Help Error Domain
Good Morning!
Dear ones could help me.
In the configuration we use the command
#certbotcertonly --standalone -D DOMINIO.COM.BR
At the end of the process it is generating an error, could you explain to me what could be causing this error?
Domain: fwgrancursosmatriz.com.br
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for fwgrancursosmatriz.com.br - check that a DNS record exists for this domain
Welcome to the community @welington.lima
Just like the message says, you do not have DNS setup for that domain name
Make sure this is a public domain name and setup the DNS for it. Contact your domain name registrar for advice
Perfect!
In this case I need to make this domain public is that it?
It's still just local on our device.
Yes that is it
Thank you very much,
Dear mike!
