Having issues, Please help!
For Reference:
After entering:
sudo certbot --authenticator webroot --installer nginx
and going through steps I get result:
Failed authorization procedure. ico.rizzle.io (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://ico.rizzle.io/.well-known/acme-challenge/axBIaHmQWAxENv73y8SZBM-AMY16fWGY5iB3iAtt6iw: "
404 Not Found
404 Not Found
I am trying to setup 4 domains at the moment on my newly setup server running nginx.
The original errors I received were:
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA.
and,
An unexpected error occurred:
SSLError: ("bad handshake: Error([('SSL routines', 'ssl3_get_server_certificate', 'certificate verify failed')],)",)
Here are screenshots, awaiting help, thanks in advance.
Here is another screenshot, pt of the terminal command line.
Awaiting help, Thanks in advance!
Are you sure that the webroot for ico.rizzle.io is /var/www/rizzle.io/html ?
From what I can tell, it is served from a different webroot path to rizzle.io and www.rizzle.io.
$ curl -s -i rizzle.io/.well-known/ | head -n 1
HTTP/1.1 403 Forbidden
$ curl -s -i ico.rizzle.io/.well-known/ | head -n 1
HTTP/1.1 404 Not Found
Your responses to Certbot indicated that they are served from the same document root, which does not seem accurate.
You will need to provide an accurate response to Certbot when prompted for the webroot path for ico.rizzle.io, otherwise it will not be able to complete the HTTP challenge for that domain.
