Continuing the discussion from Can’t obtain certificate for *.tk domain:
Hello http://bhemapp.tk this is my .tk site. Can I get free ssl.
No, that poster is not me.
You didn't provide us any information.
What OS are you using? Do you have root access? Are you being externally hosted? Do you need to go through a portal or use a panel?
We need to know your situation before we can help you. You should read the Getting Started page for some context.
Yes, you can.
