Hi Everyone,
I’m currently attempting to setup Let’s Encrypt via HaProxy on a Centos 7 machine using the Webroot method. The issue I’m having is receiving 503 errors on the specific URL that’s generated:
(IP’s and URL edited for security)
certbot certonly --webroot -w /home/sites -d example.com -d www.example.com
http-01 challenge for example.com
http-01 challenge for www.example.com
Using the webroot path /var/www for all unmatched domains.
Failed authorization procedure. www.example.com (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.example.com/.well-known/acme-challenge/Mxh1WV4OE2grdgdXCVBIUe0P6EcJIEbI [111.222.333.444]: 503,
Domain: www.domain.com
Detail: Invalid response from
http://www.domain.com/.well-known/acme-challenge/Mxh1WV4OE2x5LpgdfgdfgXCVBIUe0P6EcJIEbI
Here is the config file inside of: /etc/haproxy/haproxy.cfg
frontend www-http
bind 111.222.333.444:80
reqadd X-Forwarded-Proto:\ http
#default_backend www-backend
acl letsencrypt-acl path_beg /.well-known/acme-challenge/
use_backend letsencrypt-backend if letsencrypt-acl
frontend www-https
bind 111.222.333.444:443 ssl crt /etc/haproxy/certs/example.com.pem
reqadd X-Forwarded-Proto:\ https
backend www-backend
redirect scheme https if !{ ssl_fc }
server www-1 111.222.333.777:80 check
server www-2 111.222.333.888:80 check
server letsencrypt 127.0.0.1:54321
At the moment, when I go to my specific URL in question, such as example.com/.well-known/acme-challenge/ then it gives me a 503 error on the browser. Therefore, when attempting to use web-root to generate my SSL, it’s failing with a 503 error.
I’ve compared my configs with around 20 other examples and they’re very similar in regards to the section for letsencrypt-acl. If I edit the URL inside the config file to something else, then the site loads fine on my browser, but the script still fails with a different error. So it’s deffo related to that specific section.
Doing an NMAP on my server, I can see that the port is closed, which I’ve attempted to open, although I doubt that it’s related. My assumption is that it’s attempting to load that URL over port 54321 which isn’t giving a response, so it’s generating a 503.
Is my theory correct and I need to look towards making that port accessible online, or do I need a different configuration to make it publicly accessible?
Thank you.
