Fullchain does not match cert and chain
My domain is: mail.bankvictoriasyariah.co.id
I ran this command: certbot certificates
Renewal configuration file /etc/letsencrypt/renewal/mail.bankvictoriasyariah.co.id.conf produced an unexpected error: fullchain does not match cert + chain for mail.bankvictoriasyariah.co.id!. Skipping.
The following renewal configurations were invalid:
The operating system my web server runs on is (include version): Ubuntu Xenial 16.04
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): via ssh
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): Certbot 0.31
I already check the cert.pem, chain.pem & fullchain.pem through this directory
/etc/letsencrypt/live/mail.bankvictoriasyariah.co.id vs /opt/zimbra/ssl/letsencrypt and the result is match, like the first and the last words on the given ceritificate from each .pem and the file size also exact.
How do i solve this problem ?
Please show this file:
and also, the full output of:
ls -l /etc/letsencrypt/live/*
Here the output
renew_before_expiry = 30 days
version = 0.31.0
archive_dir = /etc/letsencrypt/archive/mail.bankvictoriasyariah.co.id
cert = /etc/letsencrypt/live/mail.bankvictoriasyariah.co.id/cert.pem
privkey = /etc/letsencrypt/live/mail.bankvictoriasyariah.co.id/privkey.pem
chain = /etc/letsencrypt/live/mail.bankvictoriasyariah.co.id/chain.pem
fullchain = /etc/letsencrypt/live/mail.bankvictoriasyariah.co.id/fullchain.pem
[renewalparams]
authenticator = webroot
installer = None
account = 306xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
pre_hook = /usr/local/sbin/certbot_zimbra.sh -p
renew_hook = /usr/local/sbin/certbot_zimbra.sh -r -d mail.bankvictoriasyariah.co.id
[[webroot_map]]
mail.bankvictoriasyariah.co.id = /opt/zimbra/data/nginx/html
#authenticator = nginx
#installer = nginx
#server = https://acme-v02.api.letsencrypt.org/directory
/etc/letsencrypt/live/mail.bankvictoriasyariah.co.id:
total 4
lrwxrwxrwx 1 root root 54 Dec 24 23:24 cert.pem -> …/…/archive/mail.bankvictoriasyariah.co.id/cert3.pem
lrwxrwxrwx 1 root root 55 Dec 24 23:24 chain.pem -> …/…/archive/mail.bankvictoriasyariah.co.id/chain3.pem
lrwxrwxrwx 1 root root 59 Dec 24 23:24 fullchain.pem -> …/…/archive/mail.bankvictoriasyariah.co.id/fullchain3.pem
lrwxrwxrwx 1 root root 57 Dec 24 23:24 privkey.pem -> …/…/archive/mail.bankvictoriasyariah.co.id/privkey3.pem
-rw-r–r-- 1 zimbra zimbra 692 Dec 18 13:47 README
root@root:/etc/nginx/sites-available# ls -l /opt/zimbra/ssl/letsencrypt/
total 20
-rw-r----- 1 zimbra zimbra 1948 Dec 24 23:54 cert.pem
-rw-r----- 1 zimbra zimbra 2847 Dec 24 23:54 chain.pem
-rw-r----- 1 zimbra zimbra 3595 Dec 24 23:54 fullchain.pem
-rw-r----- 1 zimbra zimbra 1704 Dec 24 23:54 privkey.pem
-rw-r----- 1 zimbra zimbra 692 Dec 24 23:54 README
OK; So far, so good.
Please show output of:
ls -l /etc/letsencrypt/archive/*
Here is the result
root@root:/etc/nginx/sites-available# ls -l /etc/letsencrypt/archive/*
total 48
-rw-r–r-- 1 zimbra zimbra 1952 Dec 18 13:47 cert1.pem
-rw-r–r-- 1 zimbra zimbra 1948 Dec 19 10:00 cert2.pem
-rw-r–r-- 1 root root 1948 Dec 24 23:24 cert3.pem
-rw-r–r-- 1 zimbra zimbra 1647 Dec 18 13:47 chain1.pem
-rw-r–r-- 1 zimbra zimbra 2847 Dec 24 16:20 chain2.pem
-rw-r–r-- 1 root root 2847 Dec 24 23:52 chain3.pem
-rw-r–r-- 1 zimbra zimbra 3599 Dec 18 13:47 fullchain1.pem
-rw-r–r-- 1 zimbra zimbra 3595 Dec 19 10:00 fullchain2.pem
-rw-r–r-- 1 root root 3595 Dec 24 23:24 fullchain3.pem
-rw------- 1 zimbra zimbra 1704 Dec 18 13:47 privkey1.pem
-rw------- 1 zimbra zimbra 1704 Dec 19 10:00 privkey2.pem
-rw------- 1 root zimbra 1704 Dec 24 23:24 privkey3.pem
Rearranging those (to make some sense out of it)…
We can see that only the first set "balance" and agree on the same date/time stamp:
[1952 + 1647 = 3599]
[all 3 show 13:47]
[1948 + 2847 != 3595]
[only 2 show 10:00 - the other is 6 minutes and 20 seconds newer]
[only 2 show 23:24 - the other is 8 seconds newer]
I can only assume that your renewal script is modifying the original files [bad practice]:
Maybe we should have a look at:
That is strange …
I’m sure the certificates from /opt/zimbra/ssl/letsencrypt/* is the same with the one in /etc/letsencrypt/live/mail.bankvictoriasyariah.co.id/*
the reason is the certificates in /opt/zimbra/ssl/letsencrypt/* is copied from /etc/letsencrypt/live/mail.bankvictoriasyariah.co.id/* at Dec 24th
I haven’t executed /usr/local/sbin/certbot_zimbra.sh ever, i’m still preparing and read closed article untill i know how to do it right.
Since there are the certificate with different time stamps, can i copy chain.pem from /opt/zimbra/ssl/letsencrypt/ to /etc/letsencrypt/live/mail.bankvictoriasyariah.co.id/ ?
I want to execute certbot_zimbra.sh sometime in this end of the weekend or next weekend, should i remove the exisiting certificates or just leave as it is ?
How do i upgrade existing certbot from 0.31 to the latest ?
It is set to do that every time a renewal happens (automatically).
I can't be certain that will fix things - - but may be worth a try.
[first copy the original file to another name or location in case we need to put it back]
Perhaps looking at the script and or looking within the chainX.pem files may tell us what is going wrong.
Even if i did not type certbot_zimbra.sh -n for the first run ? i only download it and do chmod directory
YES.
These files are run automatically.
The first script is run every time (always before).
The second script is run only when a cert is renewed (conditionally after).
Okay, thank you so much for the explanation.
I'm gonna read carefully for closed topics.
