Help for MDM :Mobile Device Management Headwind open source
Hi, I'm working on securing Android devices using MDM(Mobile Device Management) exacte the solution headwind open source . Is there anyone here with knowledge in MDM or related topics like device policy control or remote management?
they don't care about what certificate at all, but just a certifficate android device would trust:
Warning: despite this tutorial's order don't request certificate before login access web panel and changed password from default: every certificate is loged in public (by certificate transparency) and there are bot to connect your website and try default password.
Thank you for your answer.But actually, I’m looking for someone who really understands how MDM works , especially in the context of headwind MDMor similar open-source solutions.I’m not just asking about certificates , I’m working on a full MDM integration and I have some technical questions.
If anyone here has worked with Headwind MDM or custom Android device management, I’d be really grateful for your help!
You should search for other forums. We are not a general purpose help site for anything related to software. There must be forums that focus specifically on that.
Our purpose is on helping people get Let's Encrypt certificates. We also help configure common web servers and similar systems to use those certs.
