Help new Certificates
My domain is: data.api.mypls.com
I ran this command: certbot certonly --standalone -d api.mypls.com
It produced this output: Requesting a certificate for api.mypls.com
  Domain: api.mypls.com
  Type:   unauthorized
  Detail: 137.135.88.41: Invalid response from http://api.mypls.com/.well-known/acme-challenge/_z-rLptEumhP78JeEu36Z1YjbLvG80lN7nD19ofQ1S0: 404
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile C:\Certbot\log\letsencrypt.log or re-run Certbot with -v for more details.
The operating system my web server runs on is (include version): 10.0.22621 N/A Build 22621
My hosting provider, if applicable, is: Microsoft Azure
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot --version
First, if you want a certificate to cover data.api.mypls.com then that should be the domain name in the certbot command (and not just api.mypls.com)
Second, you have an nginx server responding to HTTP (port 80) requests right now. The --standalone option needs exclusive use of port 80 so won't work with nginx using that port.
You need to either stop nginx or use the --webroot method to rely on the existing nginx to satisfy the HTTP Challenge.
I see you already have a working HTTPS connection to your data domain (apart from its expired cert) so you should avoid using the --nginx method unless you also use it with certonly
But...
❯ curl -IL api.mypls.com
HTTP/1.1 404 Not Found
Server: nginx/1.19.1
Date: Thu, 21 Sep 2023 21:01:42 GMT
Content-Type: text/html
Are you running Certbot on the same machine your domain is pointing to?
