Help regarding renewing let's encrypt certificate
Can someone please help me with this issue:
I got an email stating that my certificate will expire in 10 days
My domain is: https://veratanlp.centralus.cloudapp.azure.com
I ran this command: sudo certbot renew
/etc/letsencrypt/live/veratanlp.centralus.cloudapp.azure.com/fullchain.pem (failure)
http://veratanlp.centralus.cloudapp.azure.com/.well-known/acme-challenge/uxIJrkHyhoeFqsxA1vAcNz-dPq4-8JSo7NCqSShCBt8:
My web server is (include version): Apache/2.4.29 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 18
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
This is telling you what the problem--the Let's Encrypt servers can't connect to your hostname on port 80. They need to be able to do that.
ok, so what we should do, so that Let’s Encrypt servers can connect to our hostname on port 80.
Like how can we let it happen, can you please give us the clue
Fix your servers, fix your router, fix your firewall--the problem is on your end. You've changed something in your network or server configuration since you got the cert, and now the world can't connect. In order to obtain or renew a cert using HTTP validation (which is what you're trying to do), the outside world needs to be able to reach your server--but it can't do so.
ok thanks, we are doing that but just a question to my mind how come Let’s encrypt has been running successfully on our server since Feb 2019 and getting failed now. I also run renew-dry run at that time and it gave no error.
