My web server is (include version): apache 2
The operating system my web server runs on is (include version): Ubuntu 22.04
My hosting provider, if applicable, is: no
I can login to a root shell on my machine (yes or no, or I don't know): no
I'm using a control panel to manage my site (no,
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
got this:
apachectl -S
AH00526: Syntax error on line 33 of /etc/apache2/sites-enabled/000-default-le-ssl.conf:
SSLCertificateFile: file '/etc/letsencrypt/live/ekoninfochecker.efri.uniri.hr/fullchain.pem' does not exist or is empty
Action '-S' failed.
sudo certbot certificates shows
Found the following certs:
Certificate Name: ekoninfochecker.efri.uniri.hr
Serial Number: 4c6920a96979091d360c1c8ff71546f3396
Key Type: ECDSA
Domains: ekoninfochecker.efri.uniri.hr
Expiry Date: 2024-08-01 18:01:33+00:00 (VALID: 87 days)
Certificate Path: /etc/letsencrypt/live/ekoninfochecker.efri.uniri.hr/fullchain.pem
Private Key Path: /etc/letsencrypt/live/ekoninfochecker.efri.uniri.hr/privkey.pem
SSL Checker gives ok, SSL Certificate Checker - Diagnostic Tool | DigiCert.com gives ok,
Check SSL Certificate - GeoCerts gives ok
Chrome: Your connection is not private
Attackers might be trying to steal your information from 31.147.206.21 (for example, passwords, messages, or credit cards). Learn more
NET::ERR_CERT_COMMON_NAME_INVALID
Common Name (CN)
Organization (O)
Organizational Unit (OU)
Common Name (CN)
R3
Organization (O)
Let's Encrypt
Issued On
Friday, May 3, 2024 at 8:01:34 PM
Expires On
Thursday, August 1, 2024 at 8:01:33 PM
Certificate
623282b720c2f7d0937e7e6c204cbeb174b365ee1915995353d52d9137d5f9e6
Public Key
cce991425d535f8413382d06dfc937290cd113c5051328dcb265147757522df8
Hello @dcisic , welcome to the Let's Encrypt community.
I am not sure what I am sharing directly applies,
but the site https://ekoninfochecker.efri.uniri.hr (a Doman Name)
is being redirected to (https://31.147.206.21/ (an IP Address)
Let’s Encrypt offers Domain Validation (DV) certificates ; an NOT IP Addresses presently.
$ curl -i https://ekoninfochecker.efri.uniri.hr
Date: Sun, 05 May 2024 20:08:57 GMT
Server: Apache/2.4.52 (Ubuntu)
X-Redirect-By: WordPress
Content-Length: 0
@dcisic also Show the output of
sudo apachectl -t -D DUMP_VHOSTS
and also
sudo ls -l /etc/letsencrypt/live/ekoninfochecker.efri.uniri.hr/
VirtualHost configuration:
*:443 is a NameVirtualHost
default server ekoninfochecker.efri.uniri.hr (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
port 443 namevhost ekoninfochecker.efri.uniri.hr (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
port 443 namevhost ekoninfo.hrzoo (/etc/apache2/sites-enabled/default-ssl.conf:2)
port 443 namevhost ekoninfochecker.efri.uniri.hr (/etc/apache2/sites-enabled/ekoninfochecker.efri.uniri.hr.conf:1)
*:80 ekoninfochecker.efri.uniri.hr (/etc/apache2/sites-enabled/ekoninfochecker.efri.uniri.hr.conf:10)
-rw-r--r-- 1 root root 692 Apr 14 07:25 README
lrwxrwxrwx 1 root root 53 May 3 19:01 cert.pem -> ../../archive/ekoninfochecker.efri.uniri.hr/cert2.pem
lrwxrwxrwx 1 root root 54 May 3 19:01 chain.pem -> ../../archive/ekoninfochecker.efri.uniri.hr/chain2.pem
lrwxrwxrwx 1 root root 58 May 3 19:01 fullchain.pem -> ../../archive/ekoninfochecker.efri.uniri.hr/fullchain2.pem
lrwxrwxrwx 1 root root 56 May 3 19:01 privkey.pem -> ../../archive/ekoninfochecker.efri.uniri.hr/privkey2.pem
And now sudo ls -l /etc/letsencrypt/archive/ekoninfochecker.efri.uniri.hr/
ekon@ekoninfo:/etc/apache2/sites-available$ sudo ls -l /etc/letsencrypt/archive/ekoninfochecker.efri.uniri.hr/
total 32
-rw-r--r-- 1 root root 1801 Apr 14 07:25 cert1.pem
-rw-r--r-- 1 root root 1529 May 3 19:01 cert2.pem
-rw-r--r-- 1 root root 1826 Apr 14 07:25 chain1.pem
-rw-r--r-- 1 root root 1826 May 3 19:01 chain2.pem
-rw-r--r-- 1 root root 3627 Apr 14 07:25 fullchain1.pem
-rw-r--r-- 1 root root 3355 May 3 19:01 fullchain2.pem
-rw------- 1 root root 1704 Apr 14 07:25 privkey1.pem
-rw------- 1 root root 241 May 3 19:01 privkey2.pem
@dcisic ,
dcisic:
apachectl -S
Was that run as root or via sudo?
This is only the public certificates and intermediates CA chain, so this is all safe to share.
Please show the output of
sudo cat /etc/letsencrypt/live/ekoninfochecker.efri.uniri.hr/fullchain.pem
Bruce5051:
ekon@ekoninfo:/etc/apache2/sites-available$ sudo cat /etc/letsencrypt/live/ekoninfochecker.efri.uniri.hr/fullchain.pem
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
MIIFFjCCAv6gAwIBAgIRAJErCErPDBinU/bWLiWnX1owDQYJKoZIhvcNAQELBQAw
TzELMAkGA1UEBhMCVVMxKTAnBgNVBAoTIEludGVybmV0IFNlY3VyaXR5IFJlc2Vh
cmNoIEdyb3VwMRUwEwYDVQQDEwxJU1JHIFJvb3QgWDEwHhcNMjAwOTA0MDAwMDAw
WhcNMjUwOTE1MTYwMDAwWjAyMQswCQYDVQQGEwJVUzEWMBQGA1UEChMNTGV0J3Mg
RW5jcnlwdDELMAkGA1UEAxMCUjMwggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEK
AoIBAQC7AhUozPaglNMPEuyNVZLD+ILxmaZ6QoinXSaqtSu5xUyxr45r+XXIo9cP
R5QUVTVXjJ6oojkZ9YI8QqlObvU7wy7bjcCwXPNZOOftz2nwWgsbvsCUJCWH+jdx
sxPnHKzhm+/b5DtFUkWWqcFTzjTIUu61ru2P3mBw4qVUq7ZtDpelQDRrK9O8Zutm
NHz6a4uPVymZ+DAXXbpyb/uBxa3Shlg9F8fnCbvxK/eG3MHacV3URuPMrSXBiLxg
Z3Vms/EY96Jc5lP/Ooi2R6X/ExjqmAl3P51T+c8B5fWmcBcUr2Ok/5mzk53cU6cG
/kiFHaFpriV1uxPMUgP17VGhi9sVAgMBAAGjggEIMIIBBDAOBgNVHQ8BAf8EBAMC
AYYwHQYDVR0lBBYwFAYIKwYBBQUHAwIGCCsGAQUFBwMBMBIGA1UdEwEB/wQIMAYB
Af8CAQAwHQYDVR0OBBYEFBQusxe3WFbLrlAJQOYfr52LFMLGMB8GA1UdIwQYMBaA
FHm0WeZ7tuXkAXOACIjIGlj26ZtuMDIGCCsGAQUFBwEBBCYwJDAiBggrBgEFBQcw
AoYWaHR0cDovL3gxLmkubGVuY3Iub3JnLzAnBgNVHR8EIDAeMBygGqAYhhZodHRw
Oi8veDEuYy5sZW5jci5vcmcvMCIGA1UdIAQbMBkwCAYGZ4EMAQIBMA0GCysGAQQB
gt8TAQEBMA0GCSqGSIb3DQEBCwUAA4ICAQCFyk5HPqP3hUSFvNVneLKYY611TR6W
PTNlclQtgaDqw+34IL9fzLdwALduO/ZelN7kIJ+m74uyA+eitRY8kc607TkC53wl
ikfmZW4/RvTZ8M6UK+5UzhK8jCdLuMGYL6KvzXGRSgi3yLgjewQtCPkIVz6D2QQz
CkcheAmCJ8MqyJu5zlzyZMjAvnnAT45tRAxekrsu94sQ4egdRCnbWSDtY7kh+BIm
lJNXoB1lBMEKIq4QDUOXoRgffuDghje1WrG9ML+Hbisq/yFOGwXD9RiX8F6sw6W4
avAuvDszue5L3sz85K+EC4Y/wFVDNvZo4TYXao6Z0f+lQKc0t8DQYzk1OXVu8rp2
yJMC6alLbBfODALZvYH7n7do1AZls4I9d1P4jnkDrQoxB3UqQ9hVl3LEKQ73xF1O
yK5GhDDX8oVfGKF5u+decIsH4YaTw7mP3GFxJSqv3+0lUFJoi5Lc5da149p90Ids
hCExroL1+7mryIkXPeFM5TgO9r0rvZaBFOvV2z0gp35Z0+L4WPlbuEjN/lxPFin+
HlUjr8gRsI3qfJOQFy/9rKIJR0Y/8Omwt/8oTWgy1mdeHmmjk7j1nYsvC9JSQ6Zv
MldlTTKB3zhThV1+XWYp6rjd5JW1zbVWEkLNxE7GJThEUG3szgBVGP7pSWTUTsqX
nLRbwHOoq7hHwg==
sudo now : sudo apachectl -S
port 443 namevhost ekoninfochecker.efri.uniri.hr (/etc/apache2/sites-enabled/default-ssl.conf:2)
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
but still in Chrome certificate is not valid
@dcisic
So we have demonstrated
that this is not true .
Here details on Apache can be found in documentation and forums:
And at this point, kindly wait for more knowledgeable Let's Encrypt community volunteers to assist.
Yep I see that too; for this reason
@dcisic I suggest changing the redirect here
Date: Sun, 05 May 2024 22:10:17 GMT
Content-Length: 0
The Location: https://31.147.206.21/ to use the domain name of the server at the IPv4 Address 31.147.206.21 instead of that IPv4 Address.
@dcisic actually that redirect seems to only be doing harm since the
IP Address of ekoninfochecker.efri.uniri.hr is 31.147.206.21
At this point I suggest just removing the redirect.
$ nslookup ekoninfochecker.efri.uniri.hr
Server: 127.0.0.53
Address: 127.0.0.53#53
Non-authoritative answer:
Address: 31.147.206.21
After you change the redirect to use a domain name instead of an IP address you need to fix your VirtualHost layout. You have 3 VirtualHosts defined for the same domain name and port. You can only have 1. Apache does not issue an error but only one of them will ever be active.
system
Closed
June 4, 2024, 10:25pm
15
