Try:
openssl s_client -connect EXAMPLE.COM:443 -servername EXAMPLE.COM
[feel free to check all other ports too - not just 443]
@rg305 I am Old ad use Androids.
That is a very weird chain to be serving today.
Please show file:
/etc/letsencrypt/live/hub1.cet.cloud/fullchain.pem
This is causing some very serious damage since it surfaced.
I find it hard to believe that LE has not made any efforts to minimize the damage they have caused. The usual answer "They need to update their devices", although correct and true, has no application to digital agencies, or hosting companies that have clients (which in turn have clients also) and they have to explain to them was has happened.
Bottom line: is there any WORKING & SPECIFIC solution (server-side) that we can follow, even temporarily? Do we need to purchase SSLs and get it over with?
If there is something to be downloaded / replaced, please be thorough with your instructions (@rg305 we really appreciate your efforts). As you can imagine, servers with live websites are not so simple to be powered on or off numerous times a day just to "test if this works".
A responsible answer to the above, please.
@rg305
It's the same result. Port 465 is where the mail client connects to.
@AndersonSilvestre , welcome to the LE community forum
Please speak with your Hosting Service Provider (HSP) about that problem.
It is surely affecting all users of that system.
That port looks good.
How about 25 (with STARTTLS)
OR 993
OR 587
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----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and it seems to correspond to what is extracted from freecert.pfx file
Hi @Picasso701, welcome to the LE community forum
This may not be directly relevant to your firewall brand (unknown).
But it may help explain what choices are out there that others are making in the situation:
https://kb.fortinet.com/kb/documentLink.do?externalID=FD49028
@abu1
The site is not serving any chain (at all).
If you are using certbot
, then switch from using cert.pem
to using fullchain.pem
Yes, some Firewalls are taking issue with the Multiple Certificate Chain/Paths.
For example Qualys SSL Server Test even shows Certification Path #2 for community.letsencrypt.org with the Expired Certificate. For this reason some Firewalls that perform SSL Scanning (Proxying) take issue.
See "Certification Paths" -> "Path #2: Not trusted (invalid certificate [Fingerprint SHA256: 0687260331a72403d909f105e69bcf0d32e1bd2493ffc6d9206d11bcd6770739])"
For Sophos UTM/SG Firewalls see: Service and Support
Hi @nerdaliciousCH welcome to the LE community forum
Because it is still the preferred chain.
You can chose to use the other valid trust path.
993 is again the same. 587 does not respond, neither 25. Port 25 is the unencrypted one. How would I test that STARTTLS?
We are using acme.sh. Is there a different solution for this? If not, how do I make this switch? Thanks again
Has anyone got this working on a Debian based web server? My Xamarin Android app can't connect to its API due to the certificate expiry.
@criton2000
hmm... pfx...
Then you are using Windows; And it probably doesn't have the "ISRG Root X1" in the trusted store.
[and possibly not even the "R3" intermediate (not actually required)]
And Windows is doing w/e it feels like with that included information (nothing).
Try adding the "ISRG Root X1" cert to the trust store.
[might need a reboot and/or rebinding of IIS to the cert]
You can find it here:
Self-signed: der, pem
openssl s_client -connect EXAMPLE.COM:25 -starttls smtp
For acme.sh
change the EXAMPLE.COM.cer
for fullchain.cer
@reg305
Port 25 didn't give a reply. On Port 465 I got this:
CONNECTED(00000003)
Didn't find STARTTLS in server response, trying anyway...
write:errno=0
no peer certificate available
SSL handshake has read 0 bytes and written 346 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
I see. How/where do I make this change? @rg305
