Generation of certificate with loopback not allowed
My domain is: deliverance.ddns.net
I ran this command: sudo letsencrypt certonly -a webroot --webroot-path=/var/www/html -d deliverance.ddns.net
It produced this output: Failed authorization procedure. deliverance.ddns.net (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to 92.28.XXX.XXX:XXXX
    Domain: deliverance.ddns.net
    Type: connection
    Detail: Could not connect to 92.28.XXX.XXX:XXXX
My operating system is (include version): Linux raspberrypi 4.4.38-v7+
My web server is (include version): nginx version: nginx/1.6.2
My hosting provider, if applicable, is: No-IP
’m using a control panel to manage my site (no, or provide the name and version of the control panel): I dont know
Good morning. I’m quite new in all this so, please forgive me if I make dummy questions or any stupid assumption. My end goal is having node-red running in my pi serving some webpages, and handle the traffic with nginx. The tutorial that i’m following (with some exceptions) is Tutorial.
So:
  • I have running nginx. I can connect to my localhost:80 and see the basic webpages server by nginx.
  • I have a ddns (deliverance.ddns.net) and If i access that DNS from outside my local network, I can see the basic webpages server by nginx.
Now, I want to create a certificate with Let’s Encrypt and I ran the command mentioned before with the result mentioned before too.
I think that the problem is that, when I execute the command to generate the certificate the connection is
Local network -> DDNS -> Local network again.
I was asking in the forums of my internet provider, and seems that the problem is that loopback is not allowed.
I was wondering, is there anyway to avoid that restriction.
As a note, the router is a Huawey HG633 and I was not able to find an specific option that could help me with that in the admin panel of the router.
Regards
You redirect eveything on that domain name to 92.xx.xxx.xxx:1890 (I’m not sure why you turn that into xxx - because I anyone gets redirected to that IP - so it’s public information).
I can’t access that IP on port 1890 though. Do you have a firewall ? or have you not set up port forwarding ?
You may be easier obtaining a cert using the DNS-01 challenge
Good morning serverco. Thanks for the answer. I am currently out of the country so I turned off everything (that is why you could not access to the pi probably) you are right I masked the ip with XXX but only because as I’m new, I’m a bit paranoid with the security but as you pointed, the domain just gives the ip so… My bad hahaha. I will be able to set everything up tomorrow and let my pi running. I will post another message when everything is ready. Maybe that could help us. I dont know about the dns1 challenge I will try to read and find some information about it during my trip back.
