Hello ,
i have problem with my website with letsencrypt i use cwp panel where it has letsencrypt integrated with autoSSL function where it was all good but i forget it to renew the SSl licence on my domain and now it shows expired here is results from test http://prntscr.com/lkypw4
My domain is: https://najdime.mk
On CWP PANEL - AUTOSSL
Linux Centos 6/ 64 bit other sites work well with SSL
VPS server
Yes
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): CWP - panel
You’ve got multiple certificates issued today for that domain: https://crt.sh/?q=%najdime.mk (Half of them are SCT pre-certificates, but the other half are valid certificates.)
I don’t have experience with CWP panel, but you should check if your certificate was installed properly to your webserver. Perhaps it’s as simpel as just reloading your webserver, perhaps the new certificate needs to be installed first.
@Osiris has correctly pointed out that the new certificates exist, they’re just not being used by your web server. That probably means that something else has to be done in the panel, or else related to the integration between the panel and your web server.
