Help After Deleting a Certificate I get SSL_ERROR_RX_RECORD_TOO_LONG
My domain is: ineedamaid.com
certbot delete
Success
nginx/1.14.1
ubunutu 16.4
digitalocean
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.28.0-1+ubuntu16.04.1+certbot+4
Hi @rodericks
why do you delete a certificate? The error message
says: Your port 443 is a http port, not a https port. Same result - a check, ~~45 minutes old - https://check-your-website.server-daten.de/?q=ineedamaid.com - Grade Q.
So you have two options:
  • Remove the port 443 complete, create a new certificate and let Certbot create a new vHost
  • add an expired or a self signed certificate to your port 443 vHost, so that vHost has a wrong certificate, but answers.
Thank you I’ll look into that. For now I just ran certbot --rollback, and that seems to have gotten the website back up. I’ll try your solution this weekend.
