Help install ssl
My domain is: dynamicflow.my.id
sudo certbot --apache -d e-learning.dynamicflow.my.id
It produced this output: ssl certificate installed successfully
My web server is (include version): 22.04
The operating system my web server runs on is (include version): ubuntu 22.04
My hosting provider, if applicable, is: idcloudhost
I can login to a root shell on my machine (yes or no, or I don't know): i dont know
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):I run it using putty 116.193.191.70
Hi @ayyash-u, and welcome to the LE community forum :slight_smile:
What error message do you get?
I can't resolve that name to an IP:
dns.google can't find e-learning.dynamicflow.my.id: Non-existent domain
Certbot failed to authenticate some domain (authenticator : Apache) the certificate authority reported these peoblems :
Domain : dynamicflow.my.id
Type : connetion
Hint : the certificate authority failed to verify the temporary Apache configuration changes Made by certbot. Ensure that the listed domains point to this Apache server and that it is accessible from the internet
Some challenges have failed
Ask for help. See the logfile /var/log/let'sencrypt/let'sencrypt.log or re run certbot with -v for more details
Something like that
Without an IP in DNS, the site can't be accessed from the Internet.
I created a vm on cloudhost id and it's already running, port 80 and 443 are also allowed
I even recorded it on cloudflare
Did you add an A record entry in Cloudflare DNS?
I say not:
dynamicflow.my.id nameserver = rene.ns.cloudflare.com
dynamicflow.my.id nameserver = julissa.ns.cloudflare.com
rene.ns.cloudflare.com can't find e-learning.dynamicflow.my.id: Non-existent domain
julissa.ns.cloudflare.com can't find e-learning.dynamicflow.my.id: Non-existent domain
That's been done since the creation of the DNS server, here I got the task of making moodle on the second VM, on cloudflare I've added a record type a , name: moodle, ipv4 : IP of my VM, then I save
But you are trying to get a certificate for the name e-learning:
Yes, I followed the tutorial from my lecturer, but it failed, I tried it with dynamicflow.my.id and it failed too
Do you own this domain name? Did your lecturer want you to request a certificate for this particular name, or did you want to do it for your own reason?
Basically you need to decide to either use e-learning or moodle as your subdomain, and make necessary amendments to either your DNS or your command line.
