flexployment.co . <- Will not really help you tho, since I don’t have a website running on this domain yet.
I ran this command: sudo -E certbot certonly --non-interactive --agree-tos --manual-public-ip-logging-ok --manual-auth-hook ${script_location}’/auth_hook.sh’ --manual-cleanup-hook ${script_location}’/cleanup_hook.sh’ --server https://acme-v02.api.letsencrypt.org/directory --preferred-challenges dns-01 --manual -d ${domain} -d ‘*.’${domain} --cert-name ${cert_directory_name}
Note that this error also occurs when I run certbot certonly --force-renewal …
It doesn’t produce much of an output, problem is that it keeps hanging on this:
Waiting for verification…
I am (not kidding) already waiting for 1.5 hours now, and it still keeps hanging.
Ubuntu 16.04 LTS,
Yes.
Content of my auth_hook:
export TF_VAR_DOMAIN_NAME="${CERTBOT_DOMAIN}."
export TF_VAR_ACME_TXT_RECORD="${CERTBOT_VALIDATION}"
declare -A dns_zones
dns_zones=( ["flexployment.co"]="<ID>" )
export TF_VAR_DNS_MANAGED_ZONE=${dns_zones[${CERTBOT_DOMAIN}]}
txt_records_file="/tmp/txt-records"
txt_records=()
echo ${TF_VAR_ACME_TXT_RECORD} >> ${txt_records_file}
if [ $(wc -l < ${txt_records_file}) -gt "1" ] ; then #LE validates the domain with two TXT records.
for record in $(cat ${txt_records_file}) ; do
txt_records+=(${record}) #Create an array that contains all the records. This array is passed to TF
done
export TF_VAR_TXT_RECORD_1=${txt_records[0]} # Only way to get the data into TF
export TF_VAR_TXT_RECORD_2=${txt_records[1]}
terraform apply --auto-approve
sleep 70 # TTL is 60
rm -r ${txt_records_file}
fi
Content of my cleanup.sh:
sudo -E terraform destroy -auto-approve # The one dash (-) is the right syntax for destroy.
Do you guys have any idea why Certbot keeps hanging?
