Ok, updates for me:
# sudo ./certbot-auto --os-packages-only
All seems ok, two warning lines:
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-min
which looks benign.
# export VENV_ARGS="--python $(command -v python2 || command -v python 2.7)"
No output, ok.
# tools/_venv_common.sh -e acme -e . -e certbot-apache -e certbot-nginx
Some warnings, but finished ok:
++ /home/ca/certbot/tools/merge_requirements.py /home/ca/certbot/tools/dev_constraints.txt /tmp/tmp.1AVj9Qv3rM
/home/ca/certbot/venv/local/lib/python2.7/site-packages/pip/_vendor/requests/packages/urllib3/util/ssl_.py:318: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.io/en/latest/security.html#snimissingwarning. SNIMissingWarning
/home/ca/certbot/venv/local/lib/python2.7/site-packages/pip/_vendor/requests/packages/urllib3/util/ssl_.py:122: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.io/en/latest/security.html#insecureplatformwarning. InsecurePlatformWarning
then final message
Please run the following command to activate developer environment:
source venv/bin/activate
# venv/bin/certbot --apache --preferred-challenges http
1: [redacted].ro
2: airtime.[redacted].ro
3: fb.[redacted].ro
4: listen.[redacted].ro
5: www.[redacted].ro
blank to select all options shown (Enter 'c' to cancel): 1,2,3,4,5
Cert not yet due for renewal
`You have an existing certificate that has exactly the same domains or certificate name you requested and isn't close to expiry.` `(ref: /etc/letsencrypt/renewal/airtime.[redacted].ro.conf)`
What would you like to do?
http-01 challenge for [redacted].ro
http-01 challenge for airtime.[redacted].ro
http-01 challenge for fb.[redacted].ro
http-01 challenge for listen.[redacted].ro
http-01 challenge for www.[redacted].ro
Failed authorization procedure. fb.[redacted].ro (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://fb.[redacted].ro/.well-known/acme-challenge/nKsabs49FVQQgPheCTm4vEghYcNhGo9GNJ2I4XgRE6w: "
<!DOCTYPE html>
<html lang="en" id="facebook" class="no_js">
<head><meta charset="utf-8" /><meta name="referrer" content="defaul", listen.[redacted].ro (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://listen.[redacted].ro/.well-known/acme-challenge/1yiF4phYb-KDZbPZ4whjYxI6Wtac-nLClyD3wbb6LlE [xxx.xxx.xxx.xxx]: 404
` Domain: fb.[redacted].ro` ` Type: unauthorized` ` Detail: Invalid response from` ` http://fb.[redacted].ro/.well-known/acme-challenge/nKsabs49FVQQgPheCTm4vEghYcNhGo9GNJ2I4XgRE6w:` ` "<!DOCTYPE html>` ` <html lang="en" id="facebook" class="no_js">` ` <head><meta charset="utf-8" /><meta name="referrer"` ` content="defaul"`
Domain: listen.[redacted].ro
For the fb.[redacted].ro and listen.[redacted].ro subdomains it might be normal to fail.
- fb.[redacted].ro is a redirect to a Facebook application page
- listen[redacted].ro is an internal redirect to an internal Icecast stream (via Airtime)
Below are the Apache conf files for those two subdomains failing (http and https):
fb.[redacted].ro.conf
<VirtualHost *:80>
ServerName fb.[redacted].ro
ProxyPreserveHost On
Redirect permanent / https://www.facebook.com/[redacted]/
RewriteEngine On
RewriteCond %{SERVER_NAME} =airtime.[redacted].ro
RewriteRule ^ https://www.facebook.com/[redacted]/%{REQUEST_URI} [END,NE,R=permanent]
RewriteCond %{SERVER_NAME} =fb.[redacted].ro
</VirtualHost>
fb.[redacted].ro-le-ssl.conf
<IfModule mod_ssl.c>
<VirtualHost *:443>
RewriteEngine On
# Some rewrite rules in this file were disabled on your HTTPS site,
# because they have the potential to create redirection loops.
SSLCertificateFile /etc/letsencrypt/live/airtime.[redacted].ro/cert.pem
SSLCertificateKeyFile /etc/letsencrypt/live/airtime.[redacted].ro/privkey.pem Include /etc/letsencrypt/options-ssl-apache.conf
SSLCertificateChainFile /etc/letsencrypt/live/airtime.[redacted].ro/chain.pem
</VirtualHost>
</IfModule>
listen.[redacted].ro.conf
<VirtualHost *:80>
ServerName listen.[redacted].ro
ProxyPass / http://localhost:8000/airtime_128
ProxyPassReverse / http://localhost:8000/airtime_128
RewriteEngine on
RewriteCond %{SERVER_NAME} =listen.[redacted].ro
</VirtualHost>
listen.[redacted].ro-le-ssl.conf
<VirtualHost *:443>
SSLCertificateChainFile /etc/letsencrypt/live/airtime.[redacted].ro/chain.pem </VirtualHost>
</IfModule>
I cannot upload the log file (Sorry, new users cannot upload attachments), but here are the logged things for fb. and listen. subdomains:
Detail: Invalid response from http://fb.[redacted].ro/.well-known/acme-challenge/nKsabs49FVQQgPheCTm4vEghYcNhGo9GNJ2I4XgRE6w: "<!DOCTYPE html>
Detail: Invalid response from http://listen.[redacted].ro/.well-known/acme-challenge/1yiF4phYb-KDZbPZ4whjYxI6Wtac-nLClyD3wbb6LlE [xxx.xxx.xxx.xxx]: 404
To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address.
2018-01-15 07:11:41,985:INFO:certbot.auth_handler:Cleaning up challenges
2018-01-15 07:11:43,481:DEBUG:certbot.log:Exiting abnormally:
File "venv/bin/certbot", line 9, in <module>
load_entry_point('certbot', 'console_scripts', 'certbot')()
File "/home/ca/certbot/certbot/main.py", line 1240, in main
File "/home/ca/certbot/certbot/main.py", line 994, in run
certname, lineage)
File "/home/ca/certbot/certbot/main.py", line 113, in _get_and_save_cert
renewal.renew_cert(config, domains, le_client, lineage)
File "/home/ca/certbot/certbot/renewal.py", line 297, in renew_cert
new_certr, new_chain, new_key, _ = le_client.obtain_certificate(domains)
File "/home/ca/certbot/certbot/client.py", line 318, in obtain_certificate
self.config.allow_subset_of_names)
File "/home/ca/certbot/certbot/auth_handler.py", line 81, in get_authorizations
self._respond(resp, best_effort)
File "/home/ca/certbot/certbot/auth_handler.py", line 138, in _respond
self._poll_challenges(chall_update, best_effort)
File "/home/ca/certbot/certbot/auth_handler.py", line 202, in _poll_challenges
raise errors.FailedChallenges(all_failed_achalls)
FailedChallenges: Failed authorization procedure. fb.[redacted].ro (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://fb.[redacted].ro/.well-known/acme-challenge/nKsabs49FVQQgPheCTm4vEghYcNhGo9GNJ2I4XgRE6w: "<!DOCTYPE html>
