Is it possible to have certbot+dns-google issue a certificate where there are two SANs, each in a different subdomain delegation and GCP project?
The problem I am seeing is that certbot cannot run API calls against two GCP projects in the same certificate generation.
Thank you
example.com
certbot certonly --dns-google --dns-google-credentials=/creds/.credentials --non-interactive -m redacted@example.com --agree-tos --expand -d example.com.
(Issuance is correct)
n/a
Container-Optimized OS
GCP
no
certbot/dns-google:latest
