Golang server problem
pressurewash.io
sudo certbot certonly --webroot --webroot-path /tmp/letsencrypt/ --dry-run -d pressurewash.io
    Domain: pressurewash.io
    Type: connection
    Detail: Fetching
    http://pressurewash.io/.well-known/acme-challenge/CMIjiAak0xRXbppBAnFU6lYVz8bcff-5-bAOtgh_Poc:
golang standalone
centos7 latest
no
0.31.0
Extra information: I was having trouble getting certbot to work for me, and so i searched and found this tutorial. I expected it to work since i can readily access pressurewash.io when running the backend, and i figured this would resolve some of my port 80 problems. Sadly, no, this is the same error i got earlier. I followed this guide exactly, and it still has timeout error.
📄 Adding webroot support to your existing Go/Golang server
Are you sure your AT&T service allows you to forward ports? Have you forwarded port 80 to the machine running your webserver?
Your server is not accessible from the internet, and the error from Certbot reflects that.
Thanks, this seems to be what the problem is. I havent solved it yet, but I can confirm that my router hasnt enabled this device on the public IP. Thanks so much its been so long since ive setup the last public ip address i forgot i needed to do this. Cheers.
I didnt want to bump but i couldnt find an edit. The problem I faced was that my virtual machine host changed in the last few months and I forgot to reinitialize network bridging. Thanks to @_az for putting me on the right path to solving this.
Hi @cmshnrblu
use the three ..., then a pencil is shown.
