This is what I see :
root@192-53-160-247:/etc/nginx/sites-enabled# ls
reverse-proxy.conf
reverse-proxy.conf
That's weird, why wouldn't it pop up in the output earlier:
Very weird.. Anyway, it still depends on what the configuration file does and if you want it enabled or not.
Since /etc/nginx/sites-enabled
only has that file, where do I put my url?
You mean your hostname(s)? I don't know, as I don't know the purpose nor contents of reverse-proxy.conf
Just trying to figure out how to get the cert working.
The server_name www.captainnemo.icu captainnemo.icu;
directive goes into the configuration file you want to enable SSL on. (And of course you want to listen to those hostnames.)
Please explain like I'm 5. This is the first time I've worked with Nginx or certs. I need to know exactly what needs to go where.
Change server_name localhost;
to server_name www.captainnemo.icu captainnemo.icu;
in reverse-proxy.conf
, reload nginx and try installing the cert again.
That worked.
Deploying certificate
Successfully deployed certificate for captainnemo.icu to /etc/nginx/sites-enabled/reverse-proxy.conf
Successfully deployed certificate for www.captainnemo.icu to /etc/nginx/sites-enabled/reverse-proxy.conf
Thanks @Osiris
Because the grep searched through all folders - even the sites-available folder [which has that file that isn't being used]
As shown by the nginx -T
output.
If the file was in /sites-available/
and /sites-enabled/
, then the grep output would show both, right? Even if it are symlinks?
I mean, I would have expected:
/etc/nginx/sites-available/reverse-proxy.conf: server_name localhost;
/etc/nginx/sites-enabled/reverse-proxy.conf: server_name localhost;
Yeah, I missed the last few lines in that output, it was there.
