Help renewing certificate (ends on April 21) on nextcloudpi instance
Hello,
I have the following problem. I don’t really understand why, but it might be linked to an apache issue I had earlier that I fixed by removing the LISTEN directive on IPv6 addresses in my port.conf. See here for the entire description of the problem: https://help.nextcloud.com/t/need-help-ncp-dist-upgrade-broke-everything-apache-config/71779.
But maybe not? Anyway, thanks for your help !
My domain is: nc.jcjm.fr
I ran this command: $ sudo letsencrypt renew (actually nextcloupi run it for me, but I just did it manually)
Processing /etc/letsencrypt/renewal/nc.jcjm.fr.conf
http-01 challenge for nc.jcjm.fr
Attempting to renew cert (nc.jcjm.fr) from /etc/letsencrypt/renewal/nc.jcjm.fr.conf produced an unexpected error: Failed authorization procedure. nc.jcjm.fr (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://nc.jcjm.fr/.well-known/acme-challenge/7xUX6oIIYr1YpY9kXVCGQhYJTIE2UAS2qYEYT9jUc2Q [82.66.248.159]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\">\n<html><head>\n<title>404 Not Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p". Skipping.
  /etc/letsencrypt/live/nc.jcjm.fr/fullchain.pem (failure)
   Domain: nc.jcjm.fr
   Type:   unauthorized
   Detail: Invalid response from
My web server is (include version): Apache/2.4.38
The operating system my web server runs on is (include version): Raspbian 10 (buster)
My hosting provider, if applicable, is: OVH
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Hi @jean2
if you use webroot and if that doesn't work, your webroot may be wrong or you have additional definitions.
What's the webroot of your config file (or what's your manual input)?
What says
apachectl -S
It gives:
$ sudo apachectl -S
VirtualHost configuration:
*:4443                 localhost (/etc/apache2/sites-enabled/ncp.conf:2)
*:443                  nc.jcjm.fr (/etc/apache2/sites-enabled/nextcloud.conf:2)
ServerRoot: "/etc/apache2"
Mutex proxy: using_defaults
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
I noticed that the Main DocumentRoot is probably wrong (it should be /var/www/nextcloud I believe), so it may be that, I don't know how to change that.
Where is your http / port 80 vHost?
You need such a vHost. That document root -> use that in your command.
Check
What do you mean ?
(And thanks for your help by the way !)
Ah I just got what was wrong (or at least I think!)
So my http vHost was I guess in /etc/apaches/sites-available/nextcloud.conf
I noticed that another site (000-default.conf) was not activated, and that in my nextcloud.conf, there is a <VirtualHost _default_:443>, so I assumed that it was referring to that default conf that was not activated, so I activated it (a2ensite...) and now it works ! I don’t know whther my reasoning is correct or not, but let me know otherwise !
Thanks for your time
