After hearing more good things about this project on the "Security Now" podcast I finally decided to give it a shot. The host I have happens to be CentOS 6.7. I am giving feedback 'cos that is how projects improve, and see through the eyes of newbie users:
Hoping to "stand on the shoulders of giants" I tried just poking / prodding at the command line, but quickly ended up at the website 'cos I had no idea where to start. I still struggle to know how to find clear understanding of the various command-line options (I just could not lookup "standalone", nor do I now know what that means verse webroot or manual.)
The problems I ran into where:
- Did not appear to support CentOS 6.7's Python 2.6 (but then, after warning, it seemed to run.)
- Could not get from yum, but got from github. Still not sure what the "-auto" means (but I assume for dummies, like me.)
- When I ran with "apache" it gave me a whole message blurb with undefined terms, which I assume meant it could not read the apache configuration to determine a list of hosts. (This HTTPD doesn't have a sites subdirectory.) Ok, understood ... passing -d www.neukadye.com (didn't immediately think to pass -d neukadye.com as well, eventually did.) BTW: Error messages might be simpler if they suggested "maybe the Apache format is not supported, or something".
- Wouldn't accept my email address (despite trying the one I signed up to her with, and my Gmail.) Not quite sure how I got past that, but it finally seemed to work.
- After Googling I finally try the standalone approach per community reference, which seemed to make sense if my HTTPD configuration was old style / not supported.
- Complained it could not listen on 80, ok ... makes sense, I'd missed that, stopped HTTPD.
- Finally got stuck here:
Failed authorization procedure. neukadye.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to host for DVSNI challenge, www.neukadye.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to host for DVSNI challenge
Domain: neukadye . com
Type: connection
Detail: Failed to connect to host for DVSNI challenge
Domain: www . neukadye . com
Type: connection
I've installed DNS tools and confirmed the nslookup of the domain works to it's IP, and I've futzed with the firewall settings to allow 443 (if that helps, except I believe this step is using 80.)
Any pointers on what to try next would be appreciated. (Note: I looked at the letsencrpyt.log file but for some reason it only includes a time when I attempt a --dry-run and it said that option was not available for my command.)
Clearly it appears like I have an inbound problem, from server back to this client, but I cannot think how and / or what I could try. Thanks in advance for any assistance.
Addendum:
Ok. ... I've tried to share my command line history, and reference the sites I read to get here, but your system is treating me as a spammer and disallowing links or attachment. I give in. ![]()
I found the iptables config file I’d saved before tinkering, I restored to that, restarted iptables service, checked I wasn’t locked out :-), then did exactly what it says NOT to do
