html.var
2018/07/07 02:06 AM 17 468 BUILTIN\Administrators HTTP_INTERNAL_SERVER_ERROR.html.var
2018/07/07 02:06 AM 9 702 BUILTIN\Administrators HTTP_LENGTH_REQUIRED.html.var
2018/07/07 02:06 AM 8 641 BUILTIN\Administrators HTTP_METHOD_NOT_ALLOWED.html.var
2018/07/07 02:06 AM 17 404 BUILTIN\Administrators HTTP_NOT_FOUND.html.var
2018/07/07 02:06 AM 8 115 BUILTIN\Administrators HTTP_NOT_IMPLEMENTED.html.var
2018/07/07 02:06 AM 8 298 BUILTIN\Administrators HTTP_PRECONDITION_FAILED.html.var
2018/07/07 02:06 AM 9 963 BUILTIN\Administrators HTTP_REQUEST_ENTITY_TOO_LARGE.html.var
2018/07/07 02:06 AM 9 058 BUILTIN\Administrators HTTP_REQUEST_TIME_OUT.html.var
2018/07/07 02:06 AM 9 129 BUILTIN\Administrators HTTP_REQUEST_URI_TOO_LARGE.html.var
2018/07/07 02:06 AM 10 121 BUILTIN\Administrators HTTP_SERVICE_UNAVAILABLE.html.var
2018/07/07 02:06 AM 17 237 BUILTIN\Administrators HTTP_UNAUTHORIZED.html.var
2018/07/07 02:06 AM 8 085 BUILTIN\Administrators HTTP_UNSUPPORTED_MEDIA_TYPE.html.var
2018/07/07 02:06 AM 9 050 BUILTIN\Administrators HTTP_VARIANT_ALSO_VARIES.html.var
2018/07/07 02:06 AM 2 307 BUILTIN\Administrators README
2013/03/30 02:29 PM 19 553 BUILTIN\Administrators XAMPP_FORBIDDEN.html.var
20 File(s) 222 507 bytes
Directory of G:\xampp\apache\error\include
2007/07/31 11:49 PM 285 BUILTIN\Administrators bottom.html
2004/11/20 11:16 PM 11 BUILTIN\Administrators spacer.html
2011/10/11 01:06 AM 852 BUILTIN\Administrators top.html
3 File(s) 1 148 bytes
Directory of G:\xampp\apache\icons
2004/11/20 11:16 PM 246 BUILTIN\Administrators a.gif
2007/09/11 09:11 AM 306 BUILTIN\Administrators a.png
2004/11/20 11:16 PM 242 BUILTIN\Administrators alert.black.gif
2007/09/11 09:11 AM 293 BUILTIN\Administrators alert.black.png
2004/11/20 11:16 PM 247 BUILTIN\Administrators alert.red.gif
2007/09/11 09:11 AM 314 BUILTIN\Administrators alert.red.png
2013/05/04 04:52 PM 4 463 BUILTIN\Administrators apache_pb.gif
2012/10/03 04:35 PM 9 691 BUILTIN\Administrators apache_pb.png
2012/10/05 06:55 PM 272 334 BUILTIN\Administrators apache_pb.svg
2013/05/04 04:52 PM 4 234 BUILTIN\Administrators apache_pb2.gif
2012/10/03 04:35 PM 10 401 BUILTIN\Administrators apache_pb2.png
2004/11/20 11:16 PM 216 BUILTIN\Administrators back.gif
2007/09/11 09:11 AM 308 BUILTIN\Administrators back.png
2004/11/20 11:16 PM 233 BUILTIN\Administrators ball.gray.gif
2007/09/11 09:11 AM 298 BUILTIN\Administrators ball.gray.png
2004/11/20 11:16 PM 205 BUILTIN\Administrators ball.red.gif
2007/09/11 09:11 AM 289 BUILTIN\Administrators ball.red.png
2004/11/20 11:16 PM 246 BUILTIN\Administrators binary.gif
2007/09/11 09:11 AM 310 BUILTIN\Administrators binary.png
2004/11/20 11:16 PM 246 BUILTIN\Administrators binhex.gif
2007/09/11 09:11 AM 319 BUILTIN\Administrators binhex.png
2004/11/20 11:16 PM 148 BUILTIN\Administrators blank.gif
2007/09/11 09:11 AM 215 BUILTIN\Administrators blank.png
2004/11/20 11:16 PM 308 BUILTIN\Administrators bomb.gif
2007/09/11 09:11 AM 375 BUILTIN\Administrators bomb.png
2004/11/20 11:16 PM 251 BUILTIN\Administrators box1.gif
2007/08/28 02:53 PM 325 BUILTIN\Administrators box1.png
2004/11/20 11:16 PM 268 BUILTIN\Administrators box2.gif
2007/08/28 02:53 PM 336 BUILTIN\Administrators box2.png
2004/11/20 11:16 PM 247 BUILTIN\Administrators broken.gif
2007/09/11 09:11 AM 320 BUILTIN\Administrators broken.png
2004/11/20 11:16 PM 235 BUILTIN\Administrators burst.gif
2007/09/11 09:11 AM 341 BUILTIN\Administrators burst.png
2004/11/20 11:16 PM 242 BUILTIN\Administrators c.gif
2007/09/11 09:11 AM 299 BUILTIN\Administrators c.png
2004/11/20 11:16 PM 251 BUILTIN\Administrators comp.blue.gif
2007/08/28 02:53 PM 330 BUILTIN\Administrators comp.blue.png
2004/11/20 11:16 PM 246 BUILTIN\Administrators comp.gray.gif
2007/09/11 09:11 AM 318 BUILTIN\Administrators comp.gray.png
2004/11/20 11:16 PM 1 038 BUILTIN\Administrators compressed.gif
2007/08/28 02:53 PM 1 108 BUILTIN\Administrators compressed.png
2004/11/20 11:16 PM 214 BUILTIN\Administrators continued.gif
2007/09/11 09:11 AM 296 BUILTIN\Administrators continued.png
2004/11/20 11:16 PM 225 BUILTIN\Administrators dir.gif
2007/09/11 09:11 AM 295 BUILTIN\Administrators dir.png
2004/11/20 11:16 PM 167 BUILTIN\Administrators diskimg.gif
2007/08/28 02:53 PM 215 BUILTIN\Administrators diskimg.png
2004/11/20 11:16 PM 163 BUILTIN\Administrators down.gif
2007/09/11 09:11 AM 256 BUILTIN\Administrators down.png
2004/11/20 11:16 PM 238 BUILTIN\Administrators dvi.gif
2007/09/11 09:11 AM 305 BUILTIN\Administrators dvi.png
2004/11/20 11:16 PM 236 BUILTIN\Administrators f.gif
2007/09/11 09:11 AM 296 BUILTIN\Administrators f.png
2004/11/20 11:16 PM 225 BUILTIN\Administrators folder.gif
2004/11/20 11:16 PM 242 BUILTIN\Administrators folder.open.gif
2007/09/11 09:11 AM 332 BUILTIN\Administrators folder.open.png
2007/09/11 09:11 AM 295 BUILTIN\Administrators folder.png
2004/11/20 11:16 PM 243 BUILTIN\Administrators folder.sec.gif
2007/08/28 02:53 PM 313 BUILTIN\Administrators folder.sec.png
2004/11/20 11:16 PM 219 BUILTIN\Administrators forward.gif
2007/09/11 09:11 AM 308 BUILTIN\Administrators forward.png
2004/11/20 11:16 PM 221 BUILTIN\Administrators generic.gif
2007/09/11 09:11 AM 275 BUILTIN\Administrators generic.png
2004/11/20 11:16 PM 220 BUILTIN\Administrators generic.red.gif
2007/09/11 09:11 AM 283 BUILTIN\Administrators generic.red.png
2004/11/20 11:16 PM 249 BUILTIN\Administrators generic.sec.gif
2007/09/11 09:11 AM 295 BUILTIN\Administrators generic.sec.png
2004/11/20 11:16 PM 217 BUILTIN\Administrators hand.right.gif
2007/09/11 09:11 AM 311 BUILTIN\Administrators hand.right.png
2004/11/20 11:16 PM 223 BUILTIN\Administrators hand.up.gif
2007/09/11 09:11 AM 304 BUILTIN\Administrators hand.up.png
2004/11/20 11:16 PM 11 977 BUILTIN\Administrators icon.sheet.gif
2007/08/28 02:53 PM 9 018 BUILTIN\Administrators icon.sheet.png
2004/11/20 11:16 PM 274 BUILTIN\Administrators image1.gif
2007/09/11 09:11 AM 325 BUILTIN\Administrators image1.png
2004/11/20 11:16 PM 309 BUILTIN\Administrators image2.gif
2007/09/11 09:11 AM 371 BUILTIN\Administrators image2.png
2004/11/20 11:16 PM 286 BUILTIN\Administrators image3.gif
2007/09/11 09:11 AM 338 BUILTIN\Administrators image3.png
2004/11/20 11:16 PM 268 BUILTIN\Administrators index.gif
2007/09/11 09:11 AM 332 BUILTIN\Administrators index.png
2004/11/20 11:16 PM 276 BUILTIN\Administrators layout.gif
2007/09/11 09:11 AM 323 BUILTIN\Administrators layout.png
2004/11/20 11:16 PM 172 BUILTIN\Administrators left.gif
2007/09/11 09:11 AM 257 BUILTIN\Administrators left.png
2004/11/20 11:16 PM 249 BUILTIN\Administrators link.gif
2007/09/11 09:11 AM 314 BUILTIN\Administrators link.png
2004/11/20 11:16 PM 243 BUILTIN\Administrators movie.gif
2007/09/11 09:11 AM 272 BUILTIN\Administrators movie.png
2009/02/01 04:37 AM 1 047 BUILTIN\Administrators odf6odb.png
2009/02/01 04:37 AM 1 000 BUILTIN\Administrators odf6odc.png
2009/02/01 04:37 AM 1 047 BUILTIN\Administrators odf6odf.png
2009/02/01 04:37 AM 1 072 BUILTIN\Administrators odf6odg.png
2009/02/01 04:37 AM 1 067 BUILTIN\Administrators odf6odi.png
2009/02/01 04:37 AM 1 060 BUILTIN\Administrators odf6odm.png
2009/02/01 04:37 AM 978 BUILTIN\Administrators odf6odp.png
2009/02/01 04:37 AM 971 BUILTIN\Administrators odf6ods.png
2009/02/01 04:37 AM 983 BUILTIN\Administrators odf6odt.png
2009/02/01 04:37 AM 1 040 BUILTIN\Administrators odf6otc.png
2009/02/01 04:37 AM 1 082 BUILTIN\Administrators odf6otf.png
2009/02/01 04:37 AM 1 106 BUILTIN\Administrators odf6otg.png
2009/02/01 04:37 AM 1 062 BUILTIN\Administrators odf6oth.png
2009/02/01 04:37 AM 1 107 BUILTIN\Administrators odf6oti.png
2009/02/01 04:37 AM 1 017 BUILTIN\Administrators odf6otp.png
2009/02/01 04:37 AM 1 010 BUILTIN\Administrators odf6ots.png
2009/02/01 04:37 AM 1 022 BUILTIN\Administrators odf6ott.png
2004/11/20 11:16 PM 237 BUILTIN\Administrators p.gif
2007/09/11 09:11 AM 298 BUILTIN\Administrators p.png
2004/11/20 11:16 PM 251 BUILTIN\Administrators patch.gif
2007/09/11 09:11 AM 310 BUILTIN\Administrators patch.png
2004/11/20 11:16 PM 249 BUILTIN\Administrators pdf.gif
2007/09/11 09:11 AM 304 BUILTIN\Administrators pdf.png
2004/11/20 11:16 PM 188 BUILTIN\Administrators pie0.gif
2007/09/11 09:11 AM 259 BUILTIN\Administrators pie0.png
2004/11/20 11:16 PM 198 BUILTIN\Administrators pie1.gif
2007/09/11 09:11 AM 279 BUILTIN\Administrators pie1.png
2004/11/20 11:16 PM 198 BUILTIN\Administrators pie2.gif
2007/09/11 09:11 AM 272 BUILTIN\Administrators pie2.png
2004/11/20 11:16 PM 191 BUILTIN\Administrators pie3.gif
2007/09/11 09:11 AM 276 BUILTIN\Administrators pie3.png
2004/11/20 11:16 PM 193 BUILTIN\Administrators pie4.gif
2007/09/11 09:11 AM 258 BUILTIN\Administrators pie4.png
2004/11/20 11:16 PM 189 BUILTIN\Administrators pie5.gif
2007/09/11 09:11 AM 277 BUILTIN\Administrators pie5.png
2004/11/20 11:16 PM 186 BUILTIN\Administrators pie6.gif
2007/09/11 09:11 AM 273 BUILTIN\Administrators pie6.png
2004/11/20 11:16 PM 185 BUILTIN\Administrators pie7.gif
2007/09/11 09:11 AM 275 BUILTIN\Administrators pie7.png
2004/11/20 11:16 PM 173 BUILTIN\Administrators pie8.gif
2007/09/11 09:11 AM 259 BUILTIN\Administrators pie8.png
2004/11/20 11:16 PM 254 BUILTIN\Administrators portal.gif
2007/08/28 02:53 PM 319 BUILTIN\Administrators portal.png
2004/11/20 11:16 PM 244 BUILTIN\Administrators ps.gif
2007/09/11 09:11 AM 303 BUILTIN\Administrators ps.png
2004/11/20 11:16 PM 267 BUILTIN\Administrators quill.gif
2007/08/28 02:53 PM 329 BUILTIN\Administrators quill.png
2007/08/28 02:47 PM 5 274 BUILTIN\Administrators README
2007/08/28 02:47 PM 36 872 BUILTIN\Administrators README.html
2004/11/20 11:16 PM 172 BUILTIN\Administrators right.gif
2007/09/11 09:11 AM 254 BUILTIN\Administrators right.png
2004/11/20 11:16 PM 258 BUILTIN\Administrators screw1.gif
2007/09/11 09:11 AM 328 BUILTIN\Administrators screw1.png
2004/11/20 11:16 PM 263 BUILTIN\Administrators screw2.gif
2007/09/11 09:11 AM 333 BUILTIN\Administrators screw2.png
2004/11/20 11:16 PM 242 BUILTIN\Administrators script.gif
2007/09/11 09:11 AM 290 BUILTIN\Administrators script.png
2021/06/08 03:29 PM <DIR> BUILTIN\Administrators small
2004/11/20 11:16 PM 248 BUILTIN\Administrators sound1.gif
2007/08/28 02:53 PM 331 BUILTIN\Administrators sound1.png
2004/11/20 11:16 PM 221 BUILTIN\Administrators sound2.gif
2007/09/11 09:11 AM 315 BUILTIN\Administrators sound2.png
2004/11/20 11:16 PM 285 BUILTIN\Administrators sphere1.gif
2007/09/11 09:11 AM 347 BUILTIN\Administrators sphere1.png
2004/11/20 11:16 PM 264 BUILTIN\Administrators sphere2.gif
2007/08/28 02:53 PM 339 BUILTIN\Administrators sphere2.png
2009/02/01 04:37 AM 1 010 BUILTIN\Administrators svg.png
2004/11/20 11:16 PM 219 BUILTIN\Administrators tar.gif
2007/09/11 09:11 AM 261 BUILTIN\Administrators tar.png
2004/11/20 11:16 PM 251 BUILTIN\Administrators tex.gif
2007/09/11 09:11 AM 310 BUILTIN\Administrators tex.png
2004/11/20 11:16 PM 229 BUILTIN\Administrators text.gif
2007/09/11 09:11 AM 288 BUILTIN\Administrators text.png
2004/11/20 11:16 PM 242 BUILTIN\Administrators transfer.gif
2007/09/11 09:11 AM 334 BUILTIN\Administrators transfer.png
2004/11/20 11:16 PM 245 BUILTIN\Administrators unknown.gif
2007/09/11 09:11 AM 307 BUILTIN\Administrators unknown.png
2004/11/20 11:16 PM 164 BUILTIN\Administrators up.gif
2007/09/11 09:11 AM 255 BUILTIN\Administrators up.png
2004/11/20 11:16 PM 236 BUILTIN\Administrators uu.gif
2007/09/11 09:11 AM 296 BUILTIN\Administrators uu.png
2004/11/20 11:16 PM 236 BUILTIN\Administrators uuencoded.gif
2007/09/11 09:11 AM 296 BUILTIN\Administrators uuencoded.png
2004/11/20 11:16 PM 228 BUILTIN\Administrators world1.gif
2007/08/28 02:53 PM 332 BUILTIN\Administrators world1.png
2004/11/20 11:16 PM 261 BUILTIN\Administrators world2.gif
2007/09/11 09:11 AM 363 BUILTIN\Administrators world2.png
2009/02/01 04:37 AM 1 053 BUILTIN\Administrators xml.png
176 File(s) 425 144 bytes
Directory of G:\xampp\apache\icons\small
2004/11/20 11:16 PM 129 BUILTIN\Administrators back.gif
2007/08/28 02:53 PM 181 BUILTIN\Administrators back.png
2004/11/20 11:16 PM 134 BUILTIN\Administrators binary.gif
2007/08/28 02:53 PM 172 BUILTIN\Administrators binary.png
2004/11/20 11:16 PM 131 BUILTIN\Administrators binhex.gif
2007/08/28 02:53 PM 178 BUILTIN\Administrators binhex.png
2004/11/20 11:16 PM 55 BUILTIN\Administrators blank.gif
2007/08/28 02:53 PM 100 BUILTIN\Administrators blank.png
2004/11/20 11:16 PM 139 BUILTIN\Administrators broken.gif
2007/08/28 02:53 PM 184 BUILTIN\Administrators broken.png
2004/11/20 11:16 PM 128 BUILTIN\Administrators burst.gif
2007/08/28 02:53 PM 210 BUILTIN\Administrators burst.png
2004/11/20 11:16 PM 130 BUILTIN\Administrators comp1.gif
2007/08/28 02:53 PM 216 BUILTIN\Administrators comp1.png
2004/11/20 11:16 PM 131 BUILTIN\Administrators comp2.gif
2007/08/28 02:53 PM 215 BUILTIN\Administrators comp2.png
2004/11/20 11:16 PM 128 BUILTIN\Administrators compressed.gif
2007/08/28 02:53 PM 212 BUILTIN\Administrators compressed.png
2004/11/20 11:16 PM 114 BUILTIN\Administrators continued.gif
2007/08/28 02:53 PM 163 BUILTIN\Administrators continued.png
2004/11/20 11:16 PM 191 BUILTIN\Administrators doc.gif
2007/08/28 02:53 PM 222 BUILTIN\Administrators doc.png
2007/07/31 11:16 PM 132 BUILTIN\Administrators folder.gif
2007/08/28 02:53 PM 196 BUILTIN\Administrators folder.png
2007/07/31 11:17 PM 122 BUILTIN\Administrators folder2.gif
2007/08/28 02:53 PM 180 BUILTIN\Administrators folder2.png
2004/11/20 11:16 PM 125 BUILTIN\Administrators forward.gif
2007/08/28 02:53 PM 174 BUILTIN\Administrators forward.png
2004/11/20 11:16 PM 116 BUILTIN\Administrators generic.gif
2007/08/28 02:53 PM 149 BUILTIN\Administrators generic.png
2004/11/20 11:16 PM 127 BUILTIN\Administrators generic2.gif
2007/08/28 02:53 PM 179 BUILTIN\Administrators generic2.png
2004/11/20 11:16 PM 113 BUILTIN\Administrators generic3.gif
2007/08/28 02:53 PM 171 BUILTIN\Administrators generic3.png
2004/11/20 11:16 PM 126 BUILTIN\Administrators image.gif
2007/08/28 02:53 PM 197 BUILTIN\Administrators image.png
2004/11/20 11:16 PM 138 BUILTIN\Administrators image2.gif
2007/08/28 02:53 PM 203 BUILTIN\Administrators image2.png
2004/11/20 11:16 PM 145 BUILTIN\Administrators index.gif
2007/08/28 02:53 PM 225 BUILTIN\Administrators index.png
2004/11/20 11:16 PM 187 BUILTIN\Administrators key.gif
2007/08/28 02:53 PM 210 BUILTIN\Administrators key.png
2004/11/20 11:16 PM 134 BUILTIN\Administrators movie.gif
2007/08/28 02:53 PM 159 BUILTIN\Administrators movie.png
2004/11/20 11:16 PM 182 BUILTIN\Administrators patch.gif
2007/08/28 02:53 PM 211 BUILTIN\Administrators patch.png
2004/11/20 11:16 PM 184 BUILTIN\Administrators ps.gif
2007/08/28 02:53 PM 217 BUILTIN\Administrators ps.png
2004/11/20 11:16 PM 3 811 BUILTIN\Administrators rainbow.gif
2007/08/28 02:53 PM 2 427 BUILTIN\Administrators rainbow.png
2004/11/20 11:16 PM 130 BUILTIN\Administrators sound.gif
2007/08/28 02:53 PM 197 BUILTIN\Administrators sound.png
2004/11/20 11:16 PM 119 BUILTIN\Administrators sound2.gif
2007/08/28 02:53 PM 171 BUILTIN\Administrators sound2.png
2004/11/20 11:16 PM 132 BUILTIN\Administrators tar.gif
2007/08/28 02:53 PM 173 BUILTIN\Administrators tar.png
2004/11/20 11:16 PM 128 BUILTIN\Administrators text.gif
2007/08/28 02:53 PM 163 BUILTIN\Administrators text.png
2004/11/20 11:16 PM 124 BUILTIN\Administrators transfer.gif
2007/08/28 02:53 PM 211 BUILTIN\Administrators transfer.png
2004/11/20 11:16 PM 131 BUILTIN\Administrators unknown.gif
2007/08/28 02:53 PM 172 BUILTIN\Administrators unknown.png
2004/11/20 11:16 PM 125 BUILTIN\Administrators uu.gif
2007/08/28 02:53 PM 166 BUILTIN\Administrators uu.png
64 File(s) 16 145 bytes
markjc
#15
Here is 3b Bottom half of it.
Directory of G:\xampp\apache\include
2012/04/05 12:11 AM 16 312 BUILTIN\Administrators apache_noprobes.h
2020/08/02 04:32 PM 18 734 BUILTIN\Administrators apr.h
2018/08/25 05:48 PM 6 396 BUILTIN\Administrators apr_allocator.h
2007/01/15 10:00 PM 5 178 BUILTIN\Administrators apr_anylock.h
2018/09/17 10:20 PM 6 395 BUILTIN\Administrators apr_atomic.h
2012/12/23 01:24 AM 3 957 BUILTIN\Administrators apr_base64.h
2017/04/03 03:26 PM 66 152 BUILTIN\Administrators apr_buckets.h
2017/06/14 12:28 AM 20 664 BUILTIN\Administrators apr_crypto.h
2016/12/03 11:49 PM 11 690 BUILTIN\Administrators apr_cstr.h
2007/01/15 10:00 PM 3 660 BUILTIN\Administrators apr_date.h
2017/04/02 09:57 PM 24 458 BUILTIN\Administrators apr_dbd.h
2008/11/21 09:20 AM 8 826 BUILTIN\Administrators apr_dbm.h
2006/08/03 02:55 PM 2 794 BUILTIN\Administrators apr_dso.h
2018/06/28 12:26 AM 25 113 BUILTIN\Administrators apr_encode.h
2009/09/26 12:07 AM 2 172 BUILTIN\Administrators apr_env.h
2016/03/03 07:11 PM 56 403 BUILTIN\Administrators apr_errno.h
2018/08/26 02:24 PM 18 077 BUILTIN\Administrators apr_escape.h
2020/08/02 04:32 PM 1 436 BUILTIN\Administrators apr_escape_test_char.h
2018/08/26 02:01 PM 18 012 BUILTIN\Administrators apr_file_info.h
2017/03/30 11:53 PM 44 142 BUILTIN\Administrators apr_file_io.h
2014/04/15 05:55 PM 6 382 BUILTIN\Administrators apr_fnmatch.h
2018/08/26 02:01 PM 7 538 BUILTIN\Administrators apr_general.h
2006/08/03 02:55 PM 6 140 BUILTIN\Administrators apr_getopt.h
2017/04/08 01:20 AM 7 556 BUILTIN\Administrators apr_global_mutex.h
2016/03/25 01:28 PM 10 609 BUILTIN\Administrators apr_hash.h
2013/10/03 05:32 PM 13 018 BUILTIN\Administrators apr_hooks.h
2013/10/03 05:29 PM 2 190 BUILTIN\Administrators apr_inherit.h
2020/07/27 01:38 PM 5 902 BUILTIN\Administrators apr_ldap.h
2009/02/19 11:04 AM 5 945 BUILTIN\Administrators apr_ldap_init.h
2009/02/19 11:04 AM 8 858 BUILTIN\Administrators apr_ldap_option.h
2009/02/19 11:04 AM 3 266 BUILTIN\Administrators apr_ldap_rebind.h
2009/02/19 11:04 AM 3 919 BUILTIN\Administrators apr_ldap_url.h
2014/01/16 11:26 PM 8 671 BUILTIN\Administrators apr_lib.h
2007/01/15 10:00 PM 4 660 BUILTIN\Administrators apr_md4.h
2012/07/06 03:41 PM 6 526 BUILTIN\Administrators apr_md5.h
2010/11/26 05:39 PM 17 668 BUILTIN\Administrators apr_memcache.h
2013/10/03 05:29 PM 5 304 BUILTIN\Administrators apr_mmap.h
2017/12/12 11:05 AM 37 824 BUILTIN\Administrators apr_network_io.h
2007/01/15 10:00 PM 2 872 BUILTIN\Administrators apr_optional.h
2013/10/03 05:32 PM 3 989 BUILTIN\Administrators apr_optional_hooks.h
2014/04/28 04:08 PM 1 974 BUILTIN\Administrators apr_perms_set.h
2016/03/25 04:19 AM 21 545 BUILTIN\Administrators apr_poll.h
2013/10/03 05:29 PM 32 495 BUILTIN\Administrators apr_pools.h
2018/08/26 02:01 PM 21 052 BUILTIN\Administrators apr_portable.h
2017/04/08 01:20 AM 7 204 BUILTIN\Administrators apr_proc_mutex.h
2013/10/03 05:32 PM 4 218 BUILTIN\Administrators apr_queue.h
2007/07/21 06:16 AM 5 189 BUILTIN\Administrators apr_random.h
2017/06/09 06:31 PM 16 454 BUILTIN\Administrators apr_redis.h
2013/10/03 05:32 PM 7 359 BUILTIN\Administrators apr_reslist.h
2011/02/26 07:58 PM 19 528 BUILTIN\Administrators apr_ring.h
2007/01/15 10:00 PM 4 915 BUILTIN\Administrators apr_rmm.h
2007/10/23 01:59 PM 6 289 BUILTIN\Administrators apr_sdbm.h
2007/01/15 10:00 PM 4 005 BUILTIN\Administrators apr_sha1.h
2014/04/28 05:15 PM 9 712 BUILTIN\Administrators apr_shm.h
2007/08/05 07:48 PM 2 870 BUILTIN\Administrators apr_signal.h
2017/06/15 12:00 AM 6 306 BUILTIN\Administrators apr_siphash.h
2018/08/25 05:48 PM 14 914 BUILTIN\Administrators apr_skiplist.h
2018/08/26 02:01 PM 15 277 BUILTIN\Administrators apr_strings.h
2007/01/15 10:00 PM 2 758 BUILTIN\Administrators apr_strmatch.h
2006/08/03 02:55 PM 1 691 BUILTIN\Administrators apr_support.h
2018/08/26 02:01 PM 19 860 BUILTIN\Administrators apr_tables.h
2007/06/29 09:20 PM 5 664 BUILTIN\Administrators apr_thread_cond.h
2017/04/08 01:20 AM 4 621 BUILTIN\Administrators apr_thread_mutex.h
2008/05/07 11:45 PM 11 403 BUILTIN\Administrators apr_thread_pool.h
2019/03/08 05:52 PM 36 973 BUILTIN\Administrators apr_thread_proc.h
2006/08/03 02:55 PM 4 895 BUILTIN\Administrators apr_thread_rwlock.h
2016/03/05 04:40 AM 7 800 BUILTIN\Administrators apr_time.h
2009/01/07 11:39 PM 6 767 BUILTIN\Administrators apr_uri.h
2013/10/03 05:29 PM 5 468 BUILTIN\Administrators apr_user.h
2007/01/15 10:00 PM 2 178 BUILTIN\Administrators apr_uuid.h
2019/04/01 09:45 PM 5 575 BUILTIN\Administrators apr_version.h
2012/08/15 12:48 AM 3 082 BUILTIN\Administrators apr_want.h
2007/01/15 10:00 PM 6 571 BUILTIN\Administrators apr_xlate.h
2016/06/14 01:57 AM 12 844 BUILTIN\Administrators apr_xml.h
2020/07/27 01:38 PM 4 878 BUILTIN\Administrators apu.h
2009/01/07 11:35 PM 5 617 BUILTIN\Administrators apu_errno.h
2017/10/18 06:36 PM 4 438 BUILTIN\Administrators apu_version.h
2020/07/27 01:38 PM 1 591 BUILTIN\Administrators apu_want.h
2006/07/12 12:33 AM 1 105 BUILTIN\Administrators ap_compat.h
2012/08/15 03:59 AM 6 812 BUILTIN\Administrators ap_config.h
2020/07/27 01:37 PM 1 241 BUILTIN\Administrators ap_config_layout.h
2020/02/21 03:33 AM 14 429 BUILTIN\Administrators ap_expr.h
2011/09/23 10:08 PM 6 150 BUILTIN\Administrators ap_hooks.h
2016/05/30 11:26 PM 5 992 BUILTIN\Administrators ap_listen.h
2021/03/09 07:28 PM 37 333 BUILTIN\Administrators ap_mmn.h
2020/04/23 04:32 PM 10 933 BUILTIN\Administrators ap_mpm.h
2012/07/03 11:29 PM 3 637 BUILTIN\Administrators ap_provider.h
2020/04/23 04:32 PM 11 175 BUILTIN\Administrators ap_regex.h
2011/09/23 05:38 PM 9 402 BUILTIN\Administrators ap_regkey.h
2021/04/22 10:43 AM 3 227 BUILTIN\Administrators ap_release.h
2013/11/17 11:10 PM 7 434 BUILTIN\Administrators ap_slotmem.h
2012/02/11 01:47 AM 9 617 BUILTIN\Administrators ap_socache.h
2013/05/29 12:30 AM 2 073 BUILTIN\Administrators cache_common.h
2021/03/25 03:29 AM 42 551 BUILTIN\Administrators expat.h
2014/06/17 04:06 PM 1 655 BUILTIN\Administrators heartbeat.h
2021/03/09 07:28 PM 93 608 BUILTIN\Administrators httpd.h
2020/04/23 04:32 PM 58 766 BUILTIN\Administrators http_config.h
2016/02/25 01:27 PM 6 550 BUILTIN\Administrators http_connection.h
2021/04/18 11:40 PM 36 871 BUILTIN\Administrators http_core.h
2016/08/25 04:48 PM 37 707 BUILTIN\Administrators http_log.h
2012/03/26 02:24 AM 3 333 BUILTIN\Administrators http_main.h
2021/03/09 07:28 PM 41 950 BUILTIN\Administrators http_protocol.h
2020/04/23 04:32 PM 26 480 BUILTIN\Administrators http_request.h
2011/09/23 10:08 PM 4 145 BUILTIN\Administrators http_vhost.h
2020/02/21 03:33 AM 4 664 BUILTIN\Administrators mod_auth.h
2011/12/03 09:02 PM 7 448 BUILTIN\Administrators mod_cache.h
2011/09/23 05:38 PM 2 563 BUILTIN\Administrators mod_cgi.h
2012/09/24 01:49 PM 3 509 BUILTIN\Administrators mod_core.h
2019/07/02 01:08 PM 97 579 BUILTIN\Administrators mod_dav.h
2011/09/23 05:38 PM 4 277 BUILTIN\Administrators mod_dbd.h
2020/02/21 03:33 AM 3 789 BUILTIN\Administrators mod_http2.h
2011/09/23 05:38 PM 4 104 BUILTIN\Administrators mod_include.h
2011/09/23 05:38 PM 2 559 BUILTIN\Administrators mod_log_config.h
2021/01/17 07:41 PM 62 647 BUILTIN\Administrators mod_proxy.h
2011/02/18 09:40 PM 1 692 BUILTIN\Administrators mod_request.h
2014/01/23 05:33 PM 1 439 BUILTIN\Administrators mod_rewrite.h
2011/11/30 01:21 PM 1 264 BUILTIN\Administrators mod_so.h
2019/07/30 03:23 PM 5 109 BUILTIN\Administrators mod_ssl.h
2019/07/30 03:23 PM 4 900 BUILTIN\Administrators mod_ssl_openssl.h
2006/07/12 12:33 AM 2 505 BUILTIN\Administrators mod_status.h
2014/09/05 06:19 PM 7 731 BUILTIN\Administrators mod_watchdog.h
2018/08/15 12:56 AM 17 516 BUILTIN\Administrators mpm_common.h
2021/04/21 05:10 AM 4 604 BUILTIN\Administrators os.h
2020/02/21 03:33 AM 10 222 BUILTIN\Administrators scoreboard.h
2011/09/23 05:38 PM 3 251 BUILTIN\Administrators util_cfgtree.h
2014/11/01 12:19 PM 2 339 BUILTIN\Administrators util_charset.h
2012/01/09 04:18 PM 5 107 BUILTIN\Administrators util_cookies.h
2014/11/01 12:19 PM 2 844 BUILTIN\Administrators util_ebcdic.h
2020/02/21 03:33 AM 10 264 BUILTIN\Administrators util_fcgi.h
2013/04/15 04:37 PM 27 098 BUILTIN\Administrators util_filter.h
2020/02/21 03:33 AM 18 802 BUILTIN\Administrators util_ldap.h
2014/07/17 02:11 AM 2 239 BUILTIN\Administrators util_md5.h
2011/10/09 10:35 PM 9 515 BUILTIN\Administrators util_mutex.h
2012/01/09 04:18 PM 10 035 BUILTIN\Administrators util_script.h
2011/09/23 05:38 PM 4 204 BUILTIN\Administrators util_time.h
2014/07/19 09:22 PM 8 483 BUILTIN\Administrators util_varbuf.h
2014/07/19 09:22 PM 1 392 BUILTIN\Administrators util_xml.h
2017/01/01 10:37 AM 16 832 BUILTIN\Administrators zconf.h
2017/01/15 08:29 PM 98 151 BUILTIN\Administrators zlib.h
139 File(s) 1 840 241 bytes
Directory of G:\xampp\apache\lib
2021/04/24 01:09 PM 1 726 956 BUILTIN\Administrators apr-1.lib
2021/04/24 01:09 PM 1 119 958 BUILTIN\Administrators aprutil-1.lib
2021/04/24 01:08 PM 73 141 BUILTIN\Administrators libapr-1.exp
2021/04/24 12:53 PM 121 362 BUILTIN\Administrators libapr-1.lib
2021/04/24 01:08 PM 4 000 BUILTIN\Administrators libapriconv-1.exp
2021/04/24 12:53 PM 7 404 BUILTIN\Administrators libapriconv-1.lib
2021/04/24 01:08 PM 45 672 BUILTIN\Administrators libaprutil-1.exp
2021/04/24 12:53 PM 76 656 BUILTIN\Administrators libaprutil-1.lib
2021/04/24 01:08 PM 99 466 BUILTIN\Administrators libhttpd.exp
2021/04/24 12:54 PM 162 604 BUILTIN\Administrators libhttpd.lib
2021/04/24 01:08 PM 11 854 BUILTIN\Administrators mod_dav.exp
2021/04/24 12:54 PM 19 954 BUILTIN\Administrators mod_dav.lib
2021/04/24 12:54 PM 23 878 BUILTIN\Administrators mod_proxy.lib
2021/04/24 01:08 PM 760 342 BUILTIN\Administrators xml.lib
2019/04/05 02:30 PM 345 936 BUILTIN\Administrators zlib.lib
15 File(s) 4 599 183 bytes
Directory of G:\xampp\apache\logs
2021/08/05 04:32 AM <DIR> BUILTIN\Administrators .
2021/08/05 04:32 AM <DIR> BUILTIN\Administrators ..
2021/08/05 04:19 AM 606 088 BUILTIN\Administrators access.log
2021/08/05 04:18 AM 246 114 BUILTIN\Administrators ancaccess.log
2021/06/08 04:39 PM 0 BUILTIN\Administrators ancerror.log
2021/08/05 04:32 AM 665 943 BUILTIN\Administrators error.log
2021/08/05 04:32 AM 7 BUILTIN\Administrators httpd.pid
2021/08/05 04:19 AM 44 770 BUILTIN\Administrators injusticeaccess.log
2021/06/09 01:24 PM 0 BUILTIN\Administrators injusticeerror.log
2021/04/24 01:12 PM 3 146 BUILTIN\Administrators install.log
2021/08/05 04:31 AM 3 618 482 BUILTIN\Administrators pmway_access.log
2021/08/04 04:01 PM 75 090 BUILTIN\Administrators pmway_error.log
2021/06/08 03:30 PM 0 BUILTIN\Administrators ssl_request.log
11 File(s) 5 259 640 bytes
Directory of G:\xampp\apache\manual
2021/04/24 12:34 PM 41 BUILTIN\Administrators docs.txt
1 File(s) 41 bytes
Directory of G:\xampp\apache\modules
2021/04/24 01:10 PM 16 896 BUILTIN\Administrators mod_access_compat.so
2021/04/24 01:10 PM 14 848 BUILTIN\Administrators mod_actions.so
2021/04/24 01:10 PM 20 992 BUILTIN\Administrators mod_alias.so
2021/04/24 01:10 PM 13 312 BUILTIN\Administrators mod_allowmethods.so
2021/04/24 01:10 PM 13 312 BUILTIN\Administrators mod_asis.so
2021/04/24 01:10 PM 30 208 BUILTIN\Administrators mod_authnz_fcgi.so
2021/04/24 01:10 PM 43 520 BUILTIN\Administrators mod_authnz_ldap.so
2021/04/24 01:10 PM 13 312 BUILTIN\Administrators mod_authn_anon.so
2021/04/24 01:10 PM 16 384 BUILTIN\Administrators mod_authn_core.so
2021/04/24 01:10 PM 16 896 BUILTIN\Administrators mod_authn_dbd.so
2021/04/24 01:10 PM 13 312 BUILTIN\Administrators mod_authn_dbm.so
2021/04/24 01:10 PM 15 360 BUILTIN\Administrators mod_authn_file.so
2021/04/24 01:10 PM 20 480 BUILTIN\Administrators mod_authn_socache.so
2021/04/24 01:10 PM 23 552 BUILTIN\Administrators mod_authz_core.so
2021/04/24 01:10 PM 18 432 BUILTIN\Administrators mod_authz_dbd.so
2021/04/24 01:10 PM 16 896 BUILTIN\Administrators mod_authz_dbm.so
2021/04/24 01:10 PM 16 896 BUILTIN\Administrators mod_authz_groupfile.so
2021/04/24 01:10 PM 16 896 BUILTIN\Administrators mod_authz_host.so
2021/04/24 01:10 PM 14 336 BUILTIN\Administrators mod_authz_owner.so
2021/04/24 01:10 PM 13 312 BUILTIN\Administrators mod_authz_user.so
2021/04/24 01:09 PM 17 920 BUILTIN\Administrators mod_auth_basic.so
2021/04/24 01:10 PM 34 304 BUILTIN\Administrators mod_auth_digest.so
2021/04/24 01:10 PM 29 184 BUILTIN\Administrators mod_auth_form.so
2021/04/24 01:10 PM 38 400 BUILTIN\Administrators mod_autoindex.so
2021/04/24 01:10 PM 3 209 216 BUILTIN\Administrators mod_brotli.so
2021/04/24 01:10 PM 14 336 BUILTIN\Administrators mod_buffer.so
2021/04/24 01:08 PM 58 880 BUILTIN\Administrators mod_cache.so
2021/04/24 01:10 PM 31 744 BUILTIN\Administrators mod_cache_disk.so
2021/04/24 01:10 PM 30 720 BUILTIN\Administrators mod_cache_socache.so
2021/04/24 01:10 PM 16 896 BUILTIN\Administrators mod_cern_meta.so
2021/04/24 01:10 PM 26 112 BUILTIN\Administrators mod_cgi.so
2021/04/24 01:10 PM 23 040 BUILTIN\Administrators mod_charset_lite.so
2021/04/24 01:10 PM 15 360 BUILTIN\Administrators mod_data.so
2021/04/24 01:08 PM 94 720 BUILTIN\Administrators mod_dav.so
2021/04/24 01:10 PM 50 688 BUILTIN\Administrators mod_dav_fs.so
2021/04/24 01:10 PM 23 552 BUILTIN\Administrators mod_dav_lock.so
2021/04/24 01:08 PM 22 528 BUILTIN\Administrators mod_dbd.so
2021/04/24 01:10 PM 31 744 BUILTIN\Administrators mod_deflate.so
2021/04/24 01:10 PM 16 384 BUILTIN\Administrators mod_dir.so
2021/04/24 01:10 PM 15 360 BUILTIN\Administrators mod_dumpio.so
2021/04/24 01:10 PM 13 824 BUILTIN\Administrators mod_env.so
2021/04/24 01:10 PM 16 384 BUILTIN\Administrators mod_expires.so
2021/04/24 01:10 PM 24 064 BUILTIN\Administrators mod_ext_filter.so
2021/04/24 01:10 PM 16 896 BUILTIN\Administrators mod_file_cache.so
2021/04/24 01:10 PM 20 480 BUILTIN\Administrators mod_filter.so
2021/04/24 01:10 PM 23 040 BUILTIN\Administrators mod_headers.so
2021/04/24 01:11 PM 15 872 BUILTIN\Administrators mod_heartbeat.so
2021/04/24 01:11 PM 26 112 BUILTIN\Administrators mod_heartmonitor.so
2021/04/24 01:09 PM 189 440 BUILTIN\Administrators mod_http2.so
2021/04/24 01:11 PM 16 384 BUILTIN\Administrators mod_ident.so
2021/04/24 01:11 PM 20 992 BUILTIN\Administrators mod_imagemap.so
2021/04/24 01:11 PM 48 128 BUILTIN\Administrators mod_include.so
2021/04/24 01:11 PM 30 720 BUILTIN\Administrators mod_info.so
2021/04/24 01:11 PM 29 696 BUILTIN\Administrators mod_isapi.so
2021/04/24 01:11 PM 12 800 BUILTIN\Administrators mod_lbmethod_bybusyness.so
2021/04/24 01:11 PM 12 800 BUILTIN\Administrators mod_lbmethod_byrequests.so
2021/04/24 01:10 PM 12 800 BUILTIN\Administrators mod_lbmethod_bytraffic.so
2021/04/24 01:11 PM 18 944 BUILTIN\Administrators mod_lbmethod_heartbeat.so
2021/04/24 01:08 PM 65 024 BUILTIN\Administrators mod_ldap.so
2021/04/24 01:11 PM 14 336 BUILTIN\Administrators mod_logio.so
2021/04/24 01:11 PM 31 744 BUILTIN\Administrators mod_log_config.so
2021/04/24 01:11 PM 16 384 BUILTIN\Administrators mod_log_debug.so
2021/04/24 01:11 PM 16 384 BUILTIN\Administrators mod_log_forensic.so
2021/04/24 01:11 PM 98 816 BUILTIN\Administrators mod_lua.so
2021/04/24 01:11 PM 23 040 BUILTIN\Administrators mod_macro.so
2021/04/24 01:10 PM 228 352 BUILTIN\Administrators mod_md.so
2021/04/24 01:11 PM 23 040 BUILTIN\Administrators mod_mime.so
2021/04/24 01:11 PM 29 696 BUILTIN\Administrators mod_mime_magic.so
2021/04/24 01:11 PM 36 352 BUILTIN\Administrators mod_negotiation.so
2021/04/24 01:08 PM 118 272 BUILTIN\Administrators mod_proxy.so
2021/04/24 01:11 PM 42 496 BUILTIN\Administrators mod_proxy_ajp.so
2021/04/24 01:08 PM 50 176 BUILTIN\Administrators mod_proxy_balancer.so
2021/04/24 01:11 PM 18 432 BUILTIN\Administrators mod_proxy_connect.so
2021/04/24 01:11 PM 14 336 BUILTIN\Administrators mod_proxy_express.so
2021/04/24 01:11 PM 29 184 BUILTIN\Administrators mod_proxy_fcgi.so
2021/04/24 01:11 PM 36 864 BUILTIN\Administrators mod_proxy_ftp.so
2021/04/24 01:11 PM 32 768 BUILTIN\Administrators mod_proxy_hcheck.so
2021/04/24 01:11 PM 32 256 BUILTIN\Administrators mod_proxy_html.so
2021/04/24 01:11 PM 34 816 BUILTIN\Administrators mod_proxy_http.so
2021/04/24 01:11 PM 50 688 BUILTIN\Administrators mod_proxy_http2.so
2021/04/24 01:11 PM 20 480 BUILTIN\Administrators mod_proxy_scgi.so
2021/04/24 01:11 PM 19 968 BUILTIN\Administrators mod_proxy_uwsgi.so
2021/04/24 01:11 PM 19 456 BUILTIN\Administrators mod_proxy_wstunnel.so
2021/04/24 01:11 PM 15 360 BUILTIN\Administrators mod_ratelimit.so
2021/04/24 01:11 PM 14 848 BUILTIN\Administrators mod_reflector.so
2021/04/24 01:11 PM 28 160 BUILTIN\Administrators mod_remoteip.so
2021/04/24 01:11 PM 17 408 BUILTIN\Administrators mod_reqtimeout.so
2021/04/24 01:11 PM 16 384 BUILTIN\Administrators mod_request.so
2021/04/24 01:11 PM 64 000 BUILTIN\Administrators mod_rewrite.so
2021/04/24 01:11 PM 37 376 BUILTIN\Administrators mod_sed.so
2021/04/24 01:09 PM 22 528 BUILTIN\Administrators mod_session.so
2021/04/24 01:11 PM 14 848 BUILTIN\Administrators mod_session_cookie.so
2021/04/24 01:11 PM 23 040 BUILTIN\Administrators mod_session_crypto.so
2021/04/24 01:11 PM 20 480 BUILTIN\Administrators mod_session_dbd.so
2021/04/24 01:11 PM 18 432 BUILTIN\Administrators mod_setenvif.so
2021/04/24 01:11 PM 13 824 BUILTIN\Administrators mod_slotmem_plain.so
2021/04/24 01:09 PM 19 968 BUILTIN\Administrators mod_slotmem_shm.so
2021/04/24 01:11 PM 18 944 BUILTIN\Administrators mod_socache_dbm.so
2021/04/24 01:11 PM 19 456 BUILTIN\Administrators mod_socache_memcache.so
2021/04/24 01:11 PM 19 456 BUILTIN\Administrators mod_socache_redis.so
2021/04/24 01:11 PM 24 576 BUILTIN\Administrators mod_socache_shmcb.so
2021/04/24 01:11 PM 16 896 BUILTIN\Administrators mod_speling.so
2021/04/24 01:12 PM 186 880 BUILTIN\Administrators mod_ssl.so
2021/04/24 01:12 PM 27 136 BUILTIN\Administrators mod_status.so
2021/04/24 01:12 PM 20 480 BUILTIN\Administrators mod_substitute.so
2021/04/24 01:12 PM 14 848 BUILTIN\Administrators mod_unique_id.so
2021/04/24 01:12 PM 13 824 BUILTIN\Administrators mod_userdir.so
2021/04/24 01:09 PM 18 944 BUILTIN\Administrators mod_usertrack.so
2021/04/24 01:09 PM 15 360 BUILTIN\Administrators mod_version.so
2021/04/24 01:09 PM 16 896 BUILTIN\Administrators mod_vhost_alias.so
2021/04/24 01:09 PM 22 528 BUILTIN\Administrators mod_watchdog.so
2021/04/24 01:09 PM 23 552 BUILTIN\Administrators mod_xml2enc.so
112 File(s) 6 609 408 bytes
Directory of G:\xampp\apache\scripts
2021/06/08 03:29 PM 434 BUILTIN\Administrators ctl.bat
1 File(s) 434 bytes
Total Files Listed:
845 File(s) 70 535 177 bytes
74 Dir(s) 25 879 674 880 bytes free
So not looking too bad.
There's certainly a lot more contained in the xampp Apache directory structure than in a typical Linux Apache install.
Let's see the output of this command from an administrative command prompt:
G:\xampp\apache\bin\httpd.exe -S
Again, please put 3 backticks above and below the output, like this:
output
markjc
August 5, 2021, 5:09am
#17
Hi there griffin.
here is the output you are looking for:
C:\WINDOWS\system32>G:\xampp\apache\bin\httpd.exe -S
VirtualHost configuration:
*:8080 is a NameVirtualHost
default server pmway.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:45)
port 8080 namevhost pmway.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:45)
port 8080 namevhost upguitarhill.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:115)
port 8080 namevhost anc.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:176)
port 8080 namevhost injustice.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:235)
*:80 is a NameVirtualHost
default server pmway.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:63)
port 80 namevhost pmway.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:63)
port 80 namevhost upguitarhill.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:131)
port 80 namevhost anc.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:192)
port 80 namevhost injustice.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:251)
*:443 is a NameVirtualHost
default server pmway.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:86)
port 443 namevhost pmway.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:86)
port 443 namevhost upguitarhill.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:156)
port 443 namevhost anc.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:216)
port 443 namevhost injustice.hopto.org (G:/xampp/apache/conf/extra/httpd-vhosts.conf:275)
port 443 namevhost localhost (G:/xampp/apache/conf/extra/httpd-ssl.conf:193)
port 443 namevhost localhost (G:/xampp/apache/conf/extra/httpd-ssl.conf:212)
port 443 namevhost localhost (G:/xampp/apache/conf/extra/httpd-ssl.conf:228)
port 443 namevhost localhost (G:/xampp/apache/conf/extra/httpd-ssl.conf:246)
ServerRoot: "G:/xampp/apache"
Main DocumentRoot: "G:/xampp/htdocs"
Main ErrorLog: "G:/xampp/apache/logs/error.log"
Mutex proxy: using_defaults
Mutex default: dir="G:/xampp/apache/logs/" mechanism=default
PidFile: "G:/xampp/apache/logs/httpd.pid"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
Define: SRVROOT=G:/xampp/apache
Perfect.
Please upload these files:
G:\xampp\apache\conf\extra\httpd-vhosts.conf
G:\xampp\apache\conf\extra\httpd-ssl.conf
You will likely need to change the file extensions from conf
to txt
in order to upload the files.
markjc
August 5, 2021, 7:27am
#19
Hi griffin.
Thank you again.
httpd-vhosts.txt (9.3 KB)
httpd-ssl.txt (11.1 KB)
I'll look into these as soon as I can.
