I have a VPS which hosts a single site. This site has auto HTTPS forwarding and the site is set up as a VHOST with its own sites-enabled config.
My site works fine.
I've recently seen in the logs a lot of random sites accessing the files on my server as if they had came from my domain. Turns out there's a few sites that have my VPS IP as their A record, and despite the security warning issued to these sites when accessed about impersonation etc, the are still being accessed. It appears to be all bot traffic.
MY apache server has 3 sites-enabled. 2 for the domain I'm using and one for the default config (000). I think that because of the auto forward to HTTPS all these requests are being routed to the SSL config.
I want to create a 000 SSL config to stop these requests being processed further, but running certbot docent allow me to generate an SSL for the default config.
Any ideas?
My domain is: 406oc.co.uk
I ran this command: sudo certbot
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: 406oc.co.uk
2: www.406oc.co.uk
blank to select all options shown (Enter 'c' to cancel): c
My web server is (include version): Server version: Apache/2.4.41 (Ubuntu)
Server built: 2023-03-08T17:32:54
Linux loki 5.4.0-47-generic #51-Ubuntu SMP Fri Sep 4 19:50:52 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
or certbot-auto --version
if you're using Certbot): certbot 2.8.0
