Getting too many redirects
done!
[root@earth conf.d]# httpd -t -D DUMP_VHOSTS
VirtualHost configuration:
*:80 www.labtop.com (/etc/httpd/conf.d/earthconf.conf:1)
*:443 www.labtop.com (/etc/httpd/conf.d/ssl.conf:54)
Excellent. You could do one final test. I'd be shocked if it does not work :slight_smile:
sudo certbot renew --dry-run
The --dry-run will not affect your production cert
It tests that the next renewal would succeed
Looks good! :slight_smile:
root@earth www.labtop.com]# certbot renew --dry-run
Processing /etc/letsencrypt/renewal/www.labtop.com.conf
Cannot extract OCSP URI from /etc/letsencrypt/archive/www.labtop.com/cert7.pem
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
Simulating renewal of an existing certificate for labtop.com and www.labtop.com
http-01 challenge for labtop.com
http-01 challenge for www.labtop.com
new certificate deployed with reload of apache server; fullchain is
/etc/letsencrypt/live/www.labtop.com/fullchain.pem
Congratulations, all simulated renewals succeeded:
/etc/letsencrypt/live/www.labtop.com/fullchain.pem (success)
Yes, terrific. All done :slight_smile:
Thanks again Mike... really that was above and beyond brother. :+1: :smiling_face_with_sunglasses:
